Latest version of domoticz running on arbian buster.
Works like a charm for years now.
But somehow the plugin works not all the time anymore.
Every now and then the information comes in.
The inverter is not the problem the app en local site works also.
var version="H4.01.38Y1.0.08W1.0.07";var m2mMid="1602813294";var wlanMac="AC:CF:23:15:15:68";var m2mRssi="10%";var wanIp="192.168.2.15";var nmac="ACCF2315156B";var fephy="off";var webData="NLDN4020175GX530,NL1-V1.0-0118-4,V2.0-0028,omnik4000tl ,4000,1432,1441,6304,,0,";function initPageText(){var A=window.parent.reList("status");fileText("st1",A["t1"]);fileText("st2",A["t2"]);fileText("st3",A["t3"]);for(var B=1;B<=27;B++){if(B!=14){fileText("tx"+B,A[B])}}init_main_page();initStatus();changeFont();child_getH()}function upfold(A){if(document.getElementById("up_"+A+"_div").style.display=="none"){show("up_"+A+"_div");document.getElementById("up_"+A).src="image/up.png"}else{hide("up_"+A+"_div");document.getElementById("up_"+A).src="image/down.png"}if(A==3){if(document.getElementById("ser_status").src==""){document.getElementById("ser_status").src="server_status.html"}}}function init_main_page(){var E=document.form_cover_setting;cfg2Form(E);var C;var D;var B;var A;B=window.parent.reTip("1");A=window.parent.reTip("2");document.getElementById("cover_ver").innerHTML=version;document.getElementById("cover_mid").innerHTML=m2mMid;if(E.wifi_on.value=="disable"){document.getElementById("cover_ap_status").innerHTML=A;document.getElementById("cover_ap_mac").innerHTML="";document.getElementById("cover_ap_ssid").innerHTML="";document.getElementById("cover_ap_ip").innerHTML="";document.getElementById("cover_sta_status").innerHTML=A;document.getElementById("cover_sta_rssi").innerHTML="";document.getElementById("cover_sta_ip").innerHTML="";document.getElementById("cover_sta_mac").innerHTML="";document.getElementById("cover_sta_ssid").innerHTML=""}else{if(E.sta_enable.value=="1"){document.getElementById("cover_ap_status").innerHTML=B;document.getElementById("cover_ap_mac").innerHTML=wlanMac;document.getElementById("cover_ap_ssid").innerHTML=E.ap_ssid.value;document.getElementById("cover_ap_ip").innerHTML=E.lan_ip.value;document.getElementById("cover_sta_status").innerHTML=B;document.getElementById("cover_sta_rssi").innerHTML=m2mRssi;document.getElementById("cover_sta_ip").innerHTML=wanIp;C=wlanMac.substring(0,16);D="0x"+wlanMac.charAt(16);D=D*1+1;D=D.toString(16);D=D.toUpperCase();C=C+D;document.getElementById("cover_sta_mac").innerHTML=C;document.getElementById("cover_sta_ssid").innerHTML=E.sta_ssid.value}else{document.getElementById("cover_ap_status").innerHTML=B;document.getElementById("cover_ap_mac").innerHTML=wlanMac;document.getElementById("cover_ap_ssid").innerHTML=E.ap_ssid.value;document.getElementById("cover_ap_ip").innerHTML=E.lan_ip.value;document.getElementById("cover_sta_status").innerHTML=A;document.getElementById("cover_sta_rssi").innerHTML="";document.getElementById("cover_sta_ip").innerHTML="";document.getElementById("cover_sta_mac").innerHTML="";document.getElementById("cover_sta_ssid").innerHTML=""}}}function init_webdata_form(){var E=webData;var B="";var A,C,D;A=E.length;C=0;D=0;while(C<A){if(E.charAt(C)==","){C+=1;D+=1;web_data_show(D,B);B=""}else{B=B+E.charAt(C);C+=1}}}function web_data_show(D,A){var C=new Array("webdata_sn","webdata_msvn","webdata_ssvn","webdata_pv_type","webdata_rate_p","we
