Hi have found an integration GOODWE invertors for Home Assistant. Itt is reading data directly from the inverter every 5 seconds.
I would like to ask it possible to implement it to Fibaro HC3? Someone is working on it?
GoodWe inverters
- Domoticz version: 2025.1
Re: GoodWe inverters
there is a plugin for goodwe inverters: https://github.com/JanJaapKo/domoticz-GoodWeSEMS
Here is the discussion: viewtopic.php?p=288941#p288941
bofisko
I saw it and also I have it in fibaro.
But there is basic difference. What you are referring to is a plugin via Semportal.
But in Home assistant, it's directly from the local network.
https://www.home-assistant.io/integrations/goodwe/
bofisko
I saw it and also I have it in fibaro.waltervl wrote: Friday 29 April 2022 16:14 there is a plugin for goodwe inverters: https://github.com/JanJaapKo/domoticz-GoodWeSEMS
Nobody yet found the time and spirit to modify the current plugin to use the local network option (that requires a current inverter).
It is also discussed in that forum topic.
bofisko
I did it. I have QA for local connection with HC3 and Goodwe series like in Homeassistance for ET, EM and DT series.. If you want QA contact me with message on forum https://forum.fibaro.com/topic/63203-goodwe-hc3/.
