IKEA lights not joinning
usky73
Domoticz version: 2021.1
Post by usky73 »
Hi all
I am stuck on IKEA Tradfi light association...
I have the remote control.
I try to follow the procedure here : https://github.com/zigbeefordomoticz/wi ... ts_Ikea.md
Means 6 times On/Off and launch a the pairing with the zigate interface. But nothing has been found. I repeat it many times without success.
Any help is welcome !
Domoticz version: 2025.1
Re: IKEA lights not joinning
It is the correct way but sometimes they will not listen.... Keep trying. The bulb will flash when in pairing mode.
The bulb also needs to be close to the zigate ( 1 or 2 meters) while pairing.
pipiche
Post by pipiche »
Some time the 6 times Off / On ( and not On/Off) you need to finish on the On needs a particular cadence ...
usky73
Post by usky73 »
Thanks both.
I have done both things without success... in the beginning but I found the solution. I hate Ikea.
I am using GU10 lights with the remote control.
I was doing 6 times On/Off with the remote control, even Off/On did not work.
The solution is to switch Off/On 6 times with a real switch !
Last issue not solved, I have created a group with the 3 lights in Domoticz with the max power.
But when using the group switch, the light will switch on but not 100%.
If I go to the switch menu, I can see it full power, but it is not the reality. If I move the power down and up then I have the light for real full.
Any idea ?
