Python plugin: Presence detection from wireless router
Number8
- Domoticz version: 2022.1
Re: Python plugin: Presence detection from wireless router
@EscApe: could you please review this new thread about iDetect crashing. Maybe I should have posted here. Thank you
https://www.domoticz.com/forum/viewtop ... 82#p288182
Debian buster on NUC and three RPi with buster.
mvzut
Sorry for replying to a very old message, but can you please share your solution with me too? I am running into this issue myself now. Moved my Domoticz, zigbee2mqtt, Dashticz, Homebridge, etc. all to containers. Everything works, including all my Python plugins, except iDetect. First it complained about the module "requests" not being present. In installed this from a command line within the docker image (using pip install requests), not the most beautiful solution but at least this worked. Next, it is complaining about paramiko. I cannot get this installed.EscApe wrote: Saturday 08 January 2022 22:31 I’m no docker expert either but managed to get it working. I can PM you my docker file. It needs some cleaning up, so I’m not going to publish it as it is. Took some trial and error to get paramiko install working because it has some complicated requirements on its own.
EscApe
- Domoticz version: 2020+
No problem. I can share my own docker file. It does contain some extra modules that you probably won’t need.mvzut wrote: Friday 24 June 2022 22:18Sorry for replying to a very old message, but can you please share your solution with me too? I am running into this issue myself now. Moved my Domoticz, zigbee2mqtt, Dashticz, Homebridge, etc. all to containers. Everything works, including all my Python plugins, except iDetect. First it complained about the module "requests" not being present. In installed this from a command line within the docker image (using pip install requests), not the most beautiful solution but at least this worked. Next, it is complaining about paramiko. I cannot get this installed.EscApe wrote: Saturday 08 January 2022 22:31 I’m no docker expert either but managed to get it working. I can PM you my docker file. It needs some cleaning up, so I’m not going to publish it as it is. Took some trial and error to get paramiko install working because it has some complicated requirements on its own.
The trick to getting paramiko installed was to also install its requirement, which in turn had their own requirements. I found out (by googling the error messages I got on every installation step) that it (temporarily) needed build-essentials to install some encryption related parts. Building the docker image will take a while.
Here’s the resulting docker file
FROM debian:buster-slim
ARG APP_VERSION
ARG APP_HASH
ARG BUILD_DATE
LABEL org.label-schema.version=$APP_VERSION \
org.label-schema.build-date=$BUILD_DATE \
org.label-schema.vcs-ref=$APP_HASH \
org.label-schema.vcs-url="https://github.com/domoticz/domoticz" \
org.label-schema.url="https://domoticz.com/" \
org.label-schema.vendor="DomoticzMod" \
org.label-schema.name="DomoticzMod" \
org.label-schema.description="Domoticz open source Home Automation system" \
org.label-schema.license="GPLv3" \
org.label-schema.docker.cmd="docker run -v ./config:/config -v ./plugins:/opt/domoticz/plugins -e DATABASE_PATH=/config/domoticz.db -p 8080:8080 -d domoticz/domoticz" \
maintainer="Domoticz Docker Maintainers <[email protected]>"
WORKDIR /opt/domoticz
ARG DEBIAN_FRONTEND=noninteractive
ENV CRYPTOGRAPHY_DONT_BUILD_RUST=1
RUN set -ex \
&& apt-get update \
&& apt-get install --no-install-recommends -y \
tzdata \
unzip \
git \
libudev-dev \
libusb-0.1-4 \
libsqlite3-0 \
curl libcurl4 libcurl4-gnutls-dev \
libpython3.7-dev \
python3 \
python3-pip \
python3-setuptools \
nano \
iputils-ping \
procps \
build-essential \
python3-cryptography \
libssl-dev \
libffi-dev \
&& OS="$(uname -s | sed 'y/ABCDEFGHIJKLMNOPQRSTUVWXYZ/abcdefghijklmnopqrstuvwxyz/')" \
&& MACH=$(uname -m) \
&& if [ ${MACH} = "armv6l" ]; then MACH = "armv7l"; fi \
&& archive_file="domoticz_${OS}_${MACH}.tgz" \
&& version_file="version_${OS}_${MACH}.h" \
&& history_file="history_${OS}_${MACH}.txt" \
&& curl -k -L https://releases.domoticz.com/releases/beta/${archive_file} --output domoticz.tgz \
&& tar xfz domoticz.tgz \
&& rm domoticz.tgz \
&& mkdir -p /opt/domoticz/userdata \
&& rm -rf /var/lib/apt/lists/* \
&& ln -s /usr/bin/pip3 /usr/bin/pip \
&& pip3 install setuptools requests paramiko motionblinds python_picnic_api paho-mqtt gTTS pychromecast hwmon \
&& apt-get remove --purge --auto-remove -y build-essential
VOLUME /opt/domoticz/userdata
EXPOSE 8080
EXPOSE 443
ENV LOG_PATH=
ENV DATABASE_PATH=
ENV WWW_PORT=8080
ENV SSL_PORT=443
ENV EXTRA_CMD_ARG=
# timezone env with default
ENV TZ=Europe/Amsterdam
COPY docker-entrypoint.sh /usr/local/bin/
RUN chmod +x /usr/local/bin/docker-entrypoint.sh \
&& ln -s usr/local/bin/docker-entrypoint.sh / # backwards compat
ENTRYPOINT ["docker-entrypoint.sh"]
CMD ["/opt/domoticz/domoticz"]
mvzut
Thanks EscApe, I will have a look. To be honest, I have never built a Docker myself, so far I only used existing containers (https://hub.docker.com/r/linuxserver/domoticz in this case). I can ask the developer of that container to include the paramiko package, but probably he won't do that just for one Python plugin...
