Ikea zigbee blind
gorstj
Ikea zigbee blind
Post by gorstj »
I had trouble linking my Ikea blinds when I was using Zigate (could get it to go one way but not the toher... gave up for a while)
Just tried again now I have upgraded to a Sonoff USB stick and Zigbeefordomoticz
The blind with open/close perfecly.
However, it will not work if set at a % e.g. opened to 50%. Just does nothing.
Domoticz 2022.1
ZigbeeForDomoticz 6.2.044
SONOFF Universal Zigbee 3.0 USB Dongle Plus
It was set as 'blind percentage inverted' in Domoticz
Any ideas?
Here is the JSON output in the plugin
Version : "3"
ZDeviceName : "Garden Blind"
Status : "inDB"
SQN : "57"
Ep : Object {"01":{"1000":{},"0000":{"4000":"2.2.007","0004":"IKEA of Sweden","0005":"FYRTUR block-out roller blind","0000":"3","0001":"34","0002":"99","0003":"1","0006":"20190311","0007":"3","000a":"45313735372d313430"},"0001":{"0021":0},"0003":{},"0004":{},"0005":{},"0020":{},"0102":{"0000":0,"0007":3,"0008":0,"0010":"0","0011":"65535","0017":0,"fffd":"1"},"0019":{},"fc7c":{},"Type":"WindowCovering","ClusterType":{"2429":"WindowCovering"}}}
Heartbeat : "151"
RIA : "1"
LQI : 0
Battery : Object {}
Model : "FYRTUR block-out roller blind"
ForceAckCommands : Array[0] []
MacCapa : "80"
IEEE : "000d6ffffea05be2"
Type : "WindowCovering"
ProfileID : "0104"
ZDeviceID : "0202"
App Version : "34"
Attributes List : Object {}
DeviceType : "RFD"
HW Version : "1"
Last Cmds : Array[0] []
LogicalType : "End Device"
Manufacturer : "117c"
Manufacturer Name : "IKEA of Sweden"
NbEp : "1"
PowerSource : "Battery"
ReadAttributes : Object {"Ep":{"01":{"0000":{"TimeStamp":"16/05/2022 14:28:12","iSQN":{"4000":"15","0000":"12","0001":"12","0002":"12","0003":"13","0004":"13","0005":"13","0006":"14","0007":"14","000a":"14"},"Attributes":{"4000":"00","0000":"00","0001":"00","0002":"00","0003":"00","0004":"00","0005":"00","0006":"00","0007":"00","000a":"00"},"ZigateRequest":{}},"0001":{"TimeStamp":"16/05/2022 14:27:45","iSQN":{"0021":"01"},"Attributes":{"0021":"00"},"ZigateRequest":{}},"0019":{"TimeStamp":"16/05/2022 14:27:50","iSQN":{"0001":"02","0002":"02","0003":"02","0004":"03","0005":"03","0006":"03","0007":"04","0008":"04","0009":"04","000a":"05"},"Attributes":{"0001":"86","0002":"86","0004":"86","0005":"86","0007":"86","0008":"86","000a":"86"},"ZigateRequest":{}},"0102":{"TimeStamp":"16/05/2022 14:28:06","iSQN":{"0000":"0f","0007":"0f","0008":"0f","0010":"10","0011":"10","0017":"10","fffd":"11"},"Attributes":{"0000":"00","0007":"00","0008":"00","0010":"00","0011":"00","0017":"00","fffd":"00"},"ZigateRequest":{}}}}}
ReceiveOnIdle : ""
Stack Version : "99"
Stamp : Object {"time":1653133106.5433862,"Time":"2022-05-21 12:38:26","MsgType":"8011","LastSeen":"21/05/2022 12:38:26"}
ZCL Version : "3"
Health : ""
WriteAttributes : Object {"Ep":{"01":{"1000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0001":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0003":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0004":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0005":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0020":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0102":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0019":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"fc7c":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}}}}
GroupMemberShip : Object {"01":{}}
ConfigSource : "DeviceConf"
Capability : Array[3] ["Reduced-Function Device","Standard security","NwkAddr should be allocated"]
SWBUILD_3 : "2.2.007"
BindingTable : Object {"Devices":[],"SQN":0,"TimeStamp":"16/05/2022 14:28:13","BindingTableTableSize":0,"Status":"Success"}
SWBUILD_1 : "20190311"
Param : Object {}
OTAClient : Object {"ManufacturerCode":"117c","ImageType":"1187","CurrentImageVersion":"22007631"}
Epv2 : Object {"01":{"ClusterIn":{"1000":{},"0000":{},"0001":{},"0003":{},"0004":{},"0005":{},"0020":{},"0102":{},"fc7c":{}},"ClusterOut":{"1000":{},"0019":{}},"ProfileID":"0104","ZDeviceID":"0202"}}
Bind : Object {"01":{"0000":{"Target":"0000","Stamp":"16/05/2022 14:27:44","Phase":"binded","Status":"00","i_sqn":"03"},"0001":{"Target":"0000","Stamp":"16/05/2022 14:27:44","Phase":"binded","Status":"00","i_sqn":"04"},"0019":{"Target":"0000","Stamp":"16/05/2022 14:27:45","Phase":"binded","Status":"00","i_sqn":"05"},"0102":{"Target":"0000","Stamp":"16/05/2022 14:27:45","Phase":"binded","Status":"00","i_sqn":"06"}}}
ConsistencyCheck : "ok"
NwkID : "cf1b"
pipiche
Re: Ikea zigbee blind
Post by pipiche »
could you remind me/us the context
1/ pairing the remote with the Controller
2/ pairing Ikea blinds with Controller
and then what are the next steps ?
Could you kindly provides an export.json of "List of Plugin Devices RAW"
gorstj
Post by gorstj »
Thanks for looking
The blind is directly paired with the controller (Sonoff USB stick). The buttons in Domoticz for open/close work perfectly without fail. Using the % slider does nothing.
I haven't tried using the included remote yet (no need to in my setup)
Here is the Plugin Devices RAW
Version : "3"
Status : "inDB"
SQN : "57"
Heartbeat : "464"
RIA : "1"
LQI : 0
Battery : Object {}
MacCapa : "80"
ProfileID : "0104"
ZDeviceID : "0202"
App Version : "34"
DeviceType : "RFD"
HW Version : "1"
NbEp : "1"
ReceiveOnIdle : ""
Stamp : Object {"time":1653162509.131369,"Time":"2022-05-21 20:48:29","MsgType":"8011","LastSeen":"21/05/2022 20:48:29"}
ZCL Version : "3"
Health : "Live"
Param : Object {}
CheckParam : false
ZCLSQN : "06"
NwkID : "cf1b"
pipiche
Post by pipiche »
Ok. there might be a bug in the plugin.
can you get the latest beta6 ( beta6-6.2.052 ) and redo the test.
If it is still not working, could you enable the following debug parameters and drop me the log file ( Logs/ZigbeePlugin-xx.log )
debugCommand
debugzclCommand
debugzigateCommand
gorstj
Post by gorstj »
Just updated to 6.2.052 with no difference
Here is the log with the debugs enabled.
Last few requests were close, open and set to 47%
Just remembered that when I was previously trying to use the blind, the % status was reported in the Domoticz log repeatedly when the blind was in motion (e.g. when moved with the physical buttons on the blind). This doesn't happen anymore.
