Error: dzVents: Error: (3.0.9) No information about longitude / latitude available
Antori91
Domoticz version: 4.10717
Post by Antori91 »
Even if I already set longitude/latitude in setup, I get repeatedly the following error message in the log file:
Error: dzVents: Error: (3.0.9) No information about longitude / latitude available. Please set lat/lng information in settings.
This happens for a custom Domoticz Build (Synology platform).
Where do I have to look to solve this issue?
Domoticz High Availability Cluster: Synology Dz V4.10693 (Main) - Raspberry Dz V4.10717 (Backup) - Scripts Node.js
Alarm server: Raspberry - motionEye - iot_ALARM-SVR Node.js
Sensors/Actuators: ESP8266-Arduino
https://github.com/Antori91/Home_Automation
Domoticz version: 2025.1
Re: Error: dzVents: Error: (3.0.9) No information about longitude / latitude available
Also make sure that in the Security section in the settings (Setup > Settings > System > Local Networks (no username/password) you allow 127.0.0.1 (and / or ::1 when using IPv6 ) to not need a password. dzVents does use this port to get the location settings and to send certain commands to Domoticz.
