Extract value from json response
Supertramp4
Post by Supertramp4 »
Hi, I am a newbie to domoticz, and have been experimenting with lua/dzvents scripting, and need a little help
My script calls dz.openurl with a callback
/json.htm?type=devices&rid=2, which successfully returns values,
ie
"Data" : "309 Watt",
"LastUpdate" : "2022-03-25 19:05:43",
My question is after the
if item.isHTTPResponse and item.isJSON then
  local results=item.json.result
  for i, node in pairs(results) do
    [b]local power = node.Data -- just holding the numeric part without units[/b]
    local lastUpdate = Time(node.LastUpdate)
how do I extract the numeric value from the "node.Data" field so that power will contain a value of 309, and does not have the units of "watt" so that I can use this to update another custom sensor
Many Thanks
mgugu
Re: Extract value from json response
Post by mgugu »
You have to split the string with space separator. Unfortunately there is no built in split function un LUA. You have to make it yourself.
Check at https://www.tutorialspoint.com/how-to-s ... rogramming
Doler
Post by Doler »
Here you go
-- Split a string separated by delimiter and return result in array
stringSplit = function(s, delimiter)
	local result = {}
	for strmatch in (s..delimiter):gmatch('(.-)'..delimiter) do
		table.insert(result, strmatch)
	return result
Mark: Domoticz Beta on Raspberry Pi 4 running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - MySensors - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (plugin) - Zwave-js-ui - dzVents - Nodered
Domoticz version: 2024.7
It is fine that you experiment with JSON and OpenURL but normally this is not necessary with dzvents.
For example the lastupdate time can be read with statement
lastupdateTime = domoticz.devices(2).lastUpdate
or
lastupdateTime = device.lastUpdate
when the device 2 is the triggered device
I made an example script for getting the trend value out of the domoticz json respond.
Most important line:
local DevTrend = item.json.result[1].trend
no need for splitting etc.
viewtopic.php?p=288478#p288478
Supertramp4
Hi all, thanks for your input.
@doler, the code worked, but after @waltervl input, I played a bit more, and discovered that was the way to go, and now have something working.
