Zigate error after power shutdown
usky73
Domoticz version: 2021.1
Post by usky73 »
Dear all
I got an unexpected power failure yesterday on my pi and I now have a lot of error message visible in the domoticz log but also on zigate interface.
Time : "14/04/2022 19:17:21"
Module : "TransportRder"
nwkid : "None"
PluginHealth : "Ready"
message : "on_message Frame error Crc/len bytearray(b'\x01\x00\x81\x02\x00\x0f\xf84\xeb-\x01\x0b\x04\x05\x0f\x00!\x00\x02\x02\x947\x03')"
PermitToJoin : Object {"Duration":0,"Starttime":1649935563}
Thread : "ZiGateSerial_18"
I have one device that is off, this is normal.
Everything seems to work well, what is this error ?
pipiche
Re: Zigate error after power shutdown
Post by pipiche »
This errors means that you have some corruption in the transmission between the Zigate and the Plugin, and so such messages are dropped.
This shouldn't happen.
I would have a look to the OS messages . Do you have some other errors , is the power supply of your Pi good enought.
Maybe the Zigate, the USB-TTL model, or any other component got an issue.
You might try to stop the pi. un-plug the zigate, restart it and see if the problem still happen.
You might try to change the USB port on which the zigate is currently plugged
Wiki is available here.
Zigbee for Domoticz FAQ
usky73
Post by usky73 »
it is a pigate, not USB.
What log should I look at at system level ?
pipiche
Post by pipiche »
you might have a look to
dmesg and journalctl
usky73
Post by usky73 »
Thanks pipiche for your prompt reply.
In fact I have tested a simple reboot, and it works...
