Why is there a difference between an virtual switch Icon and normal switch Icon? I like to have the bulb light.
Can i change that? The upper icon is a virtual switch.
icon light difference
- firefox_2022-06-06_16-57-31.jpg (6.34 KiB) Viewed 606 times
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
- HansieNL
Re: icon light difference
You can change the icon with the parameter iconOn / iconOff in your block config.marktn wrote: Monday 06 June 2022 17:02 Hi,
See https://dashticz.readthedocs.io/ how to use that parameter.
Blah blah blah
Sorry for my late response, thanks for helping!HansieNL wrote: Monday 06 June 2022 19:40You can change the icon with the parameter iconOn / iconOff in your block config.marktn wrote: Monday 06 June 2022 17:02 Hi,
Nice these icons!
Is it also possible to make the bulb yellow? It is know gray, highlighted
- HansieNL
Can you try with the following code:
blocks[groep_woonk_zacht_switch]['iconOn'] = 'fas fa-lightbulb';
blocks[groep_woonk_zacht_switch]['iconOff'] = 'fas fa-lightbulb';
Blah blah blah
Yes that works. Thanks for the support!!
