execute = function( domoticz , triggerItem )
local myTable_devId = {}Code: Select all
hueScenesDz_hueId[i] = {}
myTable_devId[i].action = myUrl
myTable_devId[i].name = theNameModerator: leecollings
myTable_devId[i].name = theNameCode: Select all
Purpose of the script:
HUE is rolling out v2 of its API. Things works different now and there are more options.
One is called 'dynamic scenes'. Lights slowely change color, intensity etc. The Domoticz
plugin can't handle this yet. My goal for this script:
- Read the created scenes from the HUE bridge with v2 API
- Create devices from the HUE scenes
- Create new / delete removed / rename renamed
The idea is to make a table where the index is the hueSceneId from the HUE bridge:
hueScenesDz_hueId -- key = hueSceneId
hueScenesDz_hueId.onAction
hueScenesDz_hueId.sceneName
hueScenesDz_hueId.dzDeviceIdx
Later offAction and other things can be added. Lets try to get this working first.
The 'logic' :-p
- Do the API call to the HUE bridge to get all info
- Catch the response with HUE_SCENELIJST and build the table(s)
- Check the discovered scenes with the current devices in Domoticz
- Create new device if needed
- Add it to the table and add the new domoticz idx of the device to the table
Big problem here: Although the device is created, the idx isn't available yet.
I need a delay. Trying to wait for the MAKEDZDEVICE_EXECUTED* http-response, but
then I seem to have lost the content of my main table somehow. So now I am
experimenting with customEvents and .delay(seconds). This works, but again I can't
access my main table. I pass the table in the extradata field, and it is in
triggerItem.data but not in hueScenesDz_hueId.
experiment: is it because the customEvent trigger activates another instance of the script,
where hueScenesDz_hueId isn't created?
- (todo) Build a table with index domoticz-device index, so I can quickly find
corresponding actionOn, off etc.
devices = {
'HueScene - *',
2418 -- my virtual button; activates the script for tests
-- timer = {
-- 'every minute'
httpResponses = {
'HUE_SCENELIJST',
'MAKEDZDEVICE_EXECUTED*'
customEvents = {
'HUEEVENT_*'
-- Uncomment this later and make it so the devices are checked at startup
-- system = {
-- 'start'
logging = {
level = domoticz.LOG_DEBUG,
marker = 'HUE_SCENELIJST',
domoticz.log( 'Script started' , domoticz.LOG_DEBUG )
local hueScenesDz_hueId = {}
local scenePrefix = 'HueScene - '
-- FUNCTIONS -----------------------------------------------------------
-- Ask the HUE scenes from the bridge, the CALLBACK handles the response
local function scenesFromBridge()
domoticz.log('scenesFromBridge() : local function scenesFromBridge()' , domoticz.LOG_DEBUG )
domoticz.openURL({
url = 'https://' .. domoticz.helpers.myHueBridgeIp .. '/clip/v2/resource/scene',
method = 'GET',
callback = 'HUE_SCENELIJST',
headers = {
['hue-application-key'] = domoticz.helpers.myHueApiKey
-- Create the device
local function makeDzDevice(hueSceneId)
domoticz.log('makeDzDevice() : local function makeDzDevice()' , domoticz.LOG_DEBUG )
domoticz.openURL({
url = domoticz.settings.url .. '/json.htm?type=createdevice&idx=' .. domoticz.helpers.hueScenesHardwareId .. '&sensorname=' .. domoticz.utils.urlEncode(hueScenesDz_hueId[hueSceneId].sceneName) .. '&devicetype=244&devicesubtype=73',
method = 'GET',
callback = 'MAKEDZDEVICE_EXECUTED#' .. hueSceneId
domoticz.emitEvent( "HUEEVENT_".. hueSceneId , hueScenesDz_hueId ).afterSec(2)
-- Use the reply from the bridge to build local tables
local function makeScenelijst()
domoticz.log('makeScenelijst() : Step 2 - local function makeScenelijst()' , domoticz.LOG_DEBUG )
if (triggerItem.isJSON) then
local result_table = triggerItem.json.data -- giving table with all actions
local tc = #result_table -- counting number of actions
for i = 1, tc do -- go through all actions
local hueSceneId = result_table[i].id -- the scene-id from the hue bridge
local hueSceneName = result_table[i].metadata.name -- the scene-name from the hue bridge
local onActionCurl = 'curl --header "Content-Type: application/json" --header "hue-application-key: ' .. domoticz.helpers.myHueApiKey .. '"' ..
' --request PUT --data \'"recall":{"action":"dynamic_palette"}' ..
' https://' .. domoticz.helpers.myHueBridgeIp .. '/clip/v2/resource/scene/' .. hueSceneId -- the curl used to activate the scene on the hue bridge
hueScenesDz_hueId[hueSceneId] = {}
hueScenesDz_hueId[hueSceneId].onAction = onActionCurl
hueScenesDz_hueId[hueSceneId].sceneName = scenePrefix .. hueSceneName
if not domoticz.utils.deviceExists(hueScenesDz_hueId[hueSceneId].sceneName) then
domoticz.log('Device "' .. hueScenesDz_hueId[hueSceneId].sceneName .. '" does not exist.' , domoticz.LOG_DEBUG )
domoticz.log('noJSON',domoticz.LOG_ERROR)
-- MAIN CODE -----------------------------------------------------------
if ( triggerItem.isDevice ) then
domoticz.log ( 'Trigger is device : ' .. triggerItem.idx , domoticz.LOG_DEBUG )
if ( triggerItem.idx == 2418 ) then
domoticz.log('Trigger is device testbutton')
scenesFromBridge() -- get the scenes from the bridge and put them in a table
domoticz.log ( '******** Trigger is device : ' .. triggerItem.idx , domoticz.LOG_DEBUG )
if ( triggerItem.isHTTPResponse ) then
domoticz.log('Trigger is HTTPResponse : ' .. triggerItem.callback , domoticz.LOG_DEBUG )
if triggerItem.callback == 'HUE_SCENELIJST' then
makeScenelijst()
elseif string.find(triggerItem.callback, "MAKEDZDEVICE_EXECUTED#") then
if triggerItem.ok then
domoticz.log ( 'Devicecreation was ok' , domoticz.LOG_DEBUG )
domoticz.log ( 'ERROR - Devicecreation was not ok' , domoticz.LOG_DEBUG )
-- do stuff
-- In the next part I have to add the domoticz index to hueScenesDz_hueId for the
-- newly created device. But where is hueScenesDz_hueId ???
if ( triggerItem.isCustomEvent ) then
domoticz.log ( 'CustomEvent trigger = ' .. triggerItem.trigger, domoticz.LOG_DEBUG )
domoticz.log ( 'CustomEvent data = ' .. triggerItem.data, domoticz.LOG_DEBUG )
local event = triggerItem.data
if event == nil then
domoticz.log( 'data is missing', domoticz.LOG_ERROR)
elseif event.dzDeviceIdx == nil then
domoticz.log( 'dzDeviceIdx is missing', domoticz.LOG_ERROR)
elseif event.onAction == nil then
domoticz.log( 'onAction is missing', domoticz.LOG_ERROR)
elseif event.sceneName == nil then
domoticz.log( 'sceneName is missing', domoticz.LOG_ERROR)
domoticz.utils.dumpTable( hueScenesDz_hueId )
