i have been a long time user of Domoticz, but one thing still doesnt seem to get implemented: the aspect ratio of the cams...
I know I can manualy edit the aspect ratio in the .js files, but everytime Domoticz gets updated, I have to do it again...
A simple option in the configuration screen, to set the aspect ratio of the ip cams would be easy to implemend not?
besides that, almost all ip camera's use: 16/9 aspect ratio instead of 3/4, now when I click on an Ip cam on my dashboard, I get an ugly stretched Camera image...
Is there any way, to resolve this, or do I just have to accept the fact that it is never going to be implemented ?
iP Cams aspect ratio
- kiddigital
Re: iP Cams aspect ratio
Maybe create a feature request issue on Github describing what you want.
Should it be a default for all cameras or per camera?
Where do you propose these setting(s) should be? Maybe create a ‘screenshot’.
Where do you make the change(s), and which changes, now in the UI?
Lars77
It doesn't matter if it is per camera or for all cameras, a selection switch 3/4 or 16/9 at the camera settings screen (edit camera) would be perfect...
Now, I have to ssh into the Domoticz installation, go to the: /www/js/domoticz.js file and edit the ShowCameraLiveStream function:
and change: 4 / 3 to 16 / 9, every time domoticz gets updated...
but I will try to ask for a feature request on Github, maybe they will look into it...
function ShowCameraLiveStream(Name, camIdx) {
$.count = 0;
$.camfeed = "camsnapshot.jpg?idx=" + camIdx;
$('#dialog-camera-live #camfeed').attr("src", "images/camera_default.png");
//$('#dialog-camera-live #camfeed').attr("src", FeedURL);
var windowWidth = $(window).width() - 20;
var windowHeight = $(window).height() - 150;
var AspectSource = 4 / 3;
var height = windowHeight;
var width = Math.round(height * AspectSource) & ~1;
if (width > windowWidth) {
width = windowWidth;
height = Math.round(width / AspectSource) & ~1;
}but I will try to ask for a feature request on Github, maybe they will look into it...
- Xenomes
- Domoticz version: 2025.2
Thanks for the tip! is a good feature for a next release!Lars77 wrote: Wednesday 20 October 2021 20:25 It doesn't matter if it is per camera or for all cameras, a selection switch 3/4 or 16/9 at the camera settings screen (edit camera) would be perfect...
and change: 4 / 3 to 16 / 9, every time domoticz gets updated...Code: Select all
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.3 LTS (64Bit) - Domoticz 2025.2 (Docker) Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
- Domoticz version: 2025.1
For reference: Is implemented in Beta 14183 (februari 2022)
https://github.com/domoticz/domoticz/issues/5155
