After upgrading to the most recent version of the Zigbee2mqtt plugin in Domoticz (from v3.0.0. to v3.1.0.-beta) the GREEN led on the dongel now remains on and doesn't go off after booting, etc.
Domoticz / Zigbee2mqtt / etc. works ok with the new plugin.
RaspberryPi 3b
Domoticz version: 2022.1
Build Hash: c9526851b
Compile Date: 2022-01-31 09:34:32
Python Version: 3.7.3
Zigbee2mqtt plugin version 3.1.0.-beta
Zigbee2mqtt v.1.23.0 (zStack12 20190608)
What could be the problem?
Thanks in advance !
Regards, Theo (NL).
CC2531 coordinator USB-dongel Green LED now remains on
Dave21w
- Domoticz version: Stable
Re: CC2531 coordinator USB-dongel Green LED now remains on
I am seeing the same thing, also when I select zigbee2mqtt from the custom menu to look at the devices list / map etc it just sits on the devices tab saying loading and does nothing more.
Dave
Dave
Re: CC2531 coordinator USB-dongel Green LED now remains on (SOLVED)
My problem solved itself, what and how I don't know, but after a few full reboots of the RPi, the green LED went off after booting.
@Dave: you probably already tried that (I had the same problem and it helped) but: did you your browser cache?
Regards, Theo.
Regards, Theo.
Dave21w
Thanks, I'll check on Monday when I'm back at work - its just a test system I have sat on my desk so not that important.
Dave
Dave
