API script /http polling Powerfox Energy tracker
- Domoticz version: 2021/1
Re: API script /http polling Powerfox Energy tracker
Thank you, related to this topic I have another question.
I tried to create another http request for my Wallbox.
Im struggling with the item.json…. Because the answer of my Wallbox is full of numbers and I cannot write e.g item.json.8062d in the code.
Answer of the http request
{"8000d":3473211392,"8002":1,"8003":258,"8004":263,"8005":1084,"8006":256,"8007":0,"8008s":"W00-00EA","8016s":"cFos Power Brain","8040":3,"8041":2,"8042d":1000,"8044":0,"8045":230,"8046":230,"8047":230,"8050q":121890,"8054d":22608230,"8056":1,"8057":0,"8058q":121890,"8062d":0,"8064d":0,"8066d":0,"8068d":0,"8070":0,"8071":0,"8120d":24}
- Domoticz version: 2024.7
should be something like
Somevalue = item.json['8026d']
or perhaps
Somevalue = item.json.['8026d']
or perhaps
That was the solution. But now I get the response „Nil“ in the log for the JSON 8026d value
Because there is no "8026d"?
oh damn...too much computer in the last days...now its working
Thanks a lot for all. I will post the running scripts as well
here my running powerfox plugin . Values are loaded into a virtual dummy P1 Meter
timer = {
'every minute' -- just an example to trigger the request
httpResponses = { 'Powerfoxtrigger' } -- must match with the callback passed to the openURL command
logging = {
level = domoticz.LOG_INFO,
marker = 'Powerfox',
if (item.isTimer) then
domoticz.openURL({
url = 'https://XXXXXXXXXX:[email protected]/api/2.0/my/main/current', -- X =Login Powerfox Y= PW
method = 'GET',
callback = 'Powerfoxtrigger', -- see httpResponses above.
if (item.isHTTPResponse) then
if (item.ok) then
if (item.isJSON) then
local USAGE1 = item.json.A_Plus
local RETURN1 = item.json.A_Minus
GetWatt = item.json.Watt
if item.json.Watt < 0 then
CONS = 0
PROD = math.abs(GetWatt)
domoticz.devices('Stromverbrauch').updateP1(item.json.A_Plus, '0', item.json.A_Minus, '0', '0', item.json.Watt)
domoticz.log('negative watts', domoticz.LOG_INFO)
domoticz.log(item.json.Watt, domoticz.LOG_INFO)
domoticz.log(item.json.A_Plus , domoticz.LOG_INFO)
domoticz.log(item.json.A_Minus, domoticz.LOG_INFO)
CONS = GetWatt
PROD = 0
domoticz.devices('Stromverbrauch').updateP1(item.json.A_Plus, '0', item.json.A_Minus, '0', item.json.Watt, '0')
domoticz.log('posetive watts', domoticz.LOG_INFO)
Great, thanks for sharing the end result!