mvzut
I will start experimenting with building my own docker container soon, but for now I solved the issue with the missing paramiko package by installing it from a terminal into the container. I had to install a whole list of things before paramiko would install:
I know, I have to redo this every time I update/recreate the container, but for now I'm happy it works
Note1: This is for the container hosted at https://hub.docker.com/r/linuxserver/domoticz, the above may be different for other pre-built containers.
Note 2: I ended up removing gcc-arm*, libffi-dev, libssl-dev and make (using the apt-get remove command) since it takes up lots of space and you don't need these packages anymore after paramiko has been successfully installed/compiled
apt-get update
apt-get install gcc-arm* libffi-dev libssl-dev make python3-dev
pip install setuptools_rust cryptography==3.3.2 paramiko requestsNote1: This is for the container hosted at https://hub.docker.com/r/linuxserver/domoticz, the above may be different for other pre-built containers.
EscApe
It's not very hard. I'm no expert, so my method might not even be the best one, but here it is in just 4 steps.mvzut wrote: Tuesday 05 July 2022 23:30 I will start experimenting with building my own docker container soon, <snip>
1. clone the official domoticz docker image
2. copy my Dockerfile over the original one
3. build the image from within the cloned directory (it will take some time and you will see some "Failed building wheel for ..." error messages. Ignore them.)
4. create the docker container from that image (when using portainer, you can also just "edit" an existing container to use the new image)
Commands to build the image (step 1-3) are:
git clone https://github.com/domoticz/domoticz-docker.git buildmydomoticzdocker
cd buildmydomoticzdocker
cp <<my Dockerfile>> .
docker build --pull --no-cache -t <<name of the image>> .
My Dockerfile is hardcoded to use the latest Domoticz Beta and it includes stuff you don't need. Instead of copying it you could also just tweak the original Dockerfile to include your requirements (in the right order!). You would than also use the build.sh command or buildstable.sh commands included with the original Domoticz Docker.
To update the container in the future (newer version of Domoticz or requirements) you only need to run steps 3 and 4 again.
EscApe
I have added FRITZ!Box as a tracker type. You can use it bij configuring the tracker as
The tracker script uses the fritzconnection module, so that has become a requirement to install the plugin. (no longer the case, see below)
Response time and reliability are great! So far it looks even better than my previous Asus (via ssh) setup. And with a lot less code
EDIT: Installation of tracker specific python modules has now been made optional. The plugin will simply replace tracker types for which the requirements are not met with an empty tracker. This way you don't have to install fritzconnect if you're not using a fritzbox.
192.168.1.1#type=fritzboxResponse time and reliability are great! So far it looks even better than my previous Asus (via ssh) setup. And with a lot less code
EscApe
In addition to the message above:
Adding the FRITZ!Box tracker reminded me that some other tweaks were long overdue. Amongst them was the default port number. It was set in the main plugin, which made sense when the plugin started out as a SSH only solution. I have now changed it so the tracker class determines the default.
I could use some help with an issue stopping the FRITZ!Box tracker. It seems like it can occasionally crash the plugin framework when you try to stop it while it is busy polling. The stop_now() function in tracker_base.py should prevent that (by waiting for the treads to finish), but somehow doesn't.
