Latest update crashes domoticz
Gents,
Updated today Domoticz, what was not very successful.
System Ubuntu 20.04.
I get the message that domoticz is offline.
When I check the status: everting should be running.
I have made a fresh install, which was OK, but after importing my settings, the system is offline again.
● domoticz.service - LSB: Home Automation System
Loaded: loaded (/etc/init.d/domoticz.sh; generated)
Active: active (exited) since Tue 2022-05-24 13:04:40 CEST; 10min ago
Docs: man:systemd-sysv-generator(8)
Process: 38452 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
mei 24 13:04:40 ServerZima-M systemd[1]: Starting LSB: Home Automation System...
mei 24 13:04:40 ServerZima-M domoticz.sh[38458]: 2022-05-24 13:04:40.327 Status: Domoticz V2022.1 (bu…zMoCuz
mei 24 13:04:40 ServerZima-M domoticz.sh[38458]: 2022-05-24 13:04:40.327 Status: Build Hash: d479d6cb…:01:38
mei 24 13:04:40 ServerZima-M domoticz.sh[38458]: 2022-05-24 13:04:40.327 Status: Startup Path: /home/…oticz/
mei 24 13:04:40 ServerZima-M domoticz.sh[38458]: domoticz: Domoticz is starting up....
mei 24 13:04:40 ServerZima-M domoticz[38458]: Domoticz is starting up....
mei 24 13:04:40 ServerZima-M domoticz[38459]: Domoticz running...
mei 24 13:04:40 ServerZima-M systemd[1]: Started LSB: Home Automation System.
Hint: Some lines were ellipsized, use -l to show in full.
P.S. I am running the deConz plugin as well. Has been running well for years.
- Domoticz version: 2024.2
Re: Latest update crashes domoticz
Same here:
Domoticz (Latest) on Docker/Synology:
This afternoon after auto-update (Portainer) from 2022.1-build:14338 to 2022.1-build:14341 Domoticz is crashing just after startup, see below.
When i remove the mentioned plugin Domoticz is not crashing.
All versions of Domoticz before 2022.1-build:14341 had no problem with loading and/or using the mentioned plugin.
Part of logging:
2022-05-24 14:54:52.239 Status: Notification: Docker DS411: Domoticz (Latest) has just been (re)started
2022-05-24 14:54:52.366 Status: PluginSystem: 1 plugins started.
2022-05-24 14:54:52.997 Status: Domo_DS411: Connecting to 192.168.1.16:1883
2022-05-24 14:54:52.158 Error: Woonkamer: (YamahaPlug) failed to load 'plugin.py', Python Path used was ':/usr/lib/python37.zip:/usr/lib/python3.7:/usr/lib/python3.7/lib-dynload:/usr/local/lib/python3.7/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.7/dist-packages'.
2022-05-24 14:54:52.285 Error: Woonkamer: Exception: 'ModuleNotFoundError'. No traceback available.
Part of logging:
Synology - DS411+II
Synology - DS918+
RFXCOM - RFXtrx433XL (LAN)
Oregon - Weatherstation
Some KAKU, Impuls, TFA, etc.
Synology - DS918+
Same here...
- kiddigital
So all 3 reports here have a crash when loading a Python plugin?
Please disable the plugin and let us know it Domoticz still crashes.
And which plugin(s) do let Domoticz crash.
I already reverted back to an earlier version of Domoticz...
- Domoticz version: 2024.7
I just updated to beta build 14341 on Ubuntu 20.04 on an x86 system and have no crashing environment.
same here.
Docker version 2022.1.14341
Crashes with plugin: Denon/Marantz Amplifier
I disabled it and crashes with the nextplugin: Xiaomi Mi Robot Vacuum
In this moment i need to roolback to a previous version, because i need that all works again.
I will try this night again with this version and try to tell here more plugins that crash
hello,
As stated before: When i remove the mentioned plugin Domoticz is not crashing.
Plugin name: https://github.com/thomas-villagers/domoticz-yamaha
Synology - DS411+II
Synology - DS918+
Synology - DS918+
From what beta version did you update? This to indicate where the issue could be introduced.