Another (small) anomaly is that if an open or close command is sent when the blind it moving then it just stops (expected/desired behavior would be for it to move to the open/close position of the last command)
2022-05-22 08:26:32,669 DEBUG   : [       MainThread] mgtCommand (cf1b) Devices[37].Name: Garden Blind Command: Off Level: 100 Color:
2022-05-22 08:26:32,669 DEBUG   : [       MainThread] --------->   DeviceType: ('BlindInverted', 'WindowCovering')
2022-05-22 08:26:32,669 DEBUG   : [       MainThread] --------->1   ClusterType founds: [('01', '2429', 'WindowCovering')] for Unit: 37
2022-05-22 08:26:32,670 DEBUG   : [       MainThread] --------->2   EPOut: 01 DeviceType: WindowCovering WidgetID: 2429
2022-05-22 08:26:32,670 DEBUG   : [       MainThread] --------->3   forceUpdateDev: False
2022-05-22 08:26:32,670 DEBUG   : [       MainThread] --------->4   Ready to action
2022-05-22 08:26:32,671 DEBUG   : [       MainThread] --------->5   profalux: False
2022-05-22 08:26:32,671 DEBUG   : [       MainThread] --------->6   Model Name: FYRTUR block-out roller blind
2022-05-22 08:26:32,671 DEBUG   : [       MainThread] --------->7   Health: Live
2022-05-22 08:26:32,671 DEBUG   : [       MainThread] mgtCommand : Off for Device: cf1b EPout: 01 Unit: 37 DeviceType: WindowCovering modelName: FYRTUR block-out roller blind
2022-05-22 08:26:32,672 DEBUG   : [       MainThread] zcl_window_covering_off cf1b 01
2022-05-22 08:26:32,672 DEBUG   : [       MainThread] zcl_raw_window_covering cf1b 01 Down 00 00
2022-05-22 08:26:33,717 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8011,  Data: 00cf1b, LQI: 60
2022-05-22 08:26:41,176 DEBUG   : [       MainThread] mgtCommand (cf1b) Devices[37].Name: Garden Blind Command: On Level: 0 Color:
2022-05-22 08:26:41,176 DEBUG   : [       MainThread] --------->   DeviceType: ('BlindInverted', 'WindowCovering')
2022-05-22 08:26:41,177 DEBUG   : [       MainThread] --------->1   ClusterType founds: [('01', '2429', 'WindowCovering')] for Unit: 37
2022-05-22 08:26:41,177 DEBUG   : [       MainThread] --------->2   EPOut: 01 DeviceType: WindowCovering WidgetID: 2429
2022-05-22 08:26:41,178 DEBUG   : [       MainThread] --------->3   forceUpdateDev: False
2022-05-22 08:26:41,178 DEBUG   : [       MainThread] --------->4   Ready to action
2022-05-22 08:26:41,178 DEBUG   : [       MainThread] --------->5   profalux: False
2022-05-22 08:26:41,179 DEBUG   : [       MainThread] --------->6   Model Name: FYRTUR block-out roller blind
2022-05-22 08:26:41,179 DEBUG   : [       MainThread] --------->7   Health: Live
2022-05-22 08:26:41,179 DEBUG   : [       MainThread] mgtCommand : On for Device: cf1b EPout: 01 Unit: 37 DeviceType: WindowCovering ModelName: FYRTUR block-out roller blind
2022-05-22 08:26:41,180 DEBUG   : [       MainThread] zcl_window_covering_on cf1b 01
2022-05-22 08:26:41,180 DEBUG   : [       MainThread] zcl_raw_window_covering cf1b 01 Up 00 00
2022-05-22 08:26:42,048 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8011,  Data: 00cf1b, LQI: 60
2022-05-22 08:26:45,508 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 0001040006010102fd42020000087b0a00001000, LQI: 63
2022-05-22 08:26:45,509 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response fd42 01 01 0006 7b for command 0a with Status: 00, Manufcode: None, OrigFCF: 08
2022-05-22 08:26:45,509 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response ==== payload: 107b0b0a00
2022-05-22 08:26:45,510 DEBUG   : [ZigpyForwarder_12] Decode8102 - Attribute Reports: [fd42:01] MsgSQN: 7b ClusterID: 0006 AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >00<
2022-05-22 08:26:45,511 DEBUG   : [ZigpyForwarder_12] scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [fd42:01] ClusterID: 0006 MsgSQN: 7b, i_sqn: 7b, AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >00<
2022-05-22 08:26:45,512 DEBUG   : [ZigpyForwarder_12] Decode8102 - LQI:  63 Received Cluster:0006 Attribute: 0000 Value:   00 from (fd42/01)
2022-05-22 08:26:45,682 DEBUG   : [       MainThread] mgtCommand (cf1b) Devices[37].Name: Garden Blind Command: Set Level Level: 47 Color:
2022-05-22 08:26:45,682 DEBUG   : [       MainThread] --------->   DeviceType: ('BlindInverted', 'WindowCovering')
2022-05-22 08:26:45,683 DEBUG   : [       MainThread] --------->1   ClusterType founds: [('01', '2429', 'WindowCovering')] for Unit: 37
2022-05-22 08:26:45,683 DEBUG   : [       MainThread] --------->2   EPOut: 01 DeviceType: WindowCovering WidgetID: 2429
2022-05-22 08:26:45,683 DEBUG   : [       MainThread] --------->3   forceUpdateDev: False
2022-05-22 08:26:45,683 DEBUG   : [       MainThread] --------->4   Ready to action
2022-05-22 08:26:45,684 DEBUG   : [       MainThread] --------->5   profalux: False
2022-05-22 08:26:45,684 DEBUG   : [       MainThread] --------->6   Model Name: FYRTUR block-out roller blind
2022-05-22 08:26:45,684 DEBUG   : [       MainThread] --------->7   Health: Live
2022-05-22 08:26:45,684 DEBUG   : [       MainThread] mgtCommand : Set Level for Device: cf1b EPout: 01 Unit: 37 DeviceType: WindowCovering Level: 47
2022-05-22 08:26:45,684 DEBUG   : [       MainThread] WindowCovering - Lift Percentage Command - cf1b/01 Level: 0x2f 47
2022-05-22 08:26:45,685 INFO    : [       MainThread] WindowCovering - Lift Percentage Command - cf1b/01 value: 0x2f 2f
2022-05-22 08:26:45,685 DEBUG   : [       MainThread] zcl_window_coverting_level cf1b 01 2f
2022-05-22 08:26:45,685 DEBUG   : [       MainThread] zcl_raw_window_covering cf1b 01 GoToLiftPercentage 00 2f
2022-05-22 08:26:45,982 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 0001040102010102cf1b02000008080b0580, LQI: 60
2022-05-22 08:26:45,984 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response cf1b 01 01 0102 08 for command 0b with Status: 00, Manufcode: None, OrigFCF: 08
2022-05-22 08:26:45,985 DEBUG   : [ZigpyForwarder_12] Reception Data indication, Source Address: cf1b Destination Address: 0000 ProfilID: 0104 ClusterID: 0102 Message Payload: 08080b0580
2022-05-22 08:26:45,985 INFO    : [ZigpyForwarder_12] Unknown Window Covering Command: 0b
2022-05-22 08:26:45,985 INFO    : [ZigpyForwarder_12] inRawAps cf1b/01 Cluster 0102 Manuf: 117c/IKEA of Sweden Command: 0b Data: 0580 Payload: 08080b0580 not processed !!!
2022-05-22 08:26:46,232 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8011,  Data: 00cf1b, LQI: 60
2022-05-22 08:26:53,191 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 000104001901010266cb0200000173010029100c1115160420, LQI: 27
2022-05-22 08:26:53,191 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response 66cb 01 01 0019 73 for command 01 with Status: 00, Manufcode: None, OrigFCF: 01
2022-05-22 08:26:53,191 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response ==== payload: 18730b0100
2022-05-22 08:26:53,192 DEBUG   : [ZigpyForwarder_12] Reception Data indication, Source Address: 66cb Destination Address: 0000 ProfilID: 0104 ClusterID: 0019 Message Payload: 0173010029100c1115160420
2022-05-22 08:26:54,070 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8011,  Data: 0066cb, LQI: 27
2022-05-22 08:27:02,521 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 0001040019010102287d02000001df010029100c1115160420, LQI: 63
2022-05-22 08:27:02,522 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response 287d 01 01 0019 df for command 01 with Status: 00, Manufcode: None, OrigFCF: 01
2022-05-22 08:27:02,522 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response ==== payload: 18df0b0100
2022-05-22 08:27:02,523 DEBUG   : [ZigpyForwarder_12] Reception Data indication, Source Address: 287d Destination Address: 0000 ProfilID: 0104 ClusterID: 0019 Message Payload: 01df010029100c1115160420
2022-05-22 08:27:03,376 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8011,  Data: 00287d, LQI: 63
2022-05-22 08:27:54,641 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 000104001901010266cb020000017e010029100c1115160420, LQI: 27
2022-05-22 08:27:54,642 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response 66cb 01 01 0019 7e for command 01 with Status: 00, Manufcode: None, OrigFCF: 01
2022-05-22 08:27:54,642 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response ==== payload: 187e0b0100
2022-05-22 08:27:54,643 DEBUG   : [ZigpyForwarder_12] Reception Data indication, Source Address: 66cb Destination Address: 0000 ProfilID: 0104 ClusterID: 0019 Message Payload: 017e010029100c1115160420
2022-05-22 08:27:55,523 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8011,  Data: 0066cb, LQI: 27
pipiche
Post by pipiche »
can you kindly swiotch to pipiche38/fix/windowscovering
git pull
git checkout pipiche38/fix/windowscovering
then restart the plugin
enable debugzclDecoder
then redo the tests and send me the logs
I'll try later to setup an envirnment here , but don't have any blind.
gorstj
Post by gorstj »
Thanks for looking at this. Just done that.
Here is the log output since the restart including a open/close/set to % event
2022-05-22 10:35:59,758 INFO    : [       MainThread] onDisconnect - Closing Name: 'Zigate Server Connection', Transport: 'TCP/IP', Protocol: 'HTTP', Address: '', Port: '9440', Baud: -1, Timeout: 0, Connected: False, Parent: 'None'
2022-05-22 10:35:59,759 INFO    : [       MainThread] onStop called
2022-05-22 10:35:59,759 INFO    : [       MainThread] onStop calling (1) domoticzDb DeviceStatus closed
2022-05-22 10:35:59,759 INFO    : [       MainThread] onStop calling (2) domoticzDb Hardware closed
2022-05-22 10:35:59,759 INFO    : [       MainThread] onStop calling (3) Transport off
2022-05-22 10:35:59,759 INFO    : [       MainThread] Shuting down co-routine
2022-05-22 10:35:59,760 INFO    : [ZigpyForwarder_12] ZigpyTransport: thread_processing_and_sending Thread stop.
2022-05-22 10:36:01,818 INFO    : [       MainThread] onStop calling (4) WebServer off
2022-05-22 10:36:01,818 INFO    : [       MainThread] onStop called (4) WebServer off
2022-05-22 10:36:01,819 INFO    : [       MainThread] onStop calling (5) Plugin Database saved
2022-05-22 10:36:01,830 INFO    : [       MainThread] onStop called (5) Plugin Database saved
2022-05-22 10:36:01,830 INFO    : [       MainThread] onStop calling (6) Close Logging Management
2022-05-22 10:36:03,117 INFO    : [       MainThread] Zigate plugin beta6-6.2.052 started
2022-05-22 10:36:03,124 INFO    : [       MainThread] Plugin Database: DeviceList-12.txt
2022-05-22 10:36:03,127 INFO    : [       MainThread] DeviceConf loaded - 22 confs loaded
2022-05-22 10:36:03,205 INFO    : [       MainThread] DeviceConf loaded - 345 confs loaded
2022-05-22 10:36:03,206 INFO    : [       MainThread] load ListOfDevice
2022-05-22 10:36:03,397 INFO    : [       MainThread] 44 Entries loaded from /home/john/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-12.txt
2022-05-22 10:36:03,423 INFO    : [       MainThread] Transport mode: ZigpyZNP
2022-05-22 10:36:04,123 DEBUG   :Using selector: EpollSelector
2022-05-22 10:36:04,127 INFO    : [ZigpyForwarder_12] ZigpyTransport: thread_processing_and_sending Thread start.
