i made a simple lua script to test:
if devicechanged['dimmertest'] == 'Set Level: 90 %' then
commandArray['lamp huis'] = 'On'
print ("lamp huis is aan")
if devicechanged['dimmertest'] ~= 'Set Level: 90 %' then
commandArray['lamp huis'] = 'Off'
print ("lamp huis is uit")
return commandArray"dimmertest" is a virtual dimmer i made to do this test.
the On part works perfect.
but the Off part gets triggerd every second or so....i do not understand why becouse i have the lua set on "device"
how can i fix this?