Huntback wrote:
It might be build 14339 introducing the problem, for some:from 2022.1-build:14338 to 2022.1-build:14341
14339 20220520 Python Plugin BugFix: WebSocket messages handled incorrectly when split across TCP/IP buffers
the previous version that works for me was docker 2022.1.14338DAVIZINHO wrote: ↑Tuesday 24 May 2022 21:08 same here.
- Domoticz version: BETA
How do you all stop the plug-ins? My installation crashes even before i get to the hardware page.
If you updated with webui or script then you can revert back to the previous version see wiki https://www.domoticz.com/wiki/Raspberry ... eta_update
When using docker you could return to a previous docker build version. I do not think there were database changes in the latest beta releases.
- Dnpwwo
Unlikely that the WebSocket fix impacted this because it was contained to that protocol but there was a more general change in the last week around returning data to plgins that may have an issue.
If you are impacted please post the domoticz_crash.log file (from you Domoticz folder) and I can look.
see closed issue: https://github.com/domoticz/domoticz/issues/5243Dnpwwo wrote: ↑Wednesday 25 May 2022 0:37 Unlikely that the WebSocket fix impacted this because it was contained to that protocol but there was a more general change in the last week around returning data to plgins that may have an issue.
update: i have localized the plugin with the problem. it was the deconz plugin. There was an update for the plugin but it didn't resolve the problem.
- Dnpwwo
I've had a look at the deConz plugin and it does use WebSockets so it could be impacted.
If anyone has a test machine that can use this plugin it would be helpful to see the output from running with the plugin debug level set to include 'Messages'.
There is also a WebSocket Client example plugin that ships with Domoticz and the Wiki page has been updated with more information (https://www.domoticz.com/wiki/Developin ... ol_Details) because the plugin currently only handles best case scenarios.
In my case I also have to back to build 14337 to have below plugin running fine:
https://github.com/guillaumezin/DomoticzEbusd
Some logs but rather not helpful:
second case
Tue May 24 20:58:42 2022 daemon.info domoticz: VailantPiec: Debug set to 1
Tue May 24 20:58:42 2022 daemon.info domoticz: VailantPiec: findDevices() create connection to 127.0.0.1:8889
Tue May 24 20:58:42 2022 daemon.info domoticz: VailantPiec: Connect
Tue May 24 20:58:42 2022 daemon.info domoticz: VailantPiec: onConnect for json called
Tue May 24 20:58:42 2022 daemon.info domoticz: VailantPiec: Find
Tue May 24 20:58:42 2022 daemon.info domoticz: VailantPiec: CConnection_send, send request from 'VailantPiec' ignored. Plugin is stopping.
Wed May 25 00:04:32 2022 daemon.info domoticz: VailantPiec: handleFifo() create connection to 127.0.0.1:8888
Wed May 25 00:04:32 2022 daemon.info domoticz: VailantPiec: Connect
Wed May 25 00:04:32 2022 daemon.info domoticz: VailantPiec: onConnect for telnet called
Wed May 25 00:04:32 2022 daemon.info domoticz: VailantPiec: Handle
Wed May 25 00:04:32 2022 daemon.info domoticz: VailantPiec: Telnet write: read -v -c broadcast outsidetemp
- superelch
+1
fallback to latest backup.
hope it can be fixed soon.
thanks to all for your work and lifetime you spend......
Raspberry / Domoticz (beta) / z-wave & xiaomi & habridge & 5x Alexa & google dots & milight & yeelight & harmony hub & Netatmo & ITTT & sonoff & Conbee II .... & a girlfriend who hates that stuff ...
- heggink
- Domoticz version: 12451
Here's what happens to my test plugin (from the memory leak issue on GitHub) when using "None" as protocol:
2022-05-25 10:56:48.419 Status: T: Started.
2022-05-25 10:56:48.419 Status: NotificationSystem: thread started...
2022-05-25 10:56:48.420 Status: T: Entering work loop.
2022-05-25 10:56:48.420 Status: EventSystem: reset all events...
2022-05-25 10:56:48.422 Status: EventSystem: reset all device statuses...
