I've got a couple of these:
https://nl.aliexpress.com/item/10050024 ... 79d2jfsJxs
They work fine with the Tuya app, and are correctly handled by HomeAssistant's LocalTuya integration. They are not detected by the Domiticz Tuya cloud plugin. How can this be obtained?
Tuya temp+hum sensor not detected
PIFOUBMW
Re: Tuya temp+hum sensor not detected
I have the same problem with this aliexpress tuya sensor : https://www.aliexpress.com/item/1005003712070514.html
It is not detected with tuya plugin in domoticz and it is not detected with the RASPBEE II installed in my domoticz too.
Then actually I still working with 433mhz temp+hum sensor : https://www.aliexpress.com/item/1005001936667884.html
Any solution ?
Any solution ?