2022-05-22 10:36:04,131 INFO    : [       MainThread] Start Web Server connection
2022-05-22 10:36:04,132 INFO    : [       MainThread] Web backend for Web User Interface started on port: 9440
2022-05-22 10:36:08,920 INFO    :ZNP is already configured, not forming a new network
2022-05-22 10:36:12,367 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 00000000020000020000020000010000, LQI: 0
2022-05-22 10:36:12,367 DEBUG   : [ZigpyForwarder_12] Decode0042 - Node_Desc_req: 010000000000
2022-05-22 10:36:12,367 DEBUG   : [ZigpyForwarder_12] Decode0042 - response payload: 01890000
2022-05-22 10:36:12,390 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 000000800200000200000200000100000000408f000050a000012ca00000, LQI: 0
2022-05-22 10:36:12,390 DEBUG   : [ZigpyForwarder_12] Decode8042 - Reception Node Descriptor for: 0000 SEQ: 01 Status: 00 manufacturer:0000 mac_capability: 8f bit_field: 4000
2022-05-22 10:36:12,390 DEBUG   : [ZigpyForwarder_12] Decode8042 - Alternate PAN Coordinator = 1
2022-05-22 10:36:12,390 DEBUG   : [ZigpyForwarder_12] Decode8042 - Receiver on Idle = On
2022-05-22 10:36:12,390 DEBUG   : [ZigpyForwarder_12] Decode8042 - Power Source = Main
2022-05-22 10:36:12,391 DEBUG   : [ZigpyForwarder_12] Decode8042 - Device type  = FFD
2022-05-22 10:36:12,391 DEBUG   : [ZigpyForwarder_12] Decode8042 - bit_fieldL  = 0 bit_fieldH = 64
2022-05-22 10:36:12,391 DEBUG   : [ZigpyForwarder_12] Decode8042 - bit_field = 0: 64
2022-05-22 10:36:12,391 DEBUG   : [ZigpyForwarder_12] Decode8042 - Logical Type = Coordinator
2022-05-22 10:36:12,391 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 00000000050000020000020000020000, LQI: 0
2022-05-22 10:36:12,391 DEBUG   : [ZigpyForwarder_12] Reception Data indication, Source Address: 0000 Destination Address: 0000 ProfilID: 0000 ClusterID: 0005 Message Payload: 020000
2022-05-22 10:36:12,409 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 0000008005000002000002000002000000080308156e0a0b0201, LQI: 0
2022-05-22 10:36:12,410 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 0000000004000002000002000003000003, LQI: 0
2022-05-22 10:36:12,410 DEBUG   : [ZigpyForwarder_12] Reception Data indication, Source Address: 0000 Destination Address: 0000 ProfilID: 0000 ClusterID: 0004 Message Payload: 03000003
2022-05-22 10:36:12,429 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 00000080040000020000020000030000000a03040120080001000000, LQI: 0
2022-05-22 10:36:12,429 DEBUG   : [ZigpyForwarder_12] Decode8043 - Received SQN: 03 Addr: 0000 Len: 0a Status: 00 Data: 030000000a03010408200001000000
2022-05-22 10:36:12,430 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 0000000004000002000002000004000008, LQI: 0
2022-05-22 10:36:12,430 DEBUG   : [ZigpyForwarder_12] Reception Data indication, Source Address: 0000 Destination Address: 0000 ProfilID: 0000 ClusterID: 0004 Message Payload: 04000008
2022-05-22 10:36:12,450 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 00000080040000020000020000040000000a08040120080001000000, LQI: 0
2022-05-22 10:36:12,451 DEBUG   : [ZigpyForwarder_12] Decode8043 - Received SQN: 04 Addr: 0000 Len: 0a Status: 00 Data: 040000000a08010408200001000000
2022-05-22 10:36:12,451 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 0000000004000002000002000005000015, LQI: 0
2022-05-22 10:36:12,451 DEBUG   : [ZigpyForwarder_12] Reception Data indication, Source Address: 0000 Destination Address: 0000 ProfilID: 0000 ClusterID: 0004 Message Payload: 05000015
2022-05-22 10:36:12,472 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 00000080040000020000020000050000000a15040120080001000000, LQI: 0
2022-05-22 10:36:12,473 DEBUG   : [ZigpyForwarder_12] Decode8043 - Received SQN: 05 Addr: 0000 Len: 0a Status: 00 Data: 050000000a15010408200001000000
2022-05-22 10:36:12,473 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 000000000400000200000200000600006e, LQI: 0
2022-05-22 10:36:12,473 DEBUG   : [ZigpyForwarder_12] Reception Data indication, Source Address: 0000 Destination Address: 0000 ProfilID: 0000 ClusterID: 0004 Message Payload: 0600006e
2022-05-22 10:36:12,492 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 00000080040000020000020000060000000a6e040120080001000000, LQI: 0
2022-05-22 10:36:12,493 DEBUG   : [ZigpyForwarder_12] Decode8043 - Received SQN: 06 Addr: 0000 Len: 0a Status: 00 Data: 060000000a6e010408200001000000
2022-05-22 10:36:12,493 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 000000000400000200000200000700000a, LQI: 0
2022-05-22 10:36:12,494 DEBUG   : [ZigpyForwarder_12] Reception Data indication, Source Address: 0000 Destination Address: 0000 ProfilID: 0000 ClusterID: 0004 Message Payload: 0700000a
2022-05-22 10:36:12,511 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 00000080040000020000020000070000000a0a040120080001000000, LQI: 0
2022-05-22 10:36:12,512 DEBUG   : [ZigpyForwarder_12] Decode8043 - Received SQN: 07 Addr: 0000 Len: 0a Status: 00 Data: 070000000a0a010408200001000000
2022-05-22 10:36:12,512 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 000000000400000200000200000800000b, LQI: 0
2022-05-22 10:36:12,512 DEBUG   : [ZigpyForwarder_12] Reception Data indication, Source Address: 0000 Destination Address: 0000 ProfilID: 0000 ClusterID: 0004 Message Payload: 0800000b
2022-05-22 10:36:12,532 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 00000080040000020000020000080000000a0b040120080001000000, LQI: 0
2022-05-22 10:36:12,532 DEBUG   : [ZigpyForwarder_12] Decode8043 - Received SQN: 08 Addr: 0000 Len: 0a Status: 00 Data: 080000000a0b010408200001000000
2022-05-22 10:36:12,533 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 0000000004000002000002000009000002, LQI: 0
2022-05-22 10:36:12,533 DEBUG   : [ZigpyForwarder_12] Reception Data indication, Source Address: 0000 Destination Address: 0000 ProfilID: 0000 ClusterID: 0004 Message Payload: 09000002
2022-05-22 10:36:12,550 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 00000080040000020000020000090000000a025ec020080001000000, LQI: 0
2022-05-22 10:36:12,552 DEBUG   : [ZigpyForwarder_12] Decode8043 - Received SQN: 09 Addr: 0000 Len: 0a Status: 00 Data: 090000000a02c05e08200001000000
2022-05-22 10:36:12,553 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 000000000400000200000200000a000001, LQI: 0
2022-05-22 10:36:12,553 DEBUG   : [ZigpyForwarder_12] Reception Data indication, Source Address: 0000 Destination Address: 0000 ProfilID: 0000 ClusterID: 0004 Message Payload: 0a000001
2022-05-22 10:36:12,566 INFO    :Network settings
2022-05-22 10:36:12,567 INFO    :  Model: CC1352/CC2652, Z-Stack 3.30+ (build 20210708)
2022-05-22 10:36:12,567 INFO    :  Z-Stack version: 3.3
2022-05-22 10:36:12,568 INFO    :  Z-Stack build id: 20210708
2022-05-22 10:36:12,568 INFO    :  Max concurrent requests: 2
2022-05-22 10:36:12,568 INFO    :  Channel: 19
2022-05-22 10:36:12,568 INFO    :  PAN ID: 0x15FE
2022-05-22 10:36:12,569 INFO    :  Extended PAN ID: f5:93:58:65:5e:08:58:61
2022-05-22 10:36:12,569 INFO    :  Device IEEE: 00:12:4b:00:24:bc:49:26
2022-05-22 10:36:12,569 INFO    :  Device NWK: 0x0000
2022-05-22 10:36:12,569 DEBUG   :  Network key: 66:b3:a7:cc:5b:d0:73:36:25:32:19:5d:07:dd:bb:32
2022-05-22 10:36:12,571 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 000000800400000200000200000a0000001001040100040002000019000200050205, LQI: 0
2022-05-22 10:36:12,571 DEBUG   : [ZigpyForwarder_12] Decode8043 - Received SQN: 0a Addr: 0000 Len: 10 Status: 00 Data: 0a0000001001010404000002000000190205000502
2022-05-22 10:36:13,079 DEBUG   : [       MainThread] zigate_get_firmware_version
2022-05-22 10:36:22,491 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8015,  Data: 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, LQI: 0
2022-05-22 10:36:22,492 INFO    : [ZigpyForwarder_12] Number of devices recently active in Zigate = 28
2022-05-22 10:36:22,493 INFO    : [ZigpyForwarder_12] [00] DevID: 00 Network addr: 66cb IEEE: 00158d0001271c1e LQI: 000 power: ff Model: ICZB-FC ( Hall )
2022-05-22 10:36:22,493 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for 66cb
2022-05-22 10:36:22,493 INFO    : [ZigpyForwarder_12] [01] DevID: 00 Network addr: 4a57 IEEE: 086bd7fffe5ea8fd LQI: 000 power: ff Model: Dimmer-Switch-ZB3.0 ( Garden room outside )
2022-05-22 10:36:22,493 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for 4a57
2022-05-22 10:36:22,494 INFO    : [ZigpyForwarder_12] [02] DevID: 00 Network addr: 713f IEEE: 086bd7fffe5d2cbe LQI: 000 power: ff Model: Dimmer-Switch-ZB3.0 ( Olivia's main dimmer )
2022-05-22 10:36:22,494 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for 713f
2022-05-22 10:36:22,494 INFO    : [ZigpyForwarder_12] [03] DevID: 00 Network addr: 287d IEEE: 00158d00012f55c6 LQI: 000 power: ff Model: ICZB-FC ( Olivia's lamp )
2022-05-22 10:36:22,494 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for 287d
2022-05-22 10:36:22,495 INFO    : [ZigpyForwarder_12] [04] DevID: 00 Network addr: 6e8a IEEE: 086bd7fffe5dfe7c LQI: 000 power: ff Model: Dimmer-Switch-ZB3.0 ( Emma's main dimmer )
2022-05-22 10:36:22,495 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for 6e8a
2022-05-22 10:36:22,495 INFO    : [ZigpyForwarder_12] [05] DevID: 00 Network addr: 0e03 IEEE: 0c4314fffe2536bc LQI: 000 power: ff Model: Dimmer-Switch-ZB3.0 ( Guest Bedroom )
2022-05-22 10:36:22,496 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for 0e03
2022-05-22 10:36:22,496 INFO    : [ZigpyForwarder_12] [06] DevID: 00 Network addr: 5076 IEEE: 680ae2fffe3af5bf LQI: 000 power: ff Model: TRADFRI control outlet ( Tradfri repeater )
2022-05-22 10:36:22,496 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for 5076
2022-05-22 10:36:22,496 INFO    : [ZigpyForwarder_12] [07] DevID: 00 Network addr: 5250 IEEE: 804b50fffee0ef90 LQI: 000 power: ff Model: TS0043 ( Emmas button )
2022-05-22 10:36:22,497 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for 5250
2022-05-22 10:36:22,497 INFO    : [ZigpyForwarder_12] [08] DevID: 00 Network addr: 91bf IEEE: 847127fffe13bacd LQI: 000 power: ff Model: TS0043 ( Olivias Button )
2022-05-22 10:36:22,497 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for 91bf
2022-05-22 10:36:22,498 INFO    : [ZigpyForwarder_12] [09] DevID: 00 Network addr: 7367 IEEE: 842e14fffe504132 LQI: 000 power: ff Model: TS011F ( Rabbit outdoor lights )
2022-05-22 10:36:22,498 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for 7367
2022-05-22 10:36:22,498 INFO    : [ZigpyForwarder_12] [10] DevID: 00 Network addr: cf50 IEEE: 086bd7fffe5cdbfc LQI: 000 power: ff Model: Dimmer-Switch-ZB3.0 ( Bar light )
2022-05-22 10:36:22,498 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for cf50
2022-05-22 10:36:22,498 INFO    : [ZigpyForwarder_12] [11] DevID: 00 Network addr: 4fec IEEE: 086bd7fffe5d3254 LQI: 000 power: ff Model: Dimmer-Switch-ZB3.0 ( Theatre light )
2022-05-22 10:36:22,504 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for 4fec
2022-05-22 10:36:22,504 INFO    : [ZigpyForwarder_12] [12] DevID: 00 Network addr: 9e69 IEEE: 84fd27fffe697391 LQI: 000 power: ff Model: ZB-DoorSensor-D0003 ( Spare door sensor )
2022-05-22 10:36:22,505 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for 9e69
2022-05-22 10:36:22,505 INFO    : [ZigpyForwarder_12] [13] DevID: 00 Network addr: 3840 IEEE: 60a423fffefc9492 LQI: 000 power: ff Model: TS004F-_TZ3000_xabckq1v ( TS004F scene )
2022-05-22 10:36:22,505 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for 3840
2022-05-22 10:36:22,505 INFO    : [ZigpyForwarder_12] [14] DevID: 00 Network addr: 7d99 IEEE: a4c1380046452ee8 LQI: 000 power: ff not found in plugin database!