It should only be of concern for users of the FRITZ!Box tracker and it can be hard te reproduce since the tracker sits idle most of the time. So not a huge issue, but I would still like to fix it.
JediMax
- Domoticz version: 2020.2
Hallo!
I use this plugin a long time. Some time ago I updated plugins and libraries. And now I have some problem with iDetect plugin. I get errors like
I try to use plugin with login/password without any change.
I can connect to router (mikrotik) via terminal without any problem.
May I ask to help me?
iDetect: 10.1.0.1 SSH Could not connect (with os key). Exception: Int or String expectedI can connect to router (mikrotik) via terminal without any problem.
EscApe
Hi,JediMax wrote: Friday 19 August 2022 22:38 Hallo!
I use this plugin a long time. Some time ago I updated plugins and libraries. And now I have some problem with iDetect plugin. I get errors likeI try to use plugin with login/password without any change.Code: Select all
I would need a little more info to help. When did you update the plugin and libraries? Can you enable debug in the plugin settings and share the debug log from the moment the plugin starts until the first poll (and the error message)?
Even if you specify a password the ssh client will probably first try to login using a key (if that exists)
JediMax
Thank you.
Here is log
I can enter to router via ssh (like ssh [email protected]) wihout any problem.
I try to reinstall plugin(you can see it with default MAC addresses)
Here is log
2022-08-20 10:01:01.615 Status: iDetect: Entering work loop.
2022-08-20 10:01:01.615 Status: iDetect: Started.
2022-08-20 10:01:02.394 Status: iDetect: Initialized version 2.0, author 'ESCape'
2022-08-20 10:01:03.691 iDetect: Debug logging mask set to: PYTHON
2022-08-20 10:01:03.691 iDetect: Operation system is: linux
2022-08-20 10:01:03.715 iDetect: The OS user profile running domoticz is: root
2022-08-20 10:01:03.715 iDetect: Parsing user and optional keyfile from:root
2022-08-20 10:01:03.716 iDetect: start get or create wireless device
2022-08-20 10:01:03.716 iDetect: phone1 monitor tag_id:A1:B1:01:01:01:01, domoticz unit:2
2022-08-20 10:01:03.716 iDetect: phone2 monitor tag_id:C2:D2:02:02:02:02, domoticz unit:3
2022-08-20 10:01:03.716 iDetect: Monitoring {'A1:B1:01:01:01:01': <plugin.tag_device object at 0x7f8016db50>, 'C2:D2:02:02:02:02': <plugin.tag_device object at 0x7f80113820>} for presence.
2022-08-20 10:01:03.716 iDetect: Tracker configuration:10.1.0.1#type=routeros
2022-08-20 10:01:03.716 iDetect: tracker:10.1.0.1
2022-08-20 10:01:03.716 iDetect: options:type=routeros
2022-08-20 10:01:03.718 iDetect: 10.1.0.1 Tracker is of the ssh kind
2022-08-20 10:01:03.718 iDetect: 10.1.0.1 Data will be received and interpreted by <bound method BasePlugin.onDataReceive of <plugin.BasePlugin object at 0x7f804fa0a0>>
2022-08-20 10:01:03.718 iDetect: Tracker config:10.1.0.1, custom port:False, user:root, type:routeros and options:{'type': 'routeros'}
2022-08-20 10:01:03.718 iDetect: Trackers initialized as:{'10.1.0.1': <trackers.ssh_routeros.ssh_routeros object at 0x7f4c0552b0>}
2022-08-20 10:01:03.718 iDetect: Plugin initialization done.
2022-08-20 10:01:03.718 Status: iDetect: Starting tracker:10.1.0.1, user:root, class:ssh_routeros and poll interval:15
2022-08-20 10:01:11.068 iDetect: onHeartbeat called
2022-08-20 10:01:11.068 iDetect: 0 devices are present (excluding ignored devices)
2022-08-20 10:01:18.718 iDetect: 10.1.0.1 Timed poll starting like clockwork
2022-08-20 10:01:18.718 iDetect: 10.1.0.1 Start poll and return results to <bound method tracker.receiver_callback of <trackers.ssh_routeros.ssh_routeros object at 0x7f4c0552b0>>
2022-08-20 10:01:18.718 iDetect: 10.1.0.1 ====> SSH Fetching data using: interface wireless registration-table print
2022-08-20 10:01:18.718 iDetect: 10.1.0.1 ====> SSH not connected ... connecting
2022-08-20 10:01:18.718 iDetect: 10.1.0.1 ====> SSH start connect
2022-08-20 10:01:18.718 iDetect: 10.1.0.1 Could not be polled
2022-08-20 10:01:18.718 Error: iDetect: 10.1.0.1 SSH Could not connect (with os key). Exception: Int or String expected
2022-08-20 10:01:21.082 iDetect: onHeartbeat called
EscApe
Can you update the plugin and retry?
