How to reset an timer
Fredom
Domoticz version: 2025.1
Post by Fredom »
Dear members,
I need some help
The purpose of this script is that when the sensor turns on, it turns on the lamp.
The lamp may only go out after 10 minutes if the sensor is also off.
So as long as the sensor is on, the lamp must also remain on.
But if the sensor switches off and on again within 10 min, the 10 min must be restarted.
Now the lamp always switches off after 10 minutes and then immediately on again.
Does anyone have the solution for me.
Or is this not possible
return
    on =
        devices = {
                     'Lamp',
                     'Sensor',
   execute = function(dz)
        local  sensor = dz.devices('Sensor')
        local     lamp = dz.devices('Lamp')
    if sensor.state == 'On' then
        lamp.switchOn().silent()
    if sensor.state == 'Off' then
        lamp.switchOff().afterMin(10)
Yours sincerely,
Fred
Rasberry Pi 3B+ - Debian Trixie - Domoticz 2025.2
RFLink - RFXCom - Zigbee (CC2531)
P1 Smart Meter - KaKu
plugge
Re: How to reset an timer
Post by plugge »
Could you try this (tested with dummy devices):
local lightOnMin = 10 -- How long you want the light to burn after the sensor turned off (maybe try 2 minutes first)
return
    on =
        customEvents = { 'checkSensor',
        timer = { 'every minute'
        devices = {
                     'Lamp',
                     'Sensor',
   execute = function(dz, item)
    if item.isDevice and
       item.name == 'TestSensor' and
    then
        lamp.switchOn()
        dz.emitEvent('checkSensor')
    if item.isCustomEvent and
       sensor.state == 'Off' and
       sensor.lastUpdate.minutesAgo == lightOnMin
    then
        lamp.switchOff()
Fredom
Post by Fredom »
plugge wrote: Wednesday 01 June 2022 15:46 Could you try this (tested with dummy devices):
return
    on =
        devices = {
                     'Lamp',
                     'Sensor',
    then
        lamp.switchOn()
    then
        lamp.switchOff()
Hi plugge,
Thanks for your quick response.
It almost works well.
I made your proposal and set the timer to 2 min and also tested with 2 dummys.
If I turn the sensor off and on once within 2 minutes, it works fine.
If I switch the sensor off and on several times, the lamp switches off immediately when the sensor also switches off
Yours sincerely,
Fred
plugge
Post by plugge »
Hm. In my case the behavior is different, but the script generates far too many events, so that's not good.
Better disable it and throw away :-/
Maybe I find a better solution, later.
Fredom
Post by Fredom »
Okay,
Thanks for your help for now.
I hope you or someone else has a solution for this
Yours sincerely,
Fred
plugge
Post by plugge »
Okey, one more try. A bit simpler, albeit less accurate as to how long the light remains on 10 min -> 11-12 min.
But that should not be a problem, if I understood correctly what you're trying to achieve.
Can you try this:
local lightOnMin = 2  --(the light will stay on for at least 3 min)
Minimum = 2 minutes (it takes at least 2x 1 minute events to check the script twice
So, when you specfy the light to stay on for 10 minutes after the sensor turned off,
the light will stay on for 11 minutes, depending on how busy the system is with other events.
Everytime you turn the sensor on and then off, the timing starts from 0.
return
    on =
        devices = {
                     'Lamp',
                     'Sensor',
       item.name == 'Sensor' and
    then
        lamp.switchOn().checkFirst()
    if item.isTimer and
       sensor.lastUpdate.minutesAgo >= lightOnMin
    then
       lamp.switchOff()
If this fails, I throw in the towel...
Fredom
Post by Fredom »
plugge wrote: Wednesday 01 June 2022 20:52 Okey, one more try. A bit simpler, albeit less accurate as to how long the light remains on 10 min -> 11-12 min.
Can you try this:
return
    on =
        devices = {
                     'Lamp',
                     'Sensor',
    then
    if item.isTimer and
    then
       lamp.switchOff()
Hi plugge,
It works perfectly now.
thank you for your effort
Yours sincerely,
Fred
