2 instances of mosquitto after reboot
For devices supporting the Auto Discovery feature. Like ZWaveJS2MQTT, Zigbee2MQTT.
roblom
Post by roblom »
Everytime I restart my raspberry I have the problem that mosquitto isn't running. I know how to solve it manually but I want to find the root cause but cannot find it. Maybe someone here can help?
After a reboot:
pi@P1-Logger:~ $ sudo service mosquitto status
	? mosquitto.service - Mosquitto MQTT Broker
	Loaded: loaded (/etc/systemd/system/mosquitto.service; enabled; vendor preset: enabled)
	Active: failed (Result: exit-code) since Sat 2022-05-28 02:02:16 CEST; 58s ago
		Docs: man:mosquitto.conf(5)
		man:mosquitto(8)
	Process: 619 ExecStartPre=/bin/mkdir -m 740 -p /var/log/mosquitto (code=exited, status=0/SUCCESS)
	Process: 620 ExecStartPre=/bin/chown mosquitto /var/log/mosquitto (code=exited, status=0/SUCCESS)
	Process: 621 ExecStartPre=/bin/mkdir -m 740 -p /run/mosquitto (code=exited, status=0/SUCCESS)
	Process: 622 ExecStartPre=/bin/chown mosquitto /run/mosquitto (code=exited, status=0/SUCCESS)
	Process: 624 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (code=exited, status=1/FAILURE)
	Main PID: 624 (code=exited, status=1/FAILURE)
	mei 28 02:02:15 P1-Logger systemd[1]: mosquitto.service: Service RestartSec=100ms expired, scheduling restart.
	mei 28 02:02:15 P1-Logger systemd[1]: mosquitto.service: Scheduled restart job, restart counter is at 5.
	mei 28 02:02:16 P1-Logger systemd[1]: Stopped Mosquitto MQTT Broker.
	mei 28 02:02:16 P1-Logger systemd[1]: mosquitto.service: Start request repeated too quickly.
	mei 28 02:02:16 P1-Logger systemd[1]: mosquitto.service: Failed with result 'exit-code'.
	mei 28 02:02:16 P1-Logger systemd[1]: Failed to start Mosquitto MQTT Broker.
When I then try to restart it:
pi@P1-Logger:~ $ sudo service mosquitto restart
	Job for mosquitto.service failed because the control process exited with error code.
	See "systemctl status mosquitto.service" and "journalctl -xe" for details.
Wen I check the status:
pi@P1-Logger:~ $ systemctl status mosquitto.service
	   Active: failed (Result: exit-code) since Sat 2022-05-28 02:04:21 CEST; 22s ago
	man:mosquitto(8)
	Process: 1656 ExecStartPre=/bin/mkdir -m 740 -p /var/log/mosquitto (code=exited, status=0/SUCCESS)
	Process: 1657 ExecStartPre=/bin/chown mosquitto /var/log/mosquitto (code=exited, status=0/SUCCESS)
	Process: 1658 ExecStartPre=/bin/mkdir -m 740 -p /run/mosquitto (code=exited, status=0/SUCCESS)
	Process: 1659 ExecStartPre=/bin/chown mosquitto /run/mosquitto (code=exited, status=0/SUCCESS)
	Process: 1660 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (code=exited, status=1/FAILURE)
	Main PID: 1660 (code=exited, status=1/FAILURE)
	mei 28 02:04:21 P1-Logger systemd[1]: mosquitto.service: Service RestartSec=100ms expired, scheduling restart.
	mei 28 02:04:21 P1-Logger systemd[1]: mosquitto.service: Scheduled restart job, restart counter is at 5.
	mei 28 02:04:21 P1-Logger systemd[1]: Stopped Mosquitto MQTT Broker.
	mei 28 02:04:21 P1-Logger systemd[1]: mosquitto.service: Start request repeated too quickly.
	mei 28 02:04:21 P1-Logger systemd[1]: mosquitto.service: Failed with result 'exit-code'.
	mei 28 02:04:21 P1-Logger systemd[1]: Failed to start Mosquitto MQTT Broker.