2022-05-25 10:56:48.565 Status: Python EventSystem: Initializing event module.
2022-05-25 10:56:48.566 Status: EventSystem: Started
2022-05-25 10:56:48.567 Status: EventSystem: Queue thread started...
2022-05-25 10:56:48.588 Status: T: Initialized version 1.0.1, author 'heggink'
2022-05-25 10:56:48.591 T: Debug logging mask set to: PYTHON PLUGIN QUEUE IMAGE DEVICE CONNECTION MESSAGE ALL
2022-05-25 10:56:48.591 T: Pushing 'ListenDirective' on to queue
2022-05-25 10:56:48.591 T: Acquiring GIL for 'onStartCallback'
2022-05-25 10:56:48.591 T: Processing 'ListenDirective' message
2022-05-25 10:56:48.591 T: Acquiring GIL for 'ListenDirective'
2022-05-25 10:56:48.591 T: Protocol for 'Server Connection' not specified, 'None' assumed.
2022-05-25 10:56:48.591 T: Transport set to: 'TCP/IP', :8765.
2022-05-25 10:56:48.591 T: Listen directive received, action initiated successfully.
2022-05-25 10:56:48.796 Status: PluginSystem: 1 plugins started.
2022-05-25 10:56:50.440 M: Temp (Internal Temperature)
2022-05-25 10:56:58.009 T: Pushing 'onHeartbeatCallback' on to queue
2022-05-25 10:56:58.059 T: Processing 'onHeartbeatCallback' message
2022-05-25 10:56:58.059 T: Acquiring GIL for 'onHeartbeatCallback'
2022-05-25 10:56:58.060 T: Calling message handler 'onHeartbeat' on 'module' type object.
2022-05-25 10:56:58.060 T: onHeartbeat called
2022-05-25 10:56:58.060 T: Acquiring GIL for 'onHeartbeatCallback'
2022-05-25 10:56:59.480 T: Acquiring GIL for 'CPluginTransportTCP::handleAsyncAccept'
2022-05-25 10:56:59.481 T: Pushing 'ProtocolDirective' on to queue
2022-05-25 10:56:59.481 T: Pushing 'onConnectCallback' on to queue
2022-05-25 10:56:59.481 T: Acquiring GIL for 'CPluginTransportTCP::handleRead'
2022-05-25 10:56:59.481 T: Pushing 'ReadEvent' on to queue
2022-05-25 10:56:59.482 T: Acquiring GIL for 'CPluginTransportTCP::handleRead'
2022-05-25 10:56:59.482 Queued asynchronous read aborted (127.0.0.1:59256), [2] End of file.
2022-05-25 10:56:59.482 T: Pushing 'DisconnectedEvent' on to queue
2022-05-25 10:56:59.513 T: Processing 'ProtocolDirective' message
2022-05-25 10:56:59.513 T: Acquiring GIL for 'ProtocolDirective'
2022-05-25 10:56:59.513 T: Protocol set to: 'None'.
2022-05-25 10:56:59.513 T: Processing 'onConnectCallback' message
2022-05-25 10:56:59.513 T: Acquiring GIL for 'onConnectCallback'
2022-05-25 10:56:59.513 T: Calling message handler 'onConnect' on 'module' type object.
2022-05-25 10:56:59.513 T: onConnect called
2022-05-25 10:56:59.513 T: Connected successfully to: 127.0.0.1:59256
2022-05-25 10:56:59.514 T: Name: '127.0.0.1:59256', Transport: 'TCP/IP', Protocol: 'None', Address: '127.0.0.1', Port: '59256', Baud: -1, Timeout: 0, Bytes: 12, Connected: True, Last Seen: 2022-05-25 10:56:59, Parent: 'Server Connection'
2022-05-25 10:56:59.514 T: onConnect saving child connection for 127.0.0.1:59256
2022-05-25 10:56:59.514 T: Acquiring GIL for 'onConnectCallback'
2022-05-25 10:56:59.514 T: Processing 'ReadEvent' message
2022-05-25 10:56:59.514 T: Acquiring GIL for 'ReadEvent'
2022-05-25 10:56:59.514 T: Received 12 bytes of data
2022-05-25 10:56:59.514 T: 68 65 6c 6c 6f 20 77 6f 72 6c 64 0a .. .. .. .. .. .. .. .. hello.world.
