OpenWRT Zigbee for domoticz plugin
Re: OpenWRT Zigbee for domoticz plugin
The Python exception are usually logged to the Domoticz log.
innovateinvent
- Domoticz version: 2021.1
I would have expected that these import exceptions would be logged somewhere. Perhaps the exceptions are happening too early in the stack to make it in the log.
Have you been able to sorted out your issue ? Anything we can do to help you ?
innovateinvent
Thanks, I still haven't figured out how to get around not enough ram to install anything via pip. I was looking at moving this project to an old laptop but it needs a lot of love before I can use it.
I have put the request here https://github.com/zigpy/zigpy/discussions/931 , as we rely on the zigpy library, may be the guys will get some ideas to help you in the direction to take.
Having OpenWRT supported would be great
innovateinvent
I got it!
The magic sauce was installing the following:
It now works, I just need to muck around with trying to pair my ikea devices. They are struggling...
opkg install python3 python3-pip python3-voluptuous python3-cryptodome python3-attrs python3-aiohttp python3-jsonschema
pip install aiosqlite crccheck pyusb pyserial-asyncio coloredlogs
That is cool. congratulations.
If by chance you would be willing to document the setup for OpenWRT, we would be really pleased to make it available on our Wiki
https://github.com/zigbeefordomoticz/wiki
innovateinvent
innovateinvent
I am having issues with pairing any device, I am not sure if this is still related:
Do you know what this could be due to?
I tried pairing a Tradfri plug and switch.
"Module":"Input","nwkid":"9959","PluginHealth":"Ready","message":"Something wrong on Device 9959 97da43feff27fd84 pairing process. (aborting)","PermitToJoin":{"Duration":0,"Starttime":1647119112},"Thread":"ZigpyForwarder_2"},"LastLog":0,"StartTime":"12/03/2022 12:58:36","FirmwareVersion":"1217","FirmwareMajorVersion":"21","PluginVersion":"beta6-6.0.114"}
2022-03-12 13:04:49.605 SONOFF: (SONOFF) Assisted Pairing: Polling: ['61e0']
2022-03-12 13:04:49.612 SONOFF: (SONOFF) --> New device: 61e0
2022-03-12 13:04:49.612 SONOFF: (SONOFF) --> UNKNOW , removed 61e0 from List
2022-03-12 13:04:49.614 SONOFF: (SONOFF) --> New Device: {'NwkId': '61e0', 'ProvisionStatus': 'Failed', 'ProvisionStatusDesc': 'Failed', 'IEEE': '97da43feff27fd84', 'ProfileId': '', 'ProfileIdDesc': 'Unknow', 'ZDeviceID': '', 'ZDeviceIDDesc': 'Unknow', 'Model': '', 'PluginCertified': 'Unknow', 'Ep': []}
2022-03-12 13:04:59.573 SONOFF: (SONOFF) Assisted Pairing: Polling: []
2022-03-12 13:04:59.579 SONOFF: (SONOFF) --> Empty queue
What type/brand ?
innovateinvent
I have tried both a IKEA Tradfri E1743 switch and a IKEA Tradfri E1706 plug
I also tried enabling groups and creating group0000 in the settings, no effect.
https://www-twoenter-nl.translate.goog/ ... r_pto=wapp
No need for group at first.
Is the sonoff key closed to the system ? Can you try to put a usb cable ?
Can you try to enable
debugPairing
debugInput
debugZigpyZNP
Try pairing. And then drop me the logs here
debugPairing
debugInput
debugZigpyZNP
innovateinvent
"ControllerInRawMode": true,
"PluginAnalytics": 1,
"channel": "15",
"debugInput": 1,
"debugPairing": 1,
"debugTransportZigpy": 1,
"debugTransportZigpyZNP": 1,
"enablegroupmanagement": 1,
"filename": "/var/lib/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-02.json",
"homedirectory": "/var/lib/domoticz/plugins/Domoticz-Zigbee/",
"pluginConfig": "/var/lib/domoticz/plugins/Domoticz-Zigbee/Conf/",
"pluginData": "/var/lib/domoticz/plugins/Domoticz-Zigbee/Data/",
"pluginHome": "/var/lib/domoticz/plugins/Domoticz-Zigbee/",
"pluginLogs": "/var/lib/domoticz/plugins/Domoticz-Zigbee/Logs/",
"pluginOTAFirmware": "/var/lib/domoticz/plugins/Domoticz-Zigbee/OTAFirmware/",
"pluginReports": "/var/lib/domoticz/plugins/Domoticz-Zigbee/Reports/",
"pluginWWW": "/var/lib/domoticz/plugins/Domoticz-Zigbee/www/",
"zigatePartOfGroup0000": 1
The dongle is on a usb cable away from the router and the plug/switch is beside the dongle.
From what I quickly see in the logs is that the Device Announced itself, the pairing process started, and then few seconds later the device send a Leave message and leave the network.
Can you tell me how you do the pairing ? and especially the device reset ( switch or plug ) ?
innovateinvent
Thanks again for all this help.
I click on "Pairing" under "Pairing a new device with the assitant" and then a moment later I tap the reset button on the switch 4 times. The LED starts pulsing and then I leave it beside the SONOFF until I see the error on the popup window.
For the plug I do the same thing but press and hold the reset until the LED pulses. I also have it on an extension cord sitting beside the SONOFF.
so the all pairing looks good, and really don't understand what is going on.
Would you have any mean to sniff the zigbee traffic to undersstand what is happening ?
innovateinvent
I don't have anything other than the SONOFF for sniffing. I actually just noticed that there are other devices in my neighbourhood that are being picked up when I scan.
There is even this random RGB dimmer that I now have the option to add in the main Domoticz devices menu.
The issue must be limited to IKEA Tradfri devices. I'll see if I can dig around some more about others who have worked with this brand.
innovateinvent
Looks like it might be these issues:
https://github.com/Koenkk/Z-Stack-firmware/issues/338
https://github.com/Koenkk/zigbee2mqtt/issues/10339
I'm not sure I really understood the issue there, as from your setup, the SonOff key is already on the USB cable (just avoid USB 3.0) port.
Then in your case the extendedPANID seems to be correct (basically random number at initialisation) from the log extendedPANID=00:12:4b:00:24:c9:17:11
How are you doing ? Did you solve your issue ?
Just had a user having a similar issue, it was due to the fact that the Coordinator was plugged on a USB HUB. He just move it to a direct USB port with a USB cable and all works fine