Then check which process is using it, then there are 2 processes using it.
pi@P1-Logger:~ $ ps -ef | grep mosquitto
	mosquit+   569     1  0 02:02 ?        00:00:00 /usr/sbin/mosquitto -d
	pi        2067   967  0 02:05 pts/0    00:00:00 grep --color=auto mosquitto
Then when I kill the first one.
pi@P1-Logger:~ $ sudo kill 569
And then restart mosquitto.
Mosquitto is running.
	   Active: active (running) since Sat 2022-05-28 02:05:36 CEST; 6s ago
	man:mosquitto(8)
	Process: 2195 ExecStartPre=/bin/mkdir -m 740 -p /var/log/mosquitto (code=exited, status=0/SUCCESS)
	Process: 2196 ExecStartPre=/bin/chown mosquitto /var/log/mosquitto (code=exited, status=0/SUCCESS)
	Process: 2197 ExecStartPre=/bin/mkdir -m 740 -p /run/mosquitto (code=exited, status=0/SUCCESS)
	Process: 2198 ExecStartPre=/bin/chown mosquitto /run/mosquitto (code=exited, status=0/SUCCESS)
	Main PID: 2199 (mosquitto)
	Tasks: 1 (limit: 2059)
	CGroup: /system.slice/mosquitto.service
	  +-2199 /usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf
	mei 28 02:05:36 P1-Logger systemd[1]: Starting Mosquitto MQTT Broker...
	mei 28 02:05:36 P1-Logger mosquitto[2199]: 1653696336: Loading config file /etc/mosquitto/conf.d/connect.conf
	mei 28 02:05:36 P1-Logger systemd[1]: Started Mosquitto MQTT Broker.
roblom
Re: 2 instances of mosquitto after reboot
Post by roblom »
Nobody got a tip where to look for?
FireWizard
Post by FireWizard »
Hello @roblom,
I see that you use something like P1-logger.
Could it be that this application tries to start its own instance of Mosquitto?
You can check this by disabling the automatic start of Mosquitto during boot.
sudo service mosquitto disable
I see also 2 places where a mosquitto config file exist.
and
So I think you try to start mosquitto 2 times, 1 normal way and 1 by P1-logger.
Check this,
roblom
Post by roblom »
P1-logger is the name of the system, so it's not a process or something.
contains
# Place your local configuration in /etc/mosquitto/conf.d/
# A full description of the configuration file is at
# /usr/share/doc/mosquitto/examples/mosquitto.conf.gz
pid_file /var/run/mosquitto/mosquitto.pid
persistence true
persistence_location /var/lib/mosquitto/
log_dest file /var/log/mosquitto/mosquitto.log
include_dir /etc/mosquitto/conf.d
listener 1883
allow_anonymous true
contains
#listener 1883
FireWizard
Hi, @roblom,
Are there any other *.conf files in the /etc/mosquitto/conf.d directory?
And also put a # in front of allow_anonymous true. Not only listener 1883.
roblom
Post by roblom »
No there are no more *.conf files in that folder.
roblom
Post by roblom »
Also put an # in front of allow_anonymous true but mosquitto won't start after a reboot, and I first have to kill the first mosquitto process in order to start mosquitto.
roblom
Post by roblom »
Still I think for some reason mosquitto is trying to start twice. Does someone know how I can check this?
FireWizard
Hi, @roblom,
So you have a mosquitto process started. Why are you killing that and then start mosquitto again.
For sure you have 2 processes running.
The first one is because you have a configuration in your /etc/mosquitto/mosquitto conf file and the second one is because you have a configuration in /etc/mosquittoconf.d directory.