2022-05-22 10:36:22,505 INFO    : [ZigpyForwarder_12] [15] DevID: 00 Network addr: 21c9 IEEE: 7cb03eaa00ab751e LQI: 000 power: ff Model:  ( Rabbit heater )
2022-05-22 10:36:22,505 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for 21c9
2022-05-22 10:36:22,505 INFO    : [ZigpyForwarder_12] [16] DevID: 00 Network addr: deed IEEE: 086bd7fffe5d803e LQI: 000 power: ff Model: Dimmer-Switch-ZB3.0 ( Theatre Corner )
2022-05-22 10:36:22,506 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for deed
2022-05-22 10:36:22,506 INFO    : [ZigpyForwarder_12] [17] DevID: 00 Network addr: 1bd9 IEEE: a4c1387500a8bc02 LQI: 000 power: ff Model: TS0202 ( GardenRoom Motion )
2022-05-22 10:36:22,506 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for 1bd9
2022-05-22 10:36:22,506 INFO    : [ZigpyForwarder_12] [18] DevID: 00 Network addr: a2a1 IEEE: 00124b0022422a3e LQI: 000 power: ff Model: WB01 ( Sonoff Button )
2022-05-22 10:36:22,506 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for a2a1
2022-05-22 10:36:22,506 INFO    : [ZigpyForwarder_12] [19] DevID: 00 Network addr: fd42 IEEE: 0c4314fffe235c9d LQI: 000 power: ff Model: Dimmer-Switch-ZB3.0 ( Bedroom )
2022-05-22 10:36:22,506 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for fd42
2022-05-22 10:36:22,506 INFO    : [ZigpyForwarder_12] [20] DevID: 00 Network addr: 1147 IEEE: 842e14fffecd0792 LQI: 000 power: ff Model: TS011F ( Plug1 )
2022-05-22 10:36:22,507 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for 1147
2022-05-22 10:36:22,507 INFO    : [ZigpyForwarder_12] [21] DevID: 00 Network addr: 80a0 IEEE: 84fd27fffe69734a LQI: 000 power: ff Model: ZB-DoorSensor-D0003 ( Linkind sensor )
2022-05-22 10:36:22,507 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for 80a0
2022-05-22 10:36:22,507 INFO    : [ZigpyForwarder_12] [22] DevID: 00 Network addr: dc7c IEEE: ec1bbdfffefd474d LQI: 000 power: ff Model: TS011F ( Plug3 )
2022-05-22 10:36:22,507 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for dc7c
2022-05-22 10:36:22,507 INFO    : [ZigpyForwarder_12] [23] DevID: 00 Network addr: ded0 IEEE: 00124b00239e5c8a LQI: 000 power: ff Model: DS01 ( Bifold sensor )
2022-05-22 10:36:22,507 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for ded0
2022-05-22 10:36:22,507 INFO    : [ZigpyForwarder_12] [24] DevID: 00 Network addr: 7712 IEEE: 00124b001c4b1fc5 LQI: 000 power: ff Model: TH01 ( Hutch thermometer )
2022-05-22 10:36:22,508 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for 7712
2022-05-22 10:36:22,508 INFO    : [ZigpyForwarder_12] [25] DevID: 00 Network addr: cf1b IEEE: 000d6ffffea05be2 LQI: 000 power: ff Model: FYRTUR block-out roller blind ( Garden Blind )
2022-05-22 10:36:22,508 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for cf1b
2022-05-22 10:36:22,508 INFO    : [ZigpyForwarder_12] [26] DevID: 00 Network addr: 5efd IEEE: 000d6ffffe2766fa LQI: 000 power: ff Model: TRADFRI signal repeater ( Repeater Ikea )
2022-05-22 10:36:22,508 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for 5efd
2022-05-22 10:36:22,508 INFO    : [ZigpyForwarder_12] [27] DevID: 00 Network addr: 64c0 IEEE: 84fd27fffe803ac1 LQI: 000 power: ff Model: TS004F-_TZ3000_xabckq1v ( Olivas wall scene )
2022-05-22 10:36:22,508 DEBUG   : [ZigpyForwarder_12] Decode8015: LQI set to 0 / 0 for 64c0
2022-05-22 10:36:22,508 DEBUG   : [ZigpyForwarder_12] Decode8015 - IEEE2NWK      : {'00158d00029acb80': '6d30', '00124b0024bc4926': '0000', '00158d0003d478eb': 'fee4', '00124b0022655964': '8396', '000d6ffffef03625': 'fc4e', '7cb03eaa0a04df4b': 'b697', '086bd7fffe5dfe7c': '6e8a', '0c4314fffe2536bc': '0e03', '7cb03eaa0a04dc4b': 'b8d1', '804b50fffee0ef90': '5250', '847127fffe13bacd': '91bf', '84fd27fffe69734a': '80a0', '680ae2fffe3af5bf': '5076', '842e14fffe504132': '7367', '7cb03eaa00ab751e': '21c9', '00124b001b7902f4': 'daba', '086bd7fffe5ea8fd': '4a57', '086bd7fffe5cdbfc': 'cf50', '84fd27fffe697391': '9e69', '60a423fffefc9492': '3840', '086bd7fffe5d803e': 'deed', 'a4c1387500a8bc02': '1bd9', '00158d0001271c1e': '66cb', '00124b0022422a3e': 'a2a1', '0c4314fffe235c9d': 'fd42', '7cb03eaa0a078267': 'd5b6', '842e14fffecd0792': '1147', 'ec1bbdfffefd474d': 'dc7c', '086bd7fffe5d2cbe': '713f', '00158d00012f55c6': '287d', '00158d00035038e8': 'f08e', '00158d0003503792': 'fcd7', '00158d00033ed6a6': '9b13', '00158d00031c51f8': '7378', '086bd7fffe5d3254': '4fec', '00158d000396135d': 'af3c', '00124b00226304f0': '399a', '00158d00035038ad': '5479', '00158d000316148c': '258e', '00124b001c4b1fc5': '7712', '00124b00239e5c8a': 'ded0', '000d6ffffea05be2': 'cf1b', '000d6ffffe2766fa': '5efd', '84fd27fffe803ac1': '64c0'}
2022-05-22 10:36:22,509 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8010,  Data: 20210708, LQI: 0
2022-05-22 10:36:22,509 DEBUG   : [ZigpyForwarder_12] Decode8010 - Reception Version list:20210708 len: 8 Branch: 20 Major: 21 Version: 0708
2022-05-22 10:36:22,509 INFO    : [ZigpyForwarder_12] CC1352/CC2652, Z-Stack 3.30+ (znp)
2022-05-22 10:36:22,509 INFO    : [ZigpyForwarder_12] Installer Version Number: 0708
2022-05-22 10:36:22,509 INFO    : [ZigpyForwarder_12] Branch Version: ==> CC1352/CC2652, Z-Stack 3.30+ (znp) <==
2022-05-22 10:36:22,509 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8009,  Data: 000000124b0024bc492615fef59358655e08586113, LQI: 0
2022-05-22 10:36:22,510 DEBUG   : [ZigpyForwarder_12] Decode8009: Network state - Address:0000 extaddr:00124b0024bc4926 PanID: 15fe Channel: 19
2022-05-22 10:36:22,510 INFO    : [ZigpyForwarder_12] Zigbee Coordinator ieee: 00124b0024bc4926 , short addr: 0000
2022-05-22 10:36:22,510 INFO    : [ZigpyForwarder_12] Network state UP, PANID: 15fe extPANID: 0xf59358655e085861 Channel: 19
2022-05-22 10:36:22,510 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8045,  Data: 0000000009000308156e0a0b0201, LQI: 0
2022-05-22 10:36:22,511 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8043,  Data: 000000000103010408200001000000, LQI: 0
2022-05-22 10:36:22,511 DEBUG   : [ZigpyForwarder_12] Decode8043 - Received SQN: 00 Addr: 0000 Len: 01 Status: 00 Data: 000000000103010408200001000000
2022-05-22 10:36:22,511 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8043,  Data: 000000000108010408200001000000, LQI: 0
2022-05-22 10:36:22,511 DEBUG   : [ZigpyForwarder_12] Decode8043 - Received SQN: 00 Addr: 0000 Len: 01 Status: 00 Data: 000000000108010408200001000000
2022-05-22 10:36:22,512 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8043,  Data: 000000000115010408200001000000, LQI: 0
2022-05-22 10:36:22,512 DEBUG   : [ZigpyForwarder_12] Decode8043 - Received SQN: 00 Addr: 0000 Len: 01 Status: 00 Data: 000000000115010408200001000000
2022-05-22 10:36:22,512 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8043,  Data: 00000000016e010408200001000000, LQI: 0
2022-05-22 10:36:22,512 DEBUG   : [ZigpyForwarder_12] Decode8043 - Received SQN: 00 Addr: 0000 Len: 01 Status: 00 Data: 00000000016e010408200001000000
2022-05-22 10:36:22,513 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8043,  Data: 00000000010a010408200001000000, LQI: 0
2022-05-22 10:36:22,513 DEBUG   : [ZigpyForwarder_12] Decode8043 - Received SQN: 00 Addr: 0000 Len: 01 Status: 00 Data: 00000000010a010408200001000000
2022-05-22 10:36:22,513 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8043,  Data: 00000000010b010408200001000000, LQI: 0
2022-05-22 10:36:22,513 DEBUG   : [ZigpyForwarder_12] Decode8043 - Received SQN: 00 Addr: 0000 Len: 01 Status: 00 Data: 00000000010b010408200001000000
2022-05-22 10:36:22,514 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8043,  Data: 000000000102c05e08200001000000, LQI: 0
2022-05-22 10:36:22,514 DEBUG   : [ZigpyForwarder_12] Decode8043 - Received SQN: 00 Addr: 0000 Len: 01 Status: 00 Data: 000000000102c05e08200001000000
2022-05-22 10:36:22,514 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8043,  Data: 000000000101010404000002000000190205000502, LQI: 0
