increase or decrease of temperature
jacobsentertainment
Domoticz version: 2021-1
Post by jacobsentertainment »
I'm currently working on a heating system where I need to determine if a temperature is increasing or decreasing so I can anticipate with the script.
My intention is to open up a valve in the system when the temperature of the stove is 45° and increasing. and close the valve as soon as the temperature is below 50° and decreasing.
If someone can help me get started that would be much appreciated.
Domoticz version: 2026.3
Re: increase or decrease of temperature
when you request the data from a temperature device with /json.htm?type=devices&rid=IDX you can get the trend (2 or 3).
3 is decreasing
2 is increasing
Edit: 0=Unknown, 1=Stable, 2=Up, 3=Down
See also the up/down arrows in a temperature device widget.
the attribute is not exposed within dzVents so you will have to read it with openurl and parse the json for the trend value.
Well to be prepared for the next question I made an example script how to get the trend ( 0=Unknown, 1=Stable, 2=Up, 3=Down) of a temperature device.
Replace IP_DOMO, PORT and IDX to your own environment
		timer = {
			'every 1 minutes' -- just an example to trigger the request
		httpResponses = {
			'GetTrend' -- must match with the callback passed to the openURL command
	logging = {
		level = domoticz.LOG_INFO,
		marker = 'template',
		if (item.isTimer) then
			domoticz.openURL({
				url = 'http://IP_DOMO:PORT/json.htm?type=devices&rid=IDX',
				method = 'GET',
				callback = 'GetTrend', -- see httpResponses above.
		if (item.isHTTPResponse) then
			if (item.ok) then
				if (item.isJSON) then
					local DevTrend = item.json.result[1].trend  -- to get the trend out of the json.
					-- log trend of device in Domoticz,  0=Unknown, 1=Stable, 2=Up, 3=Down
					domoticz.log('Trend of dev = ' .. DevTrend, domoticz.LOG_LOG)
				domoticz.log('There was a problem handling the request', domoticz.LOG_ERROR)
				domoticz.log(item, domoticz.LOG_ERROR)
thomasbaetge
Domoticz version: 2023.1
Post by thomasbaetge »
I just came across this.... is there an option to get the trend value in MQTT as well? IIRC it is not in the payload for temp sensors so far..?
jacobsentertainment
Cheers Walter :D Ill give it try tonight.
waltervl wrote: Wednesday 30 March 2022 21:53 Well to be prepared for the next question I made an example script how to get the trend ( 0=Unknown, 1=Stable, 2=Up, 3=Down) of a temperature device.
		timer = {
		httpResponses = {
	logging = {
			domoticz.openURL({
				method = 'GET',
			if (item.ok) then
jacobsentertainment
Sure I do something wrong here :oops: And I admit I know to little of this.
Anyway me result where
 2022-03-31 20:20:01.335 Error: Error opening url: http://192.168.178.72:8080/json.htm?type=devices&rid=64
2022-03-31 20:20:01.697 Error: dzVents: Error: (3.1.8) Trend: HTTP/1.1 response: 401 ==>> Unauthorized
2022-03-31 20:20:01.700 Error: dzVents: Error: (3.1.8) Trend: There was a problem handling the request
2022-03-31 20:20:01.700 Error: dzVents: Error: (3.1.8) Trend: {["data"]="<html><head><title>Unauthorized</title></head><body><h1>401 Unauthorized</h1></body></html>", ["isJSON"]=false, ["isDevice"]=false, ["isVariable"]=false, ["headers"]={["Content-Type"]="text/html;charset=UTF-8", ["Set-Cookie"]="DMZSID=none; HttpOnly; Expires=Thu, 01 Jan 1970 00:00:00 GMT", ["Content-Length"]="91"}, ["callback"]="GetTrend", ["isXML"]=true, ["isSecurity"]=false, ["trigger"]="GetTrend", ["statusCode"]=401, ["protocol"]="HTTP/1.1", ["xml"]={["html"]={["body"]={["h1"]="401 Unauthorized"}, ["head"]={["title"]="Unauthorized"}}}, ["isCustomEvent"]=false, ["isHTTPResponse"]=true, ["baseType"]="httpResponse", ["_contentType"]="text/html;charset=UTF-8", ["isSystem"]=false, ["isHardware"]=false, ["statusText"]="Unauthorized", ["isShellCommandResponse"]=false, ["isTimer"]=false, ["isGroup"]=false, ["isScene"]=false, ["ok"]=false, ["dump"]=function}
If I put the http directly in a browser I get the info of that sensor.
If you have user/password, do you have 127.0.0.* (next to your local network 192.168.178.*) in the local Networks setting (menu setup- settings)?
jacobsentertainment
waltervl wrote: Thursday 31 March 2022 22:01 If you have user/password, do you have 127.0.0.* (next to your local network 192.168.178.*) in the local Networks setting (menu setup- settings)?
I do have a username and password setup in domoticz, but nothing in 127.0.0.
So you should. Like the dzvents documentation says:
https://www.domoticz.com/wiki/DzVents:_ ... h_Domoticz
Also make sure that in the Security section in the settings (Setup > Settings > System > Local Networks (no username/password) you allow 127.0.0.1 (and / or ::1 when using IPv6 ) to not need a password. dzVents does use this port to get the location settings and to send certain commands to Domoticz.
jacobsentertainment
Ill try to have a look in to this this week, currently back on job and away from home.
jacobsentertainment
I have it working;
 2022-04-03 17:40:00.420 Status: dzVents: Info: Trend: ------ Start internal script: trend test:, trigger: "every 1 minutes"
2022-04-03 17:40:00.420 Status: dzVents: Info: Trend: ------ Finished trend test
2022-04-03 17:40:00.992 Status: dzVents: Info: Handling httpResponse-events for: "GetTrend"
2022-04-03 17:40:00.992 Status: dzVents: Info: Trend: ------ Start internal script: trend test: HTTPResponse: "GetTrend"
2022-04-03 17:40:00.994 Status: dzVents: Info: Trend: Trend of dev = 3
2022-04-03 17:40:00.994 Status: dzVents: Info: Trend: ------ Finished trend test
Maybe silly to ask but how can I use this 0, 1, 2, or 3 to trigger an action :?
Like you said in first post (make it dzvents yourself):
If temp = 45 and trend = 2 then open valve
If temp = 50 and trend = 3 then close valve
jacobsentertainment
waltervl wrote: Sunday 03 April 2022 18:22 Like you said in first post (make it dzvents yourself):
Cheers Walter :D
I also had a little play to get some results
			if DevTrend ~= 2 then
			    domoticz.log('Trend gaat omhoog', domoticz.LOG_LOG)
		    elseif
		        DevTrend ~= 3 then
		            domoticz.log('Trend gaat omlaag', domoticz.LOG_LOG)
And it works just fine, this opens up some options :D
ayasystems
Post by ayasystems »
should be included into dzevents params
bitzy
Domoticz version: 2023.2
Post by bitzy »
can someone explain how the trend is set in domoticz? after how many readings is the trend set? or is set after a time and the value of the temperature? how dose domoticz set the trend for a sensore temperature?
i have a sensore that is updated every 10 seconds and the trend is changing very slow.
Looking at https://github.com/domoticz/domoticz/bl ... lculator.h it seems to be measured over an average of 30 minutes.
