Problem sensor electric
Tomcen
Post by Tomcen »
Hello , I have a problem with updating the electric sensor (computed). I have a query
http://my_ip_domoticz/json.htm?username=username&password=paswoord&type=command&param=udevice&idx=63&nvalue=0&svalue=2400>
but domoticz don/t update a state/value.
What's wrong?
Domoticz version: 2025.1
Re: Problem sensor electric
Svalue should contain 2 values
/json.htm?type=command&param=udevice&idx=IDX&nvalue=0&svalue=POWER;ENERGY
So svalue=2400;0
Tomcen
Post by Tomcen »
But I am reading the value of the current energy production from the solar inverter, what should I then provide in the inquiry when it comes to POWER; ENERGY
Power is current power (in Watt), ENERGY is the counter of total power generated in Wh.
But from your screenshot you have set it to computed and not from device so the Energy counter is ignored (so I put it to 0 in my example)
Tomcen
Post by Tomcen »
http://my_ip_domoticz/json.htm?username=admin&password=password&type=command&param=udevice&idx=63&nvalue=0&svalue=2700;0
i get response
"status" : "OK",
"title" : "Update Device"
But te status is
What does the log file say?
Users browsing this forum: Google [Bot], imautohuttraeger and 1 guest