I recently made some changes to the ssh default port handling and might have introduced a bug.
Should be fixed in the update, but I cannot test it right now. Can you test it as soon as possible and share the debug log again (even if it works)?
JediMax
I update plugin and now it works good.
Thank you very much.
EscApe
You’re welcome. Thanks for testing so quickly.
Kubra
- Domoticz version: latest
I have been using and testing this plugin for about 4 weeks now and must say that it works flawless so far. Not a single on/off event is missed. I had been using the presence detection script from Hydex80 the last 3 years or so but it wasn't performing that good. Lot of events where missed. So recently made a choice to look for a better and more consistent solution.
So I would thank you EscApe for your excellent plugin and keep up the good work. Greetings from a happy user.
MrRikkie
- Domoticz version: 2022.2
I'm trying to install iDetect Python plugin however already in the first command i get stuck.
sudo pip3 install requests paramiko
Error message :
Actions taken so far :
Error message :
pi@Smarthome-Domoticz:~$ sudo pip3 install requests paramiko
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: requests in /usr/lib/python3/dist-packages (2.21.0)
Collecting paramiko
Using cached https://www.piwheels.org/simple/paramiko/paramiko-2.12.0-py2.py3-none-any.whl (213 kB)
Requirement already satisfied: six in /usr/lib/python3/dist-packages (from paramiko) (1.12.0)
Collecting bcrypt>=3.1.3
Using cached bcrypt-4.0.1.tar.gz (25 kB)
Installing build dependencies ... done
Getting requirements to build wheel ... done
Preparing metadata (pyproject.toml) ... done
Requirement already satisfied: pynacl>=1.0.1 in /usr/local/lib/python3.7/dist-packages (from paramiko) (1.5.0)
Requirement already satisfied: cryptography>=2.5 in /usr/lib/python3/dist-packages (from paramiko) (2.6.1)
Requirement already satisfied: cffi>=1.4.1 in /usr/local/lib/python3.7/dist-packages (from pynacl>=1.0.1->paramiko) (1.15.1)
Requirement already satisfied: pycparser in /usr/local/lib/python3.7/dist-packages (from cffi>=1.4.1->pynacl>=1.0.1->paramiko) (2.21)
Building wheels for collected packages: bcrypt
Building wheel for bcrypt (pyproject.toml) ... error
error: subprocess-exited-with-error
× Building wheel for bcrypt (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [58 lines of output]
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-armv7l-cpython-37
creating build/lib.linux-armv7l-cpython-37/bcrypt
copying src/bcrypt/__init__.py -> build/lib.linux-armv7l-cpython-37/bcrypt
copying src/bcrypt/__about__.py -> build/lib.linux-armv7l-cpython-37/bcrypt
running egg_info
writing src/bcrypt.egg-info/PKG-INFO
writing dependency_links to src/bcrypt.egg-info/dependency_links.txt
writing requirements to src/bcrypt.egg-info/requires.txt
writing top-level names to src/bcrypt.egg-info/top_level.txt
reading manifest file 'src/bcrypt.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no previously-included files found matching 'requirements.txt'
warning: no previously-included files found matching 'release.py'
warning: no previously-included files found matching 'mypy.ini'
warning: no previously-included files matching '*' found under directory '.github'
warning: no previously-included files matching '*' found under directory '.circleci'
warning: no previously-included files found matching 'src/_bcrypt/target'
warning: no previously-included files matching '*' found under directory 'src/_bcrypt/target'
adding license file 'LICENSE'
writing manifest file 'src/bcrypt.egg-info/SOURCES.txt'
copying src/bcrypt/_bcrypt.pyi -> build/lib.linux-armv7l-cpython-37/bcrypt
copying src/bcrypt/py.typed -> build/lib.linux-armv7l-cpython-37/bcrypt
running build_ext
running build_rust
=============================DEBUG ASSISTANCE=============================
If you are seeing a compilation error please try the following steps to
successfully install bcrypt:
1) Upgrade to the latest pip and try again. This will fix errors for most
users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
2) Ensure you have a recent Rust toolchain installed. bcrypt requires
rustc >= 1.56.0.
