Zigbee2mqtt-plugin update error
THBR
Post by THBR »
I (beginner) did the plugin update (to be sure to check that I have the latest version) as described:
• cd domoticz/plugins/zigbee2mqtt
• git pull
Works fine but at the end I get this error
“error: The following untracked working tree files would be overwritten by merge:
github/ISSUE_TEMPLATE/new-device-feature-support.md
api/plugin.py
bridge.py
configuration.py
frontend/libs/ace_json_mode.js
frontend/libs/ace_worker_json.js
frontend/plugin_config.js
Please move or remove them before you merge.
Aborting”
I also tried “git stash” and then “git pull” without result.
My configuration:
RaspberryPi 3b
Domoticz Version: 2021.1
Python Version: 3.7.3
Plugin Version 3.0.0.
Zigbee2mqtt v.1.22.2 (zStack12 20190608)
What can be the cause and the solution without losing all settings and devices?
Thanks in advance !
Regards, Theo (NL).
HansOtten
Domoticz version: 2021-1
Re: Zigbee2mqtt-plugin update error
Post by HansOtten »
You will need just released Domoticz 2022.1 for the latest zigbee2mqtt plugin, see the github issues.
Or fallback to an older version of the plugin if you do not want to upgrade Domoticz.
To avoid the errors you have now, stop Domoticz, remove the whole plugin folder, do a fresh plugin installation and restart.
Setings are in the database.
Raspberry Pi 4, SSD, RFlink, P1 Smart Meter. Many Zigbee devices CR2562 USB stick. Bresser via Weather Underground
Switched to Home Assistant!
THBR
Post by THBR »
@HansOtten
Thanks for responding!
I updated now to Domoticz 2022.1, also updated Zigbee2mqtt. Everything works still fine, no errors or whatever.
To solve my still existing problem with updating the plugin:
- stop Domoticz
- delete the whole plugin folder > in home/pi/domoticz/plugins/zigbee2mqtt
- saving all settings/devices/etc > temporary secure by moving (or copy ?) the whole zigbee2mqtt folder > /opt/zigbee2mqtt to another temporary folder
- reinstalling the plugin by
cd domoticz/plugins
git clone https://github.com/stas-demydiuk/domoti ... plugin.git zigbee2mqtt
- set plugin settings again
- remove / replace the /opt/zigbee2mqtt folder
is this the right way to keep all settings and data as well ?
THBR
Re: Zigbee2mqtt-plugin update error SOLVED!
Post by THBR »
Problem plugin updating error SOLVED !:
I deleted the files (at first I stopped Domoticz):
.github/ISSUE_TEMPLATE/new-device-feature-support.md
api/plugin.py
bridge.py
configuration.py
Then git pull and everything updated to v.3.1.0-beta and new files were created.
Theo.
