Error: Zigate: Decode8000
pfloryann
- Domoticz version: 2025.2
Today i updated plugin to 5.2.271 and domoticz to 2021.1 (build 13872) and i added Sonoff Motion sensor SNZB-03 but an error occurs.
it works well for a while but after a few hours it crashes the zigate, it no longer receives or sends commands . I don't know if the problem is caused by the sensor or the domoticz version.
Error: Zigate: Decode8000 - PacketType: 0092 TypeSqn: 01 sqn_app: 00 sqn_aps: bb Status: [0a]
I will attach the export file error from zigate.
Thank you in advance!
- errors.rar
- (941 Bytes) Downloaded 28 times
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5
Re: Error: Zigate: Decode8000
did you try To Power Off and On the ZIGate ? Which ZiGate version is it ? which firmware ?
pfloryann
I will try to power off.. Zigate Ttl , Firmware: 0320
pfloryann
Same error and same problem after 2-3hours...zigate not send commands.
I suspect an Hardware issue with your ZiGate.
Are you having a USB-TTL module Blue or Red ?
You can mention that the ZiGate is starting to respond with 0x15 error and then continue with 0x0a
pfloryann
Blue version
So if that is the blue, I know that there is some known issue with that one. So suggest that you contact the ZiGate vendor, or you purchase this one
https://zigate.fr/produit/module-usb-ttl-cp2102/
pfloryann
Thank you!
I saw that i haven't errors in the last 24h
pfloryann
I changed usb-ttl with red version and i have the same error.
Firmware 321, zigate plugin 6 beta.
Could you please share them ?
pfloryann
It's the same from the first post , now i m back to Firmware: 031e and no problem with this version from 1 month.
If you are not putting any logs it is hard to say anything.
Could you also tell how many devices are connected.
Last I zouke not recommend using the latest plugin version with not the most recent firmware.
- Domoticz version: 2025.1
@pipiche, I have similar errors regularly like below.
I do not know where they are coming from. I cannot relate it to a device. Can you? It does not seem to give issues I believe.
Plugin: 5.1.018
Firmware: 0321
For more info check the attached errors.json.
2022-02-22 18:03:11.851 Error: ZiGate: Decode8000 - PacketType: 0030 TypeSqn: 02 sqn_app: 00 sqn_aps: 22 Status: [ZigBee Error Code Unknown code : 80]
2022-02-22 18:06:23.656 Error: ZiGate: Decode8000 - PacketType: 0030 TypeSqn: 02 sqn_app: 00 sqn_aps: 4d Status: [ZigBee Error Code Unknown code : 80]
2022-02-22 18:06:30.282 Error: ZiGate: Decode8000 - PacketType: 0030 TypeSqn: 02 sqn_app: 00 sqn_aps: 51 Status: [ZigBee Error Code Unknown code : 80]
2022-02-22 18:06:30.499 Error: ZiGate: Decode8000 - PacketType: 0030 TypeSqn: 02 sqn_app: 00 sqn_aps: 52 Status: [ZigBee Error Code Unknown code : 80]Firmware: 0321
For me this is a bad behaviour of the Zigate, i have the same on my production as well.
If you disable ReenforceConfigureReporting this would most-likely reduce those issue
I suggest that you are reporting this issue on the Zigate/Firmware side here https://github.com/fairecasoimeme/ZiGate/issues/394
as it is an existing know issue.