Python: 3.7.3
platform: Linux-5.10.103-v7+-armv7l-with-debian-10.13
pip: n/a
setuptools: 65.7.0
setuptools_rust: 1.5.2
rustc: n/a
error: can't find Rust compiler
If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
To update pip, run:
pip install --upgrade pip
and then retry package installation.
If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
This package requires Rust >=1.56.0.
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for bcrypt
Failed to build bcrypt
ERROR: Could not build wheels for bcrypt, which is required to install pyproject.toml-based projects- upgrade pip
- installed python3.7--dev
hestia
new install on a new env RPI bullseye
Domoticz Version: 2023.1 (build 15098)
Build Hash: 867c4e8fa
Compile Date: 2023-02-24 07:56:50
dzVents Version: 3.1.8
Python Version: 3.9.2 (default, Mar 12 2021, 04:06:34) [GCC 10.2.1 20210110]
When dz restart, I've got those errors
- Spoiler: show
- Spoiler: show
DeKraker
I have tried to get the plugin working on my setup. Without luck so far.
Router I want to poll is a Netgear Orbi (firmware version V4 4 1 29 3 10 80)
Running Domoticz (2022 2).
I have configured the plugin with tracker: '[local IP address]#type=orbi-http'
I am getting to following error in Domoticz log:
' Error: Home detection: [local IP address] Polling error: Failed to parse: [local IP address]:False'
Do I miss something or am I doing anything wrong?
Many thanks for any help!
hestia
I still have the same issuehestia wrote: Monday 27 February 2023 15:36 Hi,
When dz restart, I've got those errorsI disable and enable the pluging and after it's ok
- Spoiler: show
Some config
- Spoiler: show
Any idea to make it work?
SSH Could not connect (using password). Exception: No existing session
I need to disable the hardware and enable it again, and restart dz.
Some compatibility issue with ZigBeeForDonomoticZ: when I disable ZigBeeForDomoticZ, no issue
I'm trying to use iDetect with an Orbi system , but so far it is hardly failing. Would appreciate any help
Here is the setup:
and here after are the log
Here is the setup:
Mar 20 17:04:39 rasp jemalloc.sh[30336]: 2023-03-20 17:04:39.062 iDetect: 10.0.0.1 Timed poll starting like clockwork
Mar 20 17:04:39 rasp jemalloc.sh[30336]: /usr/lib/python3.10/site-packages/urllib3/connectionpool.py:1045: InsecureRequestWarning: Unverified HTTPS request is being made to host '10.0.0.1'. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/1.26.x/advanced-usage.html#ssl-warnings
Mar 20 17:04:39 rasp jemalloc.sh[30336]: warnings.warn(
Mar 20 17:04:39 rasp jemalloc.sh[30336]: 2023-03-20 17:04:39.345 iDetect: 10.0.0.1 Returned: <html><head>
Mar 20 17:04:39 rasp jemalloc.sh[30336]: <script>
Mar 20 17:04:39 rasp jemalloc.sh[30336]: top.location.href="multi_login.html";
Mar 20 17:04:39 rasp jemalloc.sh[30336]: </script>
Mar 20 17:04:39 rasp jemalloc.sh[30336]: </head>
Mar 20 17:04:39 rasp jemalloc.sh[30336]: <body bgcolor="#ffffff">
Mar 20 17:04:39 rasp jemalloc.sh[30336]: </body>
Mar 20 17:04:39 rasp jemalloc.sh[30336]: </html>
Mar 20 17:04:39 rasp jemalloc.sh[30336]: 2023-03-20 17:04:39.346 iDetect: 10.0.0.1 Sent RAW:<html><head>
Mar 20 17:04:39 rasp jemalloc.sh[30336]: 2023-03-20 17:04:39.346 iDetect: Inbound data from: 10.0.0.1 containing []
Mar 20 17:04:39 rasp jemalloc.sh[30336]: 2023-03-20 17:04:39.346 iDetect: 0 devices are present (excluding ignored devices)
Mar 20 17:04:41 rasp jemalloc.sh[30336]: 2023-03-20 17:04:41.075 iDetect: onHeartbeat called
Mar 20 17:04:41 rasp jemalloc.sh[30336]: 2023-03-20 17:04:41.076 iDetect: 0 devices are present (excluding ignored devices)Who is online
