Door contact?
TroisSix
Domoticz version: 2025.2
Door contact?
Post by TroisSix »
Hi guys,
I searched over the forum and I couldn't find my answer: I cannot modify the textOn / textOff for a Door contact :oops:
I can specify an imageOn/ImageOff, but either the textOn/textOff are not working (it displays in french: OUVERT/FERME instead of Open/Closed)
blocks['DoorTest'] = { idx: 1111, title: 'DoorTest', textOn:"Open", textOff:"Closed", hide_data : false, last_update: false, width: 2}
Do you have any idea?
Thanks for your help 8-)
VM Debian - Domoticz stable v2025.2, RFXtrx433, Aeotec Z-Stick Gen5, Zigbee, Two APC
- rts: dio, oregon, somfy
- zwave: fibaro fgs212, aeotec smart switch, vision ZG8101
- IO Homecontrol: Velux Connexoon
- philips hue, Pilot app.
Domoticz version: 2025.1
Re: Door contact?
Edit: below answer can be ignored as I did not see it was a Dashticz related question.
The text of device states (open/close/on/off etc) are hard coded.
Sometimes there are inverted devices that switch the state. So if you click on the edit button you can change the switch type.
See wiki page https://www.domoticz.com/wiki/Dummy_for ... l_Switches for short descriptions of all available switches.
Lokonli
Re: Door contact?
Post by Lokonli »
TroisSix wrote: Tuesday 05 April 2022 20:31 Hi guys,
You are correct: For some switch types, including Door Contact, the textOn/textOff parameters were not supported.
I've fixed that in the latest beta version of Dashticz.
TroisSix
Re: Door contact?
Post by TroisSix »
Oh great, thanks Lokonli! I’ll try this soon when I’m back at home ;)
For now, I use a simple switch dummy device in parallel of my door contact :p