2022-05-22 10:36:22,514 DEBUG   : [ZigpyForwarder_12] Decode8043 - Received SQN: 00 Addr: 0000 Len: 01 Status: 00 Data: 000000000101010404000002000000190205000502
2022-05-22 10:36:22,515 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 0302,  Data: , LQI: 0
2022-05-22 10:36:22,515 DEBUG   : [ZigpyForwarder_12] Decode0302 - PDM Load
2022-05-22 10:36:22,515 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 0000008002000002000002000001890000, LQI: 0
2022-05-22 10:36:22,515 DEBUG   : [ZigpyForwarder_12] Decode8042 - Reception of Node Descriptor for 0000 with status 89
2022-05-22 10:36:22,516 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 0000008002000002000002000001890000, LQI: 0
2022-05-22 10:36:22,517 DEBUG   : [ZigpyForwarder_12] Decode8042 - Reception of Node Descriptor for 0000 with status 89
2022-05-22 10:36:23,897 WARNING :Failed to parse broken GeneralFrame(header=CommandHeader(id=0x9F, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\x97\xB6\x84\x01\x50') as <class 'zigpy_znp.types.commands.ZDO.ParentAnnceRsp.Callback'>
2022-05-22 10:36:23,904 ERROR   :Task exception was never retrieved
future: <Task finished name='Task-3956' coro=<ControllerApplication.on_zdo_message() done, defined at /home/john/domoticz/plugins/Domoticz-Zigate/zigpy_znp/zigbee/application.py:643> exception=ValueError('Data is too short to contain 1 bytes')>
  File "/home/john/domoticz/plugins/Domoticz-Zigate/zigpy_znp/zigbee/application.py", line 651, in on_zdo_message
    args, data = list_deserialize(data, types)
  File "/home/john/domoticz/plugins/Domoticz-Zigate/zigpy/types/__init__.py", line 9, in deserialize
    value, data = type_.deserialize(data)
  File "/home/john/domoticz/plugins/Domoticz-Zigate/zigpy/types/basic.py", line 651, in deserialize
    item, data = cls._item_type.deserialize(data)
  File "/home/john/domoticz/plugins/Domoticz-Zigate/zigpy/types/basic.py", line 677, in deserialize
  File "/home/john/domoticz/plugins/Domoticz-Zigate/zigpy/types/basic.py", line 142, in deserialize
    raise ValueError(f"Data is too short to contain {byte_size} bytes")
ValueError: Data is too short to contain 1 bytes
2022-05-22 10:36:23,951 WARNING :Failed to parse broken GeneralFrame(header=CommandHeader(id=0x9F, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\xC9\x21\x84\x01\x50') as <class 'zigpy_znp.types.commands.ZDO.ParentAnnceRsp.Callback'>
2022-05-22 10:36:23,953 ERROR   :Task exception was never retrieved
future: <Task finished name='Task-3959' coro=<ControllerApplication.on_zdo_message() done, defined at /home/john/domoticz/plugins/Domoticz-Zigate/zigpy_znp/zigbee/application.py:643> exception=ValueError('Data is too short to contain 1 bytes')>
2022-05-22 10:36:28,066 INFO    : [       MainThread] Request Disabling Accepting new Hardware
2022-05-22 10:36:28,066 DEBUG   : [       MainThread] zigate_get_permit_joint_status
2022-05-22 10:36:28,149 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8014,  Data: 00, LQI: 0
2022-05-22 10:36:28,149 DEBUG   : [ZigpyForwarder_12] Decode8014 - Permit Join status: False
2022-05-22 10:36:28,149 INFO    : [ZigpyForwarder_12] Accepting new Hardware: Disable (Off)
2022-05-22 10:36:28,150 DEBUG   : [ZigpyForwarder_12] ---> self.permitTojoin['Starttime']: 1653212188
2022-05-22 10:36:28,150 DEBUG   : [ZigpyForwarder_12] ---> self.permitTojoin['Duration']: 0
2022-05-22 10:36:28,150 DEBUG   : [ZigpyForwarder_12] ---> Current time                  : 1653212188
2022-05-22 10:36:28,151 DEBUG   : [ZigpyForwarder_12] ---> self.Ping['Permit']  (prev)   : None
2022-05-22 10:36:28,151 DEBUG   : [ZigpyForwarder_12] ---> self.Ping['Permit']  (new )   : Off
2022-05-22 10:36:28,151 DEBUG   : [ZigpyForwarder_12] ---> _to_notify                    : True
2022-05-22 10:36:28,151 DEBUG   : [ZigpyForwarder_12] Ping - received
2022-05-22 10:36:28,164 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8014,  Data: 00, LQI: 0
2022-05-22 10:36:28,164 DEBUG   : [ZigpyForwarder_12] Decode8014 - Permit Join status: False
2022-05-22 10:36:28,165 DEBUG   : [ZigpyForwarder_12] ---> self.permitTojoin['Starttime']: 1653212188
2022-05-22 10:36:28,165 DEBUG   : [ZigpyForwarder_12] ---> self.permitTojoin['Duration']: 0
2022-05-22 10:36:28,165 DEBUG   : [ZigpyForwarder_12] ---> Current time                  : 1653212188
2022-05-22 10:36:28,165 DEBUG   : [ZigpyForwarder_12] ---> self.Ping['Permit']  (prev)   : Off
2022-05-22 10:36:28,165 DEBUG   : [ZigpyForwarder_12] ---> self.Ping['Permit']  (new )   : Off
2022-05-22 10:36:28,166 DEBUG   : [ZigpyForwarder_12] ---> _to_notify                    : True
2022-05-22 10:36:28,166 DEBUG   : [ZigpyForwarder_12] Ping - received
2022-05-22 10:36:28,311 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 0001040019010102287d020000015f010029100c1115160420, LQI: 60
2022-05-22 10:36:28,311 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response 287d 01 01 0019 5f for command 01 with Status: 00, Manufcode: None, OrigFCF: 01
2022-05-22 10:36:28,311 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response ==== payload: 185f0b0100
2022-05-22 10:36:28,312 DEBUG   : [ZigpyForwarder_12] Reception Data indication, Source Address: 287d Destination Address: 0000 ProfilID: 0104 ClusterID: 0019 Message Payload: 015f010029100c1115160420
2022-05-22 10:36:33,101 INFO    : [       MainThread] Switch Blue Led On
2022-05-22 10:36:33,102 DEBUG   : [       MainThread] zigate_blueled 01
2022-05-22 10:36:33,102 INFO    : [       MainThread] Zigate set to Certification : 1/CE -> CE
2022-05-22 10:36:33,103 DEBUG   : [       MainThread] zigate_set_certificate 01
2022-05-22 10:36:33,103 DEBUG   : [       MainThread] zigate_set_certificate value: CE
2022-05-22 10:36:33,103 INFO    : [       MainThread] Start Group Management
2022-05-22 10:36:33,106 INFO    : [       MainThread] Plugin with Zigpy, Coordinator CC1352/CC2652, Z-Stack 3.30+ (znp) firmware Znp - (....0708) correctly initialized
2022-05-22 10:36:38,373 DEBUG   : [       MainThread] read_attribute b8d1 01 03 0000 00 00 0000 01 0000
2022-05-22 10:36:38,381 DEBUG   : [       MainThread] rawaps_read_attribute_req b8d1 01 03 0000 00 00 0000 0000
2022-05-22 10:36:38,391 DEBUG   : [       MainThread] zcl_write_attribute 3840 01 01 0006 0000 00 8004 30 01
2022-05-22 10:36:38,397 DEBUG   : [       MainThread] rawaps_write_attribute_req 3840 01 01 0006 0000 00 8004 30 01
2022-05-22 10:36:38,398 DEBUG   : [       MainThread] rawaps_write_attribute_req ==== payload: 10000204803001
2022-05-22 10:36:38,401 DEBUG   : [       MainThread] zcl_write_attribute 64c0 01 01 0006 0000 00 8004 30 01
2022-05-22 10:36:38,401 DEBUG   : [       MainThread] rawaps_write_attribute_req 64c0 01 01 0006 0000 00 8004 30 01
2022-05-22 10:36:38,401 DEBUG   : [       MainThread] rawaps_write_attribute_req ==== payload: 10000204803001
2022-05-22 10:36:45,485 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8011,  Data: b6b8d1, LQI: 0
2022-05-22 10:36:45,486 INFO    : [ZigpyForwarder_12] timeout_widget unit Ray's Lamp -> True from 0:Off
2022-05-22 10:36:45,492 INFO    : [ZigpyForwarder_12] Receive NACK from Ray's Lamp (b8d1) clusterId:  Status: b6
2022-05-22 10:36:46,319 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 0001040019010102287d0200000160010029100c1115160420, LQI: 60
2022-05-22 10:36:46,320 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response 287d 01 01 0019 60 for command 01 with Status: 00, Manufcode: None, OrigFCF: 01
2022-05-22 10:36:46,321 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response ==== payload: 18600b0100
2022-05-22 10:36:46,321 DEBUG   : [ZigpyForwarder_12] Reception Data indication, Source Address: 287d Destination Address: 0000 ProfilID: 0104 ClusterID: 0019 Message Payload: 0160010029100c1115160420
2022-05-22 10:36:54,108 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 000104001901010266cb0200000182010029100c1115160420, LQI: 60
