Registering Heat Pump SCOP
Scoperius
Post by Scoperius »
I would like to store information about the Heater Pump SCOP. I need to register decimal number like 3.23 eventually percentage like 323%.
The problem is that data from Heat Pump is available always cca 2 minutes after every hour back. This means that SCOP for interval 15:00 - 16:00 is available at 16:02. If I use standard API call then data will be stored for actual Hour not for Previous. How to solve this?
Thanks,
Petr
Domoticz version: 2026.3
Re: Registering Heat Pump SCOP
By naming the device name " SCOP previous hour" ;)
But else I see no solution....
