I have done my dashticz config, it is a great tool !
The only thing that I did not found is how to access to a specific screen directly with the http link.
By default it will access to screen #1 but how to access to an other screen using the http link ?
Like http://192.168.1.1:8082?screen=2
Possible ?
Access to a specifi screen directly
Lokonli
Re: Access to a specifi screen directly
Good to read you like Dashticz
There is a config parameter you can use in CONFIG.js, like this:
Via the url you can select an alternative config like:
or, only change one (ore more) config parameters directly:
You can also combine it (for whatever reason...):
config['start_page'] = 2
http://192.168.1.1:8082/?cfg=config2.js
http://192.168.1.1:8082/?start_page=2
http://192.168.1.1:8082/?cfg=config2.js&start_page=2