Hi I need again some assistance…I try to import some data with http get from my wallbox
The answer of the request is( see below)Now my question is how to import one specific value of this answer. I mean for example line with „ power" : 612, . But there are more lines with the name „power“
"params" : {
"title" : "cFos Power Brain",
"desc" : "Standard-Konfiguration",
"max_total_power" : 11000,
"power_reserve" : 0,
"overdraft" : 0,
"max_total_evse_power" : 0,
"consumed_evse_power" : 0,
"remaining_evse_power" : 10388,
"lb_enabled" : true,
"disable_policy" : 1,
"ocpp_srv_tls_mode" : "off",
"ocpp_srv_port" : 19520,
"ocpp_srv_use_ext_cert" : false,
"ocpp_srv_cert_fn" : "",
"ocpp_srv_private_key_fn" : "",
"ocpp_srv_cacert_fn" :
"price_model" : 0,
"fixed_price" : 0.000000,
"tibber_home_id" : "",
"cycle_time" : 3000,
"max_evses" : 3,
"shareware_mode" : false,
"version" : "1.9.1101",
"time" : 1651093245,
"vsn" :
"vendorid" : 52997,
"version" : 17368141,
"productid" : 1,
"serialno" : "W00-00EA"
"cpu" : 58,
"mem" : 62,
"ocpp_gateway_license_cnt" : 0,
"ocpp_gateway_licenses_used" : 0
"devices" : [
"dev_type" : "meter_powerfox_http_json",
"device_enabled" : 1,
"name" : "Stromverbrauch Gesamt",
"address" : "https://backend.Powerfox.Energy/API/2.0/my/main/current",
"id" : 1,
"dev_id" : "M3",
"number" : 2,
"desc" : "powerfox http",
"com_err" : false,
"com_err_secs" : 26851,
"com_errors" : 25,
"last_error" : "HTTP CLT: failed to open TLS connection to backend.Powerfox.Energy:443",
"is_evse" : false,
"used_phases" : 0,
"is_mock" : false,
"is_va" : false,
"invert" : false,
"import" : 2744864,
"export" : 4406790,
"power" : 612,
"current_l1" : 887,
"current_l2" : 887,
"current_l3" : 887,
"voltage_l1" : 0,
"voltage_l2" : 0,
"voltage_l3" : 0,
"role" : 3,
"model" : "Powerfox,Powerfox,1.0,1.0,0"
"dev_type" : "meter_powerbrain",
"name" : "S0 Zähler 2",
"address" : "meter2",
"id" : 3,
"dev_id" : "M2",
"number" : 3,
"desc" : "cFos Power Brain, S0 Zähler 2",
"com_err" : false,
"com_err_secs" : 297427,
"com_errors" : 0,
"last_error" : "",
"is_evse" : false,
"used_phases" : 0,
"is_mock" : false,
"is_va" : false,
"invert" : false,
"import" : 401107,
"export" : 0,
"power" : 0,
"current_l1" : 0,
"current_l2" : 0,
"current_l3" : 0,
"voltage_l1" : 230,
"voltage_l2" : 230,
"voltage_l3" : 230,
"role" : 4,
"model" : "cFos Power Brain,1.0,1.9.1101,W00-00EA"
"name" : "Stromverbrauch Garage",
"address" : "meter1",
"id" : 2,
"dev_id" : "M1",
"number" : 1,
"desc" : "cFos Power Brain, S0 Zähler 1",
"com_err" : false,
"com_err_secs" : 300716,
"com_errors" : 0,
"last_error" : "",
"is_evse" : false,
"used_phases" : 0,
"is_mock" : false,
"is_va" : false,
"invert" : false,
"import" : 778749,
"export" : 0,
"power" : 46,
"current_l1" : 67,
"current_l2" : 67,
"current_l3" : 67,
"voltage_l1" : 230,
"voltage_l2" : 230,
"voltage_l3" : 230,
"role" : 0,
"dev_type" : "evse_powerbrain",
"name" : "Wallbox",
"address" : "evse",
"id" : 1,
"dev_id" : "E1",
"number" : 1,
"desc" : "cFos Power Brain 11kW",
"com_err" : false,
"com_errors" : 0,
"last_error" : "",
"is_evse" : true,
"used_phases" : 7,
"is_mock" : false,
"label" : "",
"min_charging_cur" : 6000,
"max_power" : 11040,
"prio" : 3,
"charging_enabled" : false,
"cur_charging_power" : 0,
"last_set_charging_cur" : 6000,
"total_energy" : 8625219,
"phases" : 0,
"state" : 1,
"model" : "cFos Power Brain,1.0,1.9.1101,W00-00EA",
"paused" : false,
"pause_time" : 300,
"pause_min_time" : 300,
"ucnt" : 1,
"evse" :
"dc_sensor_faults" : 0,
"dc_last_test_time" : "2022-04-26T15:55:30.946Z",
"dc_sensor_fault" : false,
"dc_sensor_glitches" : 3,
"cp_state" : "Standby",
"cp_fault" : false,
"pp_state" : "no cable",
"charging" : false,
"current" : 0,
"enabled" : false
"loadmgr_disabled" : false
Not completely sure but "power" : 612 is part of device with "dev_id" : "M3".
