I would like to change the background with linear-gradient of one block according to the value of another block;
block 76 holds a number between 56 and 150 and is a custom sensor. Value 56 means slightly unhealthy, 150 means unhealthy. These are pm values. I would like to make block 79 that holds the value Unhealthy (it's a text device) have a background: linear-gradient. If i put this straight in custom.css it will show the gradient, but I cannot seem to find the exact code to add the css value in custom.js. I tried this with mountPoint and also with $('.block_79') but I'm clearly missing something.
Could you please sent me in the right direction?
This is my custom.js
function getStatus_76(block) { //airqualitypm25us
var device = block.device;
if (Domoticz.getAllDevices()[79].Data == 'Unhealthy') {
var ug = parseFloat(device['Data']); //pm value in ug
var bereik = 150 - 56; //max - min //precentage unhealthy
var perc = ( bereik / ug ) * 100;
var percstr = perc.toFixed(0).toString();
var slightlyunhealthy = 'rgba(255,140,0,0.8)'; //oranje
var unhealthy = 'rgba(220,20,60,0.9)'; //rood
// example background: linear-gradient(to right, rgba(255,140,0,0.8), rgba(220,20,60,0.9) 70%) !important;
//var grad = `background: linear-gradient(to right, ${slightlyunhealthy}, ${unhealthy} ${percstr}) !important;`;
//$('.block_79').css(`background: linear-gradient(to right, ${slightlyunhealthy}, ${unhealthy} ${percstr}) !important`);
$(block.mountPoint).css(`background: linear-gradient(to right, ${slightlyunhealthy}, ${unhealthy} ${percstr}) !important`);
//$('.block_79').css(`background: linear-gradient(to right, rgba(255,140,0,0.8), rgba(220,20,60,0.9) 70%) !important`);
//example $(block.mountPoint + ' .ui-slider-horizontal').css('background-color', colorStr);
} //end if
blocks[76] = {title: 'Pm2.5', width: 4, icon: 'fas fa-smog', last_update: false}
blocks[79] = {title: 'Level Pm', width: 4, hide_data: true, last_update: false, protected: true}
If you need any more info please let me know
Thanks a lot in advance