2022-05-22 10:36:54,108 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response 66cb 01 01 0019 82 for command 01 with Status: 00, Manufcode: None, OrigFCF: 01
2022-05-22 10:36:54,109 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response ==== payload: 18820b0100
2022-05-22 10:36:54,109 DEBUG   : [ZigpyForwarder_12] Reception Data indication, Source Address: 66cb Destination Address: 0000 ProfilID: 0104 ClusterID: 0019 Message Payload: 0182010029100c1115160420
2022-05-22 10:36:59,573 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8011,  Data: b63840, LQI: 0
2022-05-22 10:37:00,253 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8011,  Data: b664c0, LQI: 0
2022-05-22 10:37:00,382 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8011,  Data: 00287d, LQI: 60
2022-05-22 10:37:00,421 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8011,  Data: 0066cb, LQI: 60
2022-05-22 10:37:00,690 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 0001040406010102258e020000189d0a00001801, LQI: 63
2022-05-22 10:37:00,690 DEBUG   : [ZigpyForwarder_12] zcl_decoders Zcl.ddr: 1 GlobalCommand: True Sqn: 9d ManufCode: None Command: 0a Data: 00001801 Payload: 189d0a00001801
2022-05-22 10:37:00,691 DEBUG   : [ZigpyForwarder_12] zcl_decoders Sqn: 157/9d ManufCode: None Command: 0a Data: 00001801
2022-05-22 10:37:00,691 DEBUG   : [ZigpyForwarder_12] buildframe_report_attribute_response - 258e 01 0406 Data: 00001801
2022-05-22 10:37:00,691 DEBUG   : [ZigpyForwarder_12] Decode8102 - Attribute Reports: [258e:01] MsgSQN: 9d ClusterID: 0406 AttributeID: 0000 Status: 00 Type: 18 Size: 0001 ClusterData: >01<
2022-05-22 10:37:00,692 DEBUG   : [ZigpyForwarder_12] scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [258e:01] ClusterID: 0406 MsgSQN: 9d, i_sqn: 9d, AttributeID: 0000 Status: 00 Type: 18 Size: 0001 ClusterData: >01<
2022-05-22 10:37:00,693 DEBUG   : [ZigpyForwarder_12] Decode8102 - LQI:  63 Received Cluster:0406 Attribute: 0000 Value:   01 from (258e/01)
2022-05-22 10:37:03,096 DEBUG   : [       MainThread] read_attribute d5b6 01 03 0000 00 00 0000 01 0000
2022-05-22 10:37:03,101 DEBUG   : [       MainThread] rawaps_read_attribute_req d5b6 01 03 0000 00 00 0000 0000
2022-05-22 10:37:08,105 DEBUG   : [       MainThread] read_attribute 1147 01 0b 0000 00 00 0000 01 0000
2022-05-22 10:37:08,114 DEBUG   : [       MainThread] rawaps_read_attribute_req 1147 01 0b 0000 00 00 0000 0000
2022-05-22 10:37:10,097 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8011,  Data: b6d5b6, LQI: 0
2022-05-22 10:37:10,098 INFO    : [ZigpyForwarder_12] timeout_widget unit Garden Flower Bed -> True from 1:100
2022-05-22 10:37:10,104 INFO    : [ZigpyForwarder_12] Receive NACK from Garden Flower Bed (d5b6) clusterId:  Status: b6
2022-05-22 10:37:13,625 DEBUG   : [       MainThread] mgtCommand (cf1b) Devices[37].Name: Garden Blind Command: On Level: 47 Color:
2022-05-22 10:37:13,626 DEBUG   : [       MainThread] --------->   DeviceType: ('BlindInverted', 'WindowCovering')
2022-05-22 10:37:13,626 DEBUG   : [       MainThread] --------->1   ClusterType founds: [('01', '2429', 'WindowCovering')] for Unit: 37
2022-05-22 10:37:13,626 DEBUG   : [       MainThread] --------->2   EPOut: 01 DeviceType: WindowCovering WidgetID: 2429
2022-05-22 10:37:13,626 DEBUG   : [       MainThread] --------->3   forceUpdateDev: False
2022-05-22 10:37:13,627 DEBUG   : [       MainThread] --------->4   Ready to action
2022-05-22 10:37:13,627 DEBUG   : [       MainThread] --------->5   profalux: False
2022-05-22 10:37:13,627 DEBUG   : [       MainThread] --------->6   Model Name: FYRTUR block-out roller blind
2022-05-22 10:37:13,627 DEBUG   : [       MainThread] --------->7   Health:
2022-05-22 10:37:13,628 DEBUG   : [       MainThread] mgtCommand : On for Device: cf1b EPout: 01 Unit: 37 DeviceType: WindowCovering ModelName: FYRTUR block-out roller blind
2022-05-22 10:37:13,628 DEBUG   : [       MainThread] zcl_window_covering_on cf1b 01
2022-05-22 10:37:13,628 DEBUG   : [       MainThread] zcl_raw_window_covering cf1b 01 Up 00 00
2022-05-22 10:37:13,628 ERROR   : [       MainThread] zcl_raw_window_covering payload cf1b 110000
2022-05-22 10:37:14,788 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8011,  Data: 00cf1b, LQI: 0
2022-05-22 10:37:15,336 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8011,  Data: b61147, LQI: 0
2022-05-22 10:37:15,337 INFO    : [ZigpyForwarder_12] timeout_widget unit zigbee-plug-1 -> True from 0:Off
2022-05-22 10:37:15,343 INFO    : [ZigpyForwarder_12] Receive NACK from Plug1 (1147) clusterId:  Status: b6
2022-05-22 10:37:16,759 DEBUG   : [       MainThread] mgtCommand (cf1b) Devices[37].Name: Garden Blind Command: Off Level: 100 Color:
2022-05-22 10:37:16,759 DEBUG   : [       MainThread] --------->   DeviceType: ('BlindInverted', 'WindowCovering')
2022-05-22 10:37:16,760 DEBUG   : [       MainThread] --------->1   ClusterType founds: [('01', '2429', 'WindowCovering')] for Unit: 37
2022-05-22 10:37:16,760 DEBUG   : [       MainThread] --------->2   EPOut: 01 DeviceType: WindowCovering WidgetID: 2429
2022-05-22 10:37:16,760 DEBUG   : [       MainThread] --------->3   forceUpdateDev: False
2022-05-22 10:37:16,761 DEBUG   : [       MainThread] --------->4   Ready to action
2022-05-22 10:37:16,761 DEBUG   : [       MainThread] --------->5   profalux: False
2022-05-22 10:37:16,761 DEBUG   : [       MainThread] --------->6   Model Name: FYRTUR block-out roller blind
2022-05-22 10:37:16,762 DEBUG   : [       MainThread] --------->7   Health: Live
2022-05-22 10:37:16,762 DEBUG   : [       MainThread] mgtCommand : Off for Device: cf1b EPout: 01 Unit: 37 DeviceType: WindowCovering modelName: FYRTUR block-out roller blind
2022-05-22 10:37:16,762 DEBUG   : [       MainThread] zcl_window_covering_off cf1b 01
2022-05-22 10:37:16,762 DEBUG   : [       MainThread] zcl_raw_window_covering cf1b 01 Down 00 00
2022-05-22 10:37:16,763 ERROR   : [       MainThread] zcl_raw_window_covering payload cf1b 110101
2022-05-22 10:37:17,750 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8011,  Data: 00cf1b, LQI: 0
2022-05-22 10:37:19,057 DEBUG   : [       MainThread] mgtCommand (cf1b) Devices[37].Name: Garden Blind Command: On Level: 0 Color:
2022-05-22 10:37:19,057 DEBUG   : [       MainThread] --------->   DeviceType: ('BlindInverted', 'WindowCovering')
2022-05-22 10:37:19,058 DEBUG   : [       MainThread] --------->1   ClusterType founds: [('01', '2429', 'WindowCovering')] for Unit: 37
2022-05-22 10:37:19,058 DEBUG   : [       MainThread] --------->2   EPOut: 01 DeviceType: WindowCovering WidgetID: 2429
2022-05-22 10:37:19,058 DEBUG   : [       MainThread] --------->3   forceUpdateDev: False
2022-05-22 10:37:19,059 DEBUG   : [       MainThread] --------->4   Ready to action
2022-05-22 10:37:19,059 DEBUG   : [       MainThread] --------->5   profalux: False
2022-05-22 10:37:19,059 DEBUG   : [       MainThread] --------->6   Model Name: FYRTUR block-out roller blind
2022-05-22 10:37:19,060 DEBUG   : [       MainThread] --------->7   Health: Live
2022-05-22 10:37:19,060 DEBUG   : [       MainThread] mgtCommand : On for Device: cf1b EPout: 01 Unit: 37 DeviceType: WindowCovering ModelName: FYRTUR block-out roller blind
2022-05-22 10:37:19,060 DEBUG   : [       MainThread] zcl_window_covering_on cf1b 01
2022-05-22 10:37:19,060 DEBUG   : [       MainThread] zcl_raw_window_covering cf1b 01 Up 00 00
2022-05-22 10:37:19,061 ERROR   : [       MainThread] zcl_raw_window_covering payload cf1b 110200
2022-05-22 10:37:19,823 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8011,  Data: 00cf1b, LQI: 0
2022-05-22 10:37:21,685 DEBUG   : [       MainThread] mgtCommand (cf1b) Devices[37].Name: Garden Blind Command: Set Level Level: 52 Color:
2022-05-22 10:37:21,685 DEBUG   : [       MainThread] --------->   DeviceType: ('BlindInverted', 'WindowCovering')
2022-05-22 10:37:21,686 DEBUG   : [       MainThread] --------->1   ClusterType founds: [('01', '2429', 'WindowCovering')] for Unit: 37
