Domoticz 2022.1 (build 14257)
I'm getting this stack trace mainly when stop/starting a plugin
Python Plugin Crash
Python Plugin Crash
Wiki is available here.
Zigbee for Domoticz FAQ
Re: Python Plugin Crash
same crash with Domoticz 2022.1 (build 14285)
Same problem here when I restart domoticz after installing any plugin it won't start again so I must delete the plugin to get it start again.
I think this problem is related to a python library
- Domoticz version: 2024.7
If you are on latest beta please report your issue in this topic with the requested details viewtopic.php?t=38086
- Dnpwwo
The 2 stack dumps show that the 'zigpy-deconz' have 3 or 4 threads running during the plugin shutdown.
Python threads need to all be stopped before leaving onStop otherwise there will be a crash. The Python C API doesn't have a way of detecting or handling this (can I've seen).
- Dnpwwo
I've pushed a change to check (and log) for running threads during stop and wait for around 10 seconds to give them time to stop before continuing.
Sadly the 'threading' library doesn't have a 'kill' or 'stop' API so I can't do much about that.
Thanks I’ll check the plugin code.
I'm now on Domoticz 2022.1 build 14289 and get crash when having the plugin running.
This looks to happen when I'm doing a http request from a web browser to a plugin webserver thread. This problem was not existing with a prior Domoticz version I was running