2022-05-25 10:56:59.514 T: Pushing 'onMessageCallback' on to queue
2022-05-25 10:56:59.514 T: Processing 'DisconnectedEvent' message
2022-05-25 10:56:59.514 T: Acquiring GIL for 'DisconnectedEvent'
2022-05-25 10:56:59.515 T: Disconnect event received for '127.0.0.1:59256'.
2022-05-25 10:56:59.515 T: Pushing 'onDisconnectCallback' on to queue
2022-05-25 10:56:59.515 T: Acquiring GIL for 'DisconnectedEvent'
2022-05-25 10:56:59.515 T: Processing 'onMessageCallback' message
2022-05-25 10:56:59.515 T: Acquiring GIL for 'onMessageCallback'
2022-05-25 10:56:59.515 T: Calling message handler 'onMessage' on 'module' type object.
2022-05-25 10:56:59.515 T: onMessage called for connection: 127.0.0.1:59256
Fatal Python error: Segmentation fault
Current thread 0x6eaff220 (most recent call first):
File "/home/pi/domoticz/plugins/test/plugin.py", line 40 in onMessage
File "/home/pi/domoticz/plugins/test/plugin.py", line 66 in onMessage
2022-05-25 10:56:59.517 Error: Domoticz(pid:302, tid:321('T')) received fatal signal 11 (Segmentation fault)
2022-05-25 10:56:59.517 Error: siginfo address=0x12e, address=(nil)
2022-05-25 10:56:59.534 T: Acquiring GIL for 'CPluginTransportTCP::handleAsyncAccept'
2022-05-25 10:57:00.455 M: General/Custom Sensor (Arm Clock Speed)
2022-05-25 10:57:00.469 M: General/Custom Sensor (V3D Clock Speed)
2022-05-25 10:57:00.480 M: General/Custom Sensor (Core Clock Speed)
2022-05-25 10:57:03.149 Error: Thread 14 (Thread 0x6eaff220 (LWP 321)):
2022-05-25 10:57:03.149 Error: #0 __waitpid (options=0, stat_loc=0x6eafdcf0, pid=341) at ../sysdeps/unix/sysv/linux/waitpid.c:30
2022-05-25 10:57:03.149 Error: #1 __waitpid (pid=341, stat_loc=0x6eafdcf0, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
2022-05-25 10:57:03.149 Error: #2 0x0022b35c in dumpstack_gdb(bool) ()
2022-05-25 10:57:03.149 Error: #3 0x0022b928 in signal_handler(int, siginfo_t*, void*) ()
2022-05-25 10:57:03.149 Error: #4 <signal handler called>
2022-05-25 10:57:03.149 Error: #5 raise (sig=11) at ../sysdeps/unix/sysv/linux/raise.c:50
2022-05-25 10:57:03.149 Error: #6 <signal handler called>
2022-05-25 10:57:03.149 Error: #7 0x69746f70 in ?? ()
2022-05-25 10:57:03.149 Error: #8 0x75d37198 in _PyObject_GetMethod () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2022-05-25 10:57:03.149 Error: #9 0x75b6f440 in _PyEval_EvalFrameDefault () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2022-05-25 10:57:03.149 Error: #10 0x75b77dd4 in ?? () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
Debug is on the setting "basic + messages" when i restart the service i get the following error:
2022-05-25 13:45:56.390 Error: Domoticz(pid:6577, tid:6602('deCONZ')) received fatal signal 11 (Segmentation fault)
2022-05-25 13:45:56.390 Error: siginfo address=0x19b1, address=(nil)
Build Hash: d479d6cb8
Compile Date: 2022-05-23 01:01:38
dzVents Version: 3.1.8
Python Version: 3.7.3 (default, Jan 22 2021, 20:04:44) [GCC 8.3.0]
Rasbian Buster
(it's not really a test machine it's my daily used domoticz install )
