Unit deletion failed, UnitEx object is not associated with a plugin
heggink
Domoticz version: 12451
Post by heggink »
@dnpwwo: whilst trying to develop a new plugin I get the above error. Here are the 2 code snippets for creating and deleting:
I create 2 devices as follows:
        if dev_id not in Devices:
                mySwitchUnit = Domoticz.Unit(Name=dev_id, DeviceID=dev_id, Unit=1, Type=244, Subtype=73, Switchtype=0, Options={}, Used=1, Description="")
                mySwitchUnit.Create()
                myTextUnit = Domoticz.Unit(Name=dev_id, DeviceID=dev_id, Unit=2, TypeName="General", Subtype=19, Options={}, Used=1, Description="")
                myTextUnit.Create()
Then if anyone of teh 2 gets deleted through teh domotcz interface, I want to delete the otherone myself:
        def onDeviceRemoved(self, DeviceID, Unit):
                Domoticz.Log("Device onDeviceRemoved for DeviceID: " +str(DeviceID)+" and Unit: "+str(Unit))
                if Unit == 1:
                        Domoticz.Log("Device onDeviceRemoved unit 1 so delete 2")
                        Devices[DeviceID].Units[2].Delete()
                else:
                        Domoticz.Log("Device onDeviceRemoved unit 1 so delete 1")
                        Devices[DeviceID].Units[1].Delete()
What am I doing wrong?
DASHTICZ 🙃
P1 meter & solar panel
Dnpwwo
Re: Unit deletion failed, UnitEx object is not associated with a plugin
Post by Dnpwwo »
@heggink,
Nothing, I reproduced your code and it didn't work for me either.
I've pushed a fix.
heggink
Post by heggink »
Excellent. Thanks.
DASHTICZ 🙃
JanJaap
Domoticz version: Dev
Post by JanJaap »
It is not only the deletion that doesn't work, any referencing of units in this way (or calling methods) doesn't work. Is all that fixed? Which version will it be pushed into?
see also: topic Deleting units in DomoticzEx framework
RPi 3, Domoticz dev version, Aeon ZWave stick (with a whole bunch of slaves), Zigbee using Zigbee2MQTT, Nest thermo, P1 smart meter on RPi Zero
Dnpwwo
Post by Dnpwwo »
@JanJaap,
I have responded in the other thread, but for clarity: The dictionary containing a device's units is 'Units' not 'Unit'.
That is why Domoticz is correctly reporting:
2022-04-24 16:26:25.867 Error: testplug: AttributeError: 'DomoticzEx.Device' object has no attribute 'Unit'