So if this M3 device is always in the same location in the json (first device in the list) you could try something like item.json.devices[0].power
or could also be item.json.devices[1].power.
If this not works you have to loop through the results
local result_table = item.json.devices
local tc = #result_table
for i = 1, tc do
if result_table[i].dev_id == "M3" then
PowerRead = result_table[i].power
Perfect, thanks I will try. Yes m3 device will be always at the same position.. I will report:)
Seems not working,
tried to receive the title just for testing: domoticz.log(item.JSON.params.title , domoticz.LOG_INFO)
thats the error in the log file
2022-05-01 19:27:11.936 Error: EventSystem: in TEST: [string "return {..."]:10: attempt to index a nil value (global 'domoticz')
here the response in raw data from by wallbox
"params" : {
"overdraft" : 0,
"remaining_evse_power" : 14140,
"price_model" : 0,
"cycle_time" : 3009,
"max_evses" : 3,
"time" : 1651298858,
"vsn" :
"vendorid" : 52997,
"productid" : 1,
"cpu" : 24,
"mem" : 57,
"devices" : [
"id" : 1,
"dev_id" : "M3",
"number" : 2,
"com_err" : false,
"com_err_secs" : 17714,
"com_errors" : 31,
"is_evse" : false,
"used_phases" : 0,
"is_mock" : false,
"is_va" : false,
"invert" : false,
"import" : 2770970,
"export" : 4593968,
"power" : -3140,
"current_l1" : -4551,
"current_l2" : -4551,
"current_l3" : -4551,
"voltage_l1" : 0,
"voltage_l2" : 0,
"voltage_l3" : 0,
"role" : 3,
"id" : 3,
"dev_id" : "M2",
"number" : 3,
"com_err" : false,
"com_err_secs" : 503040,
"com_errors" : 0,
"last_error" : "",
"is_evse" : false,
"used_phases" : 0,
"is_mock" : false,
"is_va" : false,
"invert" : false,
"import" : 425261,
"export" : 0,
"power" : 0,
"current_l1" : 0,
"current_l2" : 0,
"current_l3" : 0,
"voltage_l1" : 230,
"voltage_l2" : 230,
"voltage_l3" : 230,
"role" : 4,
"id" : 2,
"dev_id" : "M1",
"number" : 1,
"com_err" : false,
"com_err_secs" : 506329,
"com_errors" : 0,
"last_error" : "",
"is_evse" : false,
"used_phases" : 0,
"is_mock" : false,
"is_va" : false,
"invert" : false,
"import" : 810522,
"export" : 0,
"power" : 37,
"current_l1" : 54,
"current_l2" : 54,
"current_l3" : 54,
"voltage_l1" : 230,
"voltage_l2" : 230,
"voltage_l3" : 230,
"role" : 0,
"name" : "Wallbox",
"address" : "evse",
"id" : 1,
"dev_id" : "E1",
"number" : 1,
"com_err" : false,
"com_errors" : 0,
"last_error" : "",
"is_evse" : true,
"used_phases" : 7,
"is_mock" : false,
"label" : "",
"prio" : 3,
"total_energy" : 8703602,
"phases" : 0,
"state" : 1,
"paused" : false,
"pause_time" : 300,
"ucnt" : 1,
"evse" :
"dc_last_test_time" : "2022-04-28T07:25:18.416Z",
"cp_fault" : false,
"charging" : false,
"current" : 0,
"enabled" : false
It should work
but you are using capital letters for JSON. DZvents is case sensitive!
"item.JSON.params.title" should be "item.json.params.title"