In my case the mosquitto conf contains the following:
# /usr/share/doc/mosquitto/examples/mosquitto.conf.example
port 1883
pid_file /var/run/mosquitto.pid
persistence true
and my conf.d directory contains a file mymosquitto.conf, with the following contents:
port 1883
persistence_file mosquitto.db
log_dest syslog
log_dest stdout
log_dest topic
log_type error
log_type warning
log_type notice
log_type information
connection_messages true
log_timestamp true
allow_anonymous false
password_file /etc/mosquitto/passwd
As you can see in both files I have port 1883, but that does no harm. ( it is a leftover from version 1)
As I have my mosquitto server password protected you will also see a password configuration
This starts 1 instance of mosquitto
Perhaps this example will help you
roblom
Post by roblom »
FireWizard wrote: Saturday 23 July 2022 19:01 Hi, @roblom,
Because after a restart mosquitto isn't running.
The conf file in /etc/mosquitto/conf.d was empty but just to be sure i deleted it and still after a reboot mosquitto is not running and will not start after a "sudo systemctl start mosquitto". The error that is given.
systemctl status mosquitto.service gives
● mosquitto.service - Mosquitto MQTT Broker
Active: failed (Result: exit-code) since Sat 2022-07-23 20:18:43 CEST; 49s ago
man:mosquitto(8)
Process: 2667 ExecStartPre=/bin/mkdir -m 740 -p /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 2668 ExecStartPre=/bin/chown mosquitto /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 2669 ExecStartPre=/bin/mkdir -m 740 -p /run/mosquitto (code=exited, status=0/SUCCESS)
Process: 2670 ExecStartPre=/bin/chown mosquitto /run/mosquitto (code=exited, status=0/SUCCESS)
Process: 2671 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (code=exited, status=1/FAILURE)
Main PID: 2671 (code=exited, status=1/FAILURE)
jul 23 20:18:43 P1-Logger systemd[1]: mosquitto.service: Service RestartSec=100ms expired, scheduling restart.
jul 23 20:18:43 P1-Logger systemd[1]: mosquitto.service: Scheduled restart job, restart counter is at 5.
jul 23 20:18:43 P1-Logger systemd[1]: Stopped Mosquitto MQTT Broker.
jul 23 20:18:43 P1-Logger systemd[1]: mosquitto.service: Start request repeated too quickly.
jul 23 20:18:43 P1-Logger systemd[1]: mosquitto.service: Failed with result 'exit-code'.
jul 23 20:18:43 P1-Logger systemd[1]: Failed to start Mosquitto MQTT Broker.
To get mosquitto running
i use "ps -ef | grep mosquitto"
mosquit+ 581 1 0 20:15 ? 00:00:00 /usr/sbin/mosquitto -d
pi 4529 1030 0 20:22 pts/0 00:00:00 grep --color=auto mosquitto
then kill 581
then "systemctl restart mosquitto.service"
and then "systemctl status mosquitto.service" gives
Active: active (running) since Sat 2022-07-23 20:24:12 CEST; 29s ago
man:mosquitto(8)
Process: 5343 ExecStartPre=/bin/mkdir -m 740 -p /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 5344 ExecStartPre=/bin/chown mosquitto /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 5345 ExecStartPre=/bin/mkdir -m 740 -p /run/mosquitto (code=exited, status=0/SUCCESS)
Process: 5347 ExecStartPre=/bin/chown mosquitto /run/mosquitto (code=exited, status=0/SUCCESS)
Main PID: 5349 (mosquitto)
└─5349 /usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf
jul 23 20:24:11 P1-Logger systemd[1]: Starting Mosquitto MQTT Broker...
jul 23 20:24:12 P1-Logger systemd[1]: Started Mosquitto MQTT Broker.
roblom
Post by roblom »
Is it possible that mosquitto is started (so there is a pid file) but not active after boot (so it does not work)?
FireWizard
roblom
Post by roblom »
Found my problem after a long chat with chatGPT, the problem was that there was also a mosquitto start command in "etc/local.rc" which I probably added myself while using trial and error to get mosquitto up and running.
Users browsing this forum: Varazir and 1 guest
