motion sensor at night
fipse
Post by fipse »
I'd like to accomplish, that the motion sensor only works at night. With this code it works all of the time:
-- LUA trigger set to device
-- Set the time:
now = os.date("%H") * 60 + os.date("%M")
sunrise = timeofday['SunsetInMinutes']
sunset = timeofday['SunriseInMinutes']
if now >= sunset or now <= sunrise then
   	if (devicechanged['PIR2'] == 'On' and otherdevices['Vorne'] == 'Off') then
	commandArray['Vorne']='On FOR 5'
I'm quite a newbe at lua but this should work. I really can't figure out, why it don't. Can someone please point me in the right direction? I'm more the C++ guy :D
73 fipse
jake
Re: motion sensor at night
Post by jake »
fipse wrote:Hi,
-- Set the time:
73 fipse
I see a something strange:
While defining sunrise and sunset, you mixed them up
When you are new to lua, I'd advise to start with dzvents. Much easier and more consistent in use of several devices.
fipse
Post by fipse »
Thanks, that solved it :D
So if someone want exactly this without dzVents:
sunset = timeofday['SunsetInMinutes']
sunrise = timeofday['SunriseInMinutes']
You in the domoticz scripting engine you need to set Trigger: to "Devices"
'PIR2' is the name of the motion sensor. (here via zigbee2mqtt)
'Vorne' is the name of the bulb (also a hue via zigbee2mqtt)
5 ... time in minutes the bulb is set to on
73 de fipse
EddyG
Post by EddyG »
And if someone wants to solve it in dzVents:
local SENSOR = 'PIR2'
local LIGHT = 'Vorne'
        devices = { [ SENSOR ]  = { 'between sunset and sunrise'  } }
    execute = function(dz, item)
        if item.active then
            if not dz.devices(LIGHT).active then
                dz.devices(LIGHT).switchOn().forMin(5)