2022-05-22 10:37:21,686 DEBUG   : [       MainThread] --------->2   EPOut: 01 DeviceType: WindowCovering WidgetID: 2429
2022-05-22 10:37:21,686 DEBUG   : [       MainThread] --------->3   forceUpdateDev: False
2022-05-22 10:37:21,687 DEBUG   : [       MainThread] --------->4   Ready to action
2022-05-22 10:37:21,687 DEBUG   : [       MainThread] --------->5   profalux: False
2022-05-22 10:37:21,687 DEBUG   : [       MainThread] --------->6   Model Name: FYRTUR block-out roller blind
2022-05-22 10:37:21,687 DEBUG   : [       MainThread] --------->7   Health: Live
2022-05-22 10:37:21,688 DEBUG   : [       MainThread] mgtCommand : Set Level for Device: cf1b EPout: 01 Unit: 37 DeviceType: WindowCovering Level: 52
2022-05-22 10:37:21,688 DEBUG   : [       MainThread] WindowCovering - Lift Percentage Command - cf1b/01 Level: 0x34 52
2022-05-22 10:37:21,688 INFO    : [       MainThread] WindowCovering - Lift Percentage Command - cf1b/01 value: 0x52 52
2022-05-22 10:37:21,689 DEBUG   : [       MainThread] zcl_window_covering_percentage cf1b 01 34
2022-05-22 10:37:21,689 DEBUG   : [       MainThread] zcl_raw_window_covering cf1b 01 GoToLiftPercentage 00 34
2022-05-22 10:37:21,689 ERROR   : [       MainThread] zcl_raw_window_covering payload cf1b 110305
2022-05-22 10:37:22,711 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 0001040102010102cf1b02000008030b0580, LQI: 36
2022-05-22 10:37:22,712 DEBUG   : [ZigpyForwarder_12] zcl_decoders sending a default response for command 0b
2022-05-22 10:37:22,712 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response cf1b 01 01 0102 03 for command 0b with Status: 00, Manufcode: None, OrigFCF: 08
2022-05-22 10:37:22,712 DEBUG   : [ZigpyForwarder_12] zcl_decoders Zcl.ddr: 0 GlobalCommand: True Sqn: 03 ManufCode: None Command: 0b Data: 0580 Payload: 08030b0580
2022-05-22 10:37:22,712 DEBUG   : [ZigpyForwarder_12] zcl_decoders Sqn: 3/03 ManufCode: None Command: 0b Data: 0580
2022-05-22 10:37:22,712 DEBUG   : [ZigpyForwarder_12] Reception Data indication, Source Address: cf1b Destination Address: 0000 ProfilID: 0104 ClusterID: 0102 Message Payload: 08030b0580
2022-05-22 10:37:22,713 INFO    : [ZigpyForwarder_12] Unknown Window Covering Command: 0b
2022-05-22 10:37:22,713 INFO    : [ZigpyForwarder_12] inRawAps cf1b/01 Cluster 0102 Manuf: 117c/IKEA of Sweden Command: 0b Data: 0580 Payload: 08030b0580 not processed !!!
2022-05-22 10:37:22,963 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8011,  Data: 00cf1b, LQI: 36
2022-05-22 10:38:00,328 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 0001040019010102287d0200000161010029100c1115160420, LQI: 63
2022-05-22 10:38:00,328 DEBUG   : [ZigpyForwarder_12] zcl_decoders sending a default response for command 01
2022-05-22 10:38:00,329 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response 287d 01 01 0019 61 for command 01 with Status: 00, Manufcode: None, OrigFCF: 01
2022-05-22 10:38:00,329 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response ==== payload: 18610b0100
2022-05-22 10:38:00,329 DEBUG   : [ZigpyForwarder_12] zcl_decoders Zcl.ddr: 0 GlobalCommand: False Sqn: 61 ManufCode: None Command: 01 Data: 0029100c1115160420 Payload: 0161010029100c1115160420
2022-05-22 10:38:00,330 DEBUG   : [ZigpyForwarder_12] zcl_decoders OTA Upgrade Command 01/Query Next Image Request data: 0029100c1115160420
2022-05-22 10:38:00,330 DEBUG   : [ZigpyForwarder_12] Reception Data indication, Source Address: 287d Destination Address: 0000 ProfilID: 0104 ClusterID: 0019 Message Payload: 0161010029100c1115160420
2022-05-22 10:38:00,451 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 000104001901010266cb02000001a7010029100c1115160420, LQI: 60
2022-05-22 10:38:00,452 DEBUG   : [ZigpyForwarder_12] zcl_decoders sending a default response for command 01
2022-05-22 10:38:00,452 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response 66cb 01 01 0019 a7 for command 01 with Status: 00, Manufcode: None, OrigFCF: 01
2022-05-22 10:38:00,452 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response ==== payload: 18a70b0100
2022-05-22 10:38:00,453 DEBUG   : [ZigpyForwarder_12] zcl_decoders Zcl.ddr: 0 GlobalCommand: False Sqn: a7 ManufCode: None Command: 01 Data: 0029100c1115160420 Payload: 01a7010029100c1115160420
2022-05-22 10:38:00,453 DEBUG   : [ZigpyForwarder_12] zcl_decoders OTA Upgrade Command 01/Query Next Image Request data: 0029100c1115160420
2022-05-22 10:38:00,454 DEBUG   : [ZigpyForwarder_12] Reception Data indication, Source Address: 66cb Destination Address: 0000 ProfilID: 0104 ClusterID: 0019 Message Payload: 01a7010029100c1115160420
2022-05-22 10:38:01,043 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 0001040406010102258e020000189e0a00001801, LQI: 60
2022-05-22 10:38:01,044 DEBUG   : [ZigpyForwarder_12] zcl_decoders Zcl.ddr: 1 GlobalCommand: True Sqn: 9e ManufCode: None Command: 0a Data: 00001801 Payload: 189e0a00001801
2022-05-22 10:38:01,044 DEBUG   : [ZigpyForwarder_12] zcl_decoders Sqn: 158/9e ManufCode: None Command: 0a Data: 00001801
2022-05-22 10:38:01,044 DEBUG   : [ZigpyForwarder_12] buildframe_report_attribute_response - 258e 01 0406 Data: 00001801
2022-05-22 10:38:01,045 DEBUG   : [ZigpyForwarder_12] Decode8102 - Attribute Reports: [258e:01] MsgSQN: 9e ClusterID: 0406 AttributeID: 0000 Status: 00 Type: 18 Size: 0001 ClusterData: >01<
2022-05-22 10:38:01,046 DEBUG   : [ZigpyForwarder_12] scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [258e:01] ClusterID: 0406 MsgSQN: 9e, i_sqn: 9e, AttributeID: 0000 Status: 00 Type: 18 Size: 0001 ClusterData: >01<
2022-05-22 10:38:01,046 DEBUG   : [ZigpyForwarder_12] Decode8102 - LQI:  60 Received Cluster:0406 Attribute: 0000 Value:   01 from (258e/01)
2022-05-22 10:38:01,156 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8011,  Data: 0066cb, LQI: 60
2022-05-22 10:38:01,179 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8011,  Data: 00287d, LQI: 63
2022-05-22 10:38:22,975 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 0001040000010102af3c0200001c5f11fa0a01ff422e6410006510000328149839000000009539d9d85343052136009a2000082121110727000000000000000009210003, LQI: 63
2022-05-22 10:38:22,976 DEBUG   : [ZigpyForwarder_12] zcl_decoders Zcl.ddr: 1 GlobalCommand: True Sqn: fa ManufCode: 115f Command: 0a Data: 01ff422e6410006510000328149839000000009539d9d85343052136009a2000082121110727000000000000000009210003 Payload: 1c5f11fa0a01ff422e6410006510000328149839000000009539d9d85343052136009a2000082121110727000000000000000009210003
2022-05-22 10:38:22,976 DEBUG   : [ZigpyForwarder_12] zcl_decoders Sqn: 250/fa ManufCode: 115f Command: 0a Data: 01ff422e6410006510000328149839000000009539d9d85343052136009a2000082121110727000000000000000009210003
2022-05-22 10:38:22,976 DEBUG   : [ZigpyForwarder_12] buildframe_report_attribute_response - af3c 01 0000 Data: 01ff422e6410006510000328149839000000009539d9d85343052136009a2000082121110727000000000000000009210003
2022-05-22 10:38:22,976 DEBUG   : [ZigpyForwarder_12] Decode8102 - Attribute Reports: [af3c:01] MsgSQN: fa ClusterID: 0000 AttributeID: ff01 Status: 00 Type: 42 Size: 002e ClusterData: >6410006510000328149839000000009539d9d85343052136009a2000082121110727000000000000000009210003<
2022-05-22 10:38:22,978 DEBUG   : [ZigpyForwarder_12] scan_attribute_reponse - 8102 idx: 116 Read Attribute Response: [af3c:01] ClusterID: 0000 MsgSQN: fa, i_sqn: fa, AttributeID: ff01 Status: 00 Type: 42 Size: 002e ClusterData: >6410006510000328149839000000009539d9d85343052136009a2000082121110727000000000000000009210003<
2022-05-22 10:38:22,978 DEBUG   : [ZigpyForwarder_12] Decode8102 - LQI:  63 Received Cluster:0000 Attribute: ff01 Value: 6410006510000328149839000000009539d9d85343052136009a2000082121110727000000000000000009210003 from (af3c/01)
2022-05-22 10:38:54,054 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 000104000601010266cb020000088b0a00001000, LQI: 63
