unknown sensor in Domoticz log
njlammerts
Domoticz version: 2022.2
Post by njlammerts »
Can anyone tell me where the "Pomp_2" , "DeurSensor_1&2" can be found?
These sensors are not present in the current configuration and also there is no sensor triggered at that time
2 weeks ago I had a crash where there was no more communication between devices and Zigbee2mqtt and a had to rebuild from scratch.
I restored the old Domoticz database and had to re-pair all the devices again to get them working again.
2022-01-25 15:14:03.266 Nefit Easy: Temp (Nefit Room Temp)
2022-01-25 15:14:03.464 Nefit Easy: Temp (Nefit Flow Temp)
2022-01-25 15:14:08.646 Pi: General/Percentage (HDD /)
2022-01-25 15:14:08.650 Pi: General/Percentage (HDD /boot)
2022-01-25 15:14:15.038 EventSystem: Event triggered: Pomp_2
2022-01-25 15:14:17.382 Dummy: Light/Switch (Test)
2022-01-25 15:14:17.386 EventSystem: Event triggered: DeurSensor_1
2022-01-25 15:14:17.376 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/On)
2022-01-25 15:14:18.660 Pi: General/Percentage (Pi CPU)
2022-01-25 15:14:18.689 Pi: General/Custom Sensor (Arm Clock Speed)
2022-01-25 15:14:18.721 Pi: General/Custom Sensor (V3D Clock Speed)
2022-01-25 15:14:18.737 Pi: General/Custom Sensor (Core Clock Speed)
2022-01-25 15:14:18.741 Pi: General/Percentage (Pi Mem)
2022-01-25 15:14:18.743 Pi: General/Custom Sensor (Process Usage)
2022-01-25 15:14:19.271 Dummy: Light/Switch (Test)
2022-01-25 15:14:19.277 EventSystem: Event triggered: DeurSensor_2
2022-01-25 15:14:19.265 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/Off)
2022-01-25 15:14:21.566 Dummy: Light/Switch (Test)
2022-01-25 15:14:21.570 EventSystem: Event triggered: DeurSensor_1
2022-01-25 15:14:21.561 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/On)
2022-01-25 15:14:22.286 Dummy: Light/Switch (Test)
2022-01-25 15:14:22.290 EventSystem: Event triggered: DeurSensor_2
2022-01-25 15:14:22.687 Dummy: Light/Switch (Test)
2022-01-25 15:14:22.689 EventSystem: Event triggered: DeurSensor_1
2022-01-25 15:14:22.896 Dummy: Light/Switch (Test)
2022-01-25 15:14:22.898 EventSystem: Event triggered: DeurSensor_2
2022-01-25 15:14:22.281 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/Off)
2022-01-25 15:14:22.685 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/On)
2022-01-25 15:14:22.894 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/Off)
2022-01-25 15:14:23.076 Dummy: Light/Switch (Test)
2022-01-25 15:14:23.078 EventSystem: Event triggered: DeurSensor_1
2022-01-25 15:14:23.225 Dummy: Light/Switch (Test)
2022-01-25 15:14:23.226 EventSystem: Event triggered: DeurSensor_2
2022-01-25 15:14:23.588 Dummy: Light/Switch (Test)
2022-01-25 15:14:23.592 EventSystem: Event triggered: DeurSensor_1
2022-01-25 15:14:23.876 Dummy: Light/Switch (Test)
2022-01-25 15:14:23.880 EventSystem: Event triggered: DeurSensor_2
2022-01-25 15:14:23.073 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/On)
2022-01-25 15:14:23.222 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/Off)
2022-01-25 15:14:23.584 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/On)
2022-01-25 15:14:23.871 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/Off)
2022-01-25 15:14:24.059 Dummy: Light/Switch (Test)
2022-01-25 15:14:24.063 EventSystem: Event triggered: DeurSensor_1
2022-01-25 15:14:24.173 Dummy: Light/Switch (Test)
2022-01-25 15:14:24.177 EventSystem: Event triggered: DeurSensor_2
2022-01-25 15:14:24.055 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/On)
2022-01-25 15:14:24.168 Status: User: Admin (IP: 172.16.10.200) initiated a switch command (1131/Test/Off)
2022-01-25 15:14:27.420 Dummy: Light/Switch (Test)
2022-01-25 15:14:27.425 EventSystem: Event triggered: DeurSensor_2
HansOtten
Domoticz version: 2021-1
Re: unknown sensor in Domoticz log
Post by HansOtten »
Zijn dat Nefit CV ketel sensors?
Hoe heb je dat gekoppeld? wellicht dat daar iets niet werkt.
Raspberry Pi 4, SSD, RFlink, P1 Smart Meter. Many Zigbee devices CR2562 USB stick. Bresser via Weather Underground
Switched to Home Assistant!
njlammerts
Nee, het zijn geen nefit sensoren.
het is opgelost, door het script weg te gooien en opnieuw aan te maken. Mogelijk dat bij de restore van database en bepaalde sensors een andere naam hebben gekregen.
Na opnieuw aanmaken script zijn de unknown sensors niet meer aanwezig
Nefit koppeling kun je hier vinden. i.c.m. remote zigbee CV thermostaat kranen kan ik nu de CV aansturen o.b.v. bepaalde kamer temperaturen waar geen thermostaat staat. Thermostaat kranen in ruimte waar thermostaat hangt 50-90% dichtdraaien en Nefit Script de thermostaat hoger laten zetten dan de werkelijke temperatuur. Hierdoor gaat CV aan en gaat temperatuur naar andere kamers (met auto thermostaat) en temperatuur op deze kamer regelt weer Nefit thermostaat als temperatuur is bereikt.
https://tech.ligthartnet.nl/make-your-n ... -domoticz/
https://www.bol.com/nl/nl/p/alecto-smar ... 126121963/
dit soort kranen is ook via Aliexpress te verkrijgen. maar heb je ook coordinator nodig obv CC2652RB soortgelijke zigbee devices. Genoeg te vinden op het interwebz en diverse projecten op/met Domoticz