2022-05-22 10:38:54,055 DEBUG   : [ZigpyForwarder_12] zcl_decoders sending a default response for command 0a
2022-05-22 10:38:54,055 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response 66cb 01 01 0006 8b for command 0a with Status: 00, Manufcode: None, OrigFCF: 08
2022-05-22 10:38:54,056 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response ==== payload: 108b0b0a00
2022-05-22 10:38:54,057 DEBUG   : [ZigpyForwarder_12] zcl_decoders Zcl.ddr: 0 GlobalCommand: True Sqn: 8b ManufCode: None Command: 0a Data: 00001000 Payload: 088b0a00001000
2022-05-22 10:38:54,059 DEBUG   : [ZigpyForwarder_12] zcl_decoders Sqn: 139/8b ManufCode: None Command: 0a Data: 00001000
2022-05-22 10:38:54,059 DEBUG   : [ZigpyForwarder_12] buildframe_report_attribute_response - 66cb 01 0006 Data: 00001000
2022-05-22 10:38:54,060 DEBUG   : [ZigpyForwarder_12] Decode8102 - Attribute Reports: [66cb:01] MsgSQN: 8b ClusterID: 0006 AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >00<
2022-05-22 10:38:54,060 DEBUG   : [ZigpyForwarder_12] scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [66cb:01] ClusterID: 0006 MsgSQN: 8b, i_sqn: 8b, AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >00<
2022-05-22 10:38:54,060 DEBUG   : [ZigpyForwarder_12] Decode8102 - LQI:  63 Received Cluster:0006 Attribute: 0000 Value:   00 from (66cb/01)
2022-05-22 10:38:56,026 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 0001040406010102547902000018950a00001801, LQI: 63
2022-05-22 10:38:56,027 DEBUG   : [ZigpyForwarder_12] zcl_decoders Zcl.ddr: 1 GlobalCommand: True Sqn: 95 ManufCode: None Command: 0a Data: 00001801 Payload: 18950a00001801
2022-05-22 10:38:56,028 DEBUG   : [ZigpyForwarder_12] zcl_decoders Sqn: 149/95 ManufCode: None Command: 0a Data: 00001801
2022-05-22 10:38:56,028 DEBUG   : [ZigpyForwarder_12] buildframe_report_attribute_response - 5479 01 0406 Data: 00001801
2022-05-22 10:38:56,028 DEBUG   : [ZigpyForwarder_12] Decode8102 - Attribute Reports: [5479:01] MsgSQN: 95 ClusterID: 0406 AttributeID: 0000 Status: 00 Type: 18 Size: 0001 ClusterData: >01<
2022-05-22 10:38:56,028 DEBUG   : [ZigpyForwarder_12] scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [5479:01] ClusterID: 0406 MsgSQN: 95, i_sqn: 95, AttributeID: 0000 Status: 00 Type: 18 Size: 0001 ClusterData: >01<
2022-05-22 10:38:56,028 DEBUG   : [ZigpyForwarder_12] Decode8102 - LQI:  63 Received Cluster:0406 Attribute: 0000 Value:   01 from (5479/01)
2022-05-22 10:38:58,885 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 000104000801010266cb02000008bc0a000020ff, LQI: 63
2022-05-22 10:38:58,886 DEBUG   : [ZigpyForwarder_12] zcl_decoders sending a default response for command 0a
2022-05-22 10:38:58,887 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response 66cb 01 01 0008 bc for command 0a with Status: 00, Manufcode: None, OrigFCF: 08
2022-05-22 10:38:58,887 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response ==== payload: 10bc0b0a00
2022-05-22 10:38:58,887 DEBUG   : [ZigpyForwarder_12] zcl_decoders Zcl.ddr: 0 GlobalCommand: True Sqn: bc ManufCode: None Command: 0a Data: 000020ff Payload: 08bc0a000020ff
2022-05-22 10:38:58,887 DEBUG   : [ZigpyForwarder_12] zcl_decoders Sqn: 188/bc ManufCode: None Command: 0a Data: 000020ff
2022-05-22 10:38:58,888 DEBUG   : [ZigpyForwarder_12] buildframe_report_attribute_response - 66cb 01 0008 Data: 000020ff
2022-05-22 10:38:58,888 DEBUG   : [ZigpyForwarder_12] Decode8102 - Attribute Reports: [66cb:01] MsgSQN: bc ClusterID: 0008 AttributeID: 0000 Status: 00 Type: 20 Size: 0001 ClusterData: >ff<
2022-05-22 10:38:58,888 DEBUG   : [ZigpyForwarder_12] scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [66cb:01] ClusterID: 0008 MsgSQN: bc, i_sqn: bc, AttributeID: 0000 Status: 00 Type: 20 Size: 0001 ClusterData: >ff<
2022-05-22 10:38:58,890 DEBUG   : [ZigpyForwarder_12] Decode8102 - LQI:  63 Received Cluster:0008 Attribute: 0000 Value:   ff from (66cb/01)
2022-05-22 10:39:01,357 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 0001040019010102287d0200000162010029100c1115160420, LQI: 63
2022-05-22 10:39:01,359 DEBUG   : [ZigpyForwarder_12] zcl_decoders sending a default response for command 01
2022-05-22 10:39:01,359 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response 287d 01 01 0019 62 for command 01 with Status: 00, Manufcode: None, OrigFCF: 01
2022-05-22 10:39:01,359 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response ==== payload: 18620b0100
2022-05-22 10:39:01,359 DEBUG   : [ZigpyForwarder_12] zcl_decoders Zcl.ddr: 0 GlobalCommand: False Sqn: 62 ManufCode: None Command: 01 Data: 0029100c1115160420 Payload: 0162010029100c1115160420
2022-05-22 10:39:01,360 DEBUG   : [ZigpyForwarder_12] zcl_decoders OTA Upgrade Command 01/Query Next Image Request data: 0029100c1115160420
2022-05-22 10:39:01,360 DEBUG   : [ZigpyForwarder_12] Reception Data indication, Source Address: 287d Destination Address: 0000 ProfilID: 0104 ClusterID: 0019 Message Payload: 0162010029100c1115160420
2022-05-22 10:39:01,606 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 000104001901010266cb02000001c4010029100c1115160420, LQI: 63
2022-05-22 10:39:01,608 DEBUG   : [ZigpyForwarder_12] zcl_decoders sending a default response for command 01
2022-05-22 10:39:01,608 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response 66cb 01 01 0019 c4 for command 01 with Status: 00, Manufcode: None, OrigFCF: 01
2022-05-22 10:39:01,608 DEBUG   : [ZigpyForwarder_12] zcl_raw_default_response ==== payload: 18c40b0100
2022-05-22 10:39:01,609 DEBUG   : [ZigpyForwarder_12] zcl_decoders Zcl.ddr: 0 GlobalCommand: False Sqn: c4 ManufCode: None Command: 01 Data: 0029100c1115160420 Payload: 01c4010029100c1115160420
2022-05-22 10:39:01,609 DEBUG   : [ZigpyForwarder_12] zcl_decoders OTA Upgrade Command 01/Query Next Image Request data: 0029100c1115160420
2022-05-22 10:39:01,609 DEBUG   : [ZigpyForwarder_12] Reception Data indication, Source Address: 66cb Destination Address: 0000 ProfilID: 0104 ClusterID: 0019 Message Payload: 01c4010029100c1115160420
2022-05-22 10:39:02,205 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8011,  Data: 00287d, LQI: 63
2022-05-22 10:39:02,503 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8011,  Data: 0066cb, LQI: 63
2022-05-22 10:39:02,573 DEBUG   : [ZigpyForwarder_12] ZigateRead - MsgType: 8002,  Data: 0001040406010102258e020000189f0a00001801, LQI: 60
2022-05-22 10:39:02,574 DEBUG   : [ZigpyForwarder_12] zcl_decoders Zcl.ddr: 1 GlobalCommand: True Sqn: 9f ManufCode: None Command: 0a Data: 00001801 Payload: 189f0a00001801
2022-05-22 10:39:02,574 DEBUG   : [ZigpyForwarder_12] zcl_decoders Sqn: 159/9f ManufCode: None Command: 0a Data: 00001801
2022-05-22 10:39:02,575 DEBUG   : [ZigpyForwarder_12] buildframe_report_attribute_response - 258e 01 0406 Data: 00001801
2022-05-22 10:39:02,575 DEBUG   : [ZigpyForwarder_12] Decode8102 - Attribute Reports: [258e:01] MsgSQN: 9f ClusterID: 0406 AttributeID: 0000 Status: 00 Type: 18 Size: 0001 ClusterData: >01<
2022-05-22 10:39:02,575 DEBUG   : [ZigpyForwarder_12] scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [258e:01] ClusterID: 0406 MsgSQN: 9f, i_sqn: 9f, AttributeID: 0000 Status: 00 Type: 18 Size: 0001 ClusterData: >01<
2022-05-22 10:39:02,576 DEBUG   : [ZigpyForwarder_12] Decode8102 - LQI:  60 Received Cluster:0406 Attribute: 0000 Value:   01 from (258e/01)
pipiche
Re: Ikea zigbee blind
Post by pipiche »
can you give a try again
still on the same branch
git pull
restart and test the level control
gorstj
Post by gorstj »
% control now works great.
Pressing open/close when it is in operation still causes it to stop. However, I guess I can fudge that by only ever sending setLevel commands
Thanks very much.
p.s. how do I get back to the beta branch (assuming you will be integrating the changes).
Let me know if you want me to do any more tests
pipiche
Post by pipiche »
I merged it, so you can now do
git pull
git checkout beta6
git pull
and then restart
