API script /http polling Powerfox Energy tracker
Mirkoser
- Domoticz version: 2021/1
Hello Experts
i'm using Domoticz for several years now and also the dashticz dashboard with Ubuntu 20 on my Intel NUC. But what i missed all the years was a tracking of my power consumption.
Last year i installed my new CFOS powerbrain wallbox and together with this i also installed a Powerfox optical engerie tracker who communicates with the wallbox to realize photovoltaic surplus charging.
Now i want to read the powerfox data with domoticz...Powerfox offers a API interface what is described here https://www.powerfox.energy/wp-content/ ... en-API.pdf
Is anybody able to create a working plugin for that. Or is it realisable with the http polling(there a different polling addresses)? I'm noobish in programming so i need your help to make it work
Thanks Mirko
Thanks Mirko
- Domoticz version: 2026.3
Re: API script /http polling Powerfox Energy tracker
The values of
https://backend.powerfox.energy/api/2.0/my/main/current
Could fill an electricity instant and counter device
https://www.domoticz.com/wiki/Dummy_for ... counter.29
There are several ways to get this filled. I would go for the DzVents script way but this could also be done with python plugin, python script, http Json etc.
The only thing I don't now is how to login.
Mirkoser
Regarding the login.These are my personal credentials from powerfox email / password
The response I get
{"Outdated":false,"Watt":1347.0,"Timestamp":1643054398,"A_Plus":1305727.0,"A_Minus":181798.0}
The response I get
Mirkoser
Ok i added the virtual sensor IDX 1441 name Powerfox_Energy and started with a template for http in DzVents.
Now its not clear for me to put the informations from the http request ({"Outdated":false,"Watt":831.0,"Timestamp":1643100578,"A_Plus":1318663.0,"A_Minus":181798.0}) into the virtual counter ?
timer = {
'every 1 minutes' -- just an example to trigger the request
httpResponses = {
'https://mirkosercc%40googlemail.com:[email protected]/api/2.0/my/main/current' -- must match with the callback passed to the openURL command
logging = {
level = domoticz.LOG_INFO,
marker = 'template',
if (item.isTimer) then
domoticz.openURL({
url = 'https://mirkosercc%40googlemail.com:[email protected]/api/2.0/my/main/current',
method = 'GET',
callback = 'https://mirkosercc%40googlemail.com:[email protected]/api/2.0/my/main/current', -- see httpResponses above.
if (item.isHTTPResponse) then
if (item.ok) then
if (item.isJSON) then
local someValue = item.json.someValue -- just an example
-- update some device in Domoticz
domoticz.devices('myTextDevice').updateText(someValue)
domoticz.log('There was a problem handling the request', domoticz.LOG_ERROR)
domoticz.log(item, domoticz.LOG_ERROR)
You are on the right way.
change line
callback = 'https... etc' to
and line
httpResponses = {
'https.... etc
to
basis of a http dzvents script is below (see also documentation https://www.domoticz.com/wiki/DzVents:_ ... P_requests )
change line
callback = 'Powerfoxtrigger'httpResponses = {
'https.... etc
to
httpResponses = { 'Powerfoxtrigger' }Code: Select all
timer = {'every 5 seconds'},
httpResponses = { 'trigger' }
domoticz.openURL({
url = '...',
callback = 'trigger'
if (item.ok) then
}Domoticz running on Udoo X86 (on Ubuntu)
Additional:
to get the data in a Electricity (instand and counter) dummy device use
.updateElectricity(power, energy) eg domoticz.devices('myCounterDevice').updateElectricity(power, energy)
POWER = current power (Watt) = your json value for "Watt"
ENERGY = total cumulative energy in Watt-hours (Wh) = is your jsan value for "A_Plus"
See also
https://www.domoticz.com/wiki/DzVents:_ ... counter.29
What does "A_Minus" mean? Energy that is returned to the grid?
See also
Mirkoser
Wow thanks for your replies. I will test in the evening.
"What does "A_Minus" mean? Energy that is returned to the grid?" -> Yes the powerfox shows the current power in W , PLus : wh consumed from grid, Minus : sum of wh returned to grid
So the watts could be also negative (if the consumption of my home is less than the solar output)
OK, then perhaps better use a P1 Smart meter instead of a Electricity (instand and counter) dummy device
domoticz.devices('myCounterDevice').updateP1(usage1, usage2, return1, return2, cons, prod)
USAGE1;USAGE2;RETURN1;RETURN2;CONS;PROD
IDX = id of your device (This number can be found in the devices tab in the column "IDX")
USAGE1= total cumulative energy usage meter tariff 1 in Wh. your A_Plus
USAGE2= total cumulative energy usage meter tariff 2 in Wh. (in your case send always 0)
RETURN1= total cumulative energy return meter tariff 1 in Wh. your A_Minus
RETURN2= total cumulative energy return meter tariff 2 in Wh. (in your case send always 0)
CONS= actual usage power (Watt) your Watt
PROD= actual return power (Watt) (if your "Watt" value is negative, but send a positive value)
Mirkoser
Good Morning, i guess i made some steps further but the final hint is missing. This line i do not understand?
do i have to insert the json e.g this /json.htm?type=command¶m=udevice&idx=1453&nvalue=0&svalue=USAGE1;USAGE2;RETURN1;RETURN2;CONS;PROD
But the editor says there is an error near to the question mark??
i get this error log
2022-01-30 09:30:00.242 Error: UpdateMultiMeter: Error converting sValue values! (IDX: 1453, sValue: 'nil;nil;nil;nil;nil;nil', dType: 250, sType: 1)
local someValue = item.json.someValue -- just an exampledo i have to insert the json e.g this /json.htm?type=command¶m=udevice&idx=1453&nvalue=0&svalue=USAGE1;USAGE2;RETURN1;RETURN2;CONS;PROD
timer = {
'every 20 seconds' -- just an example to trigger the request
httpResponses = { 'Powerfoxtrigger' } -- must match with the callback passed to the openURL command
logging = {
marker = 'Powerfox',
domoticz.openURL({
method = 'GET',
callback = 'Powerfoxtrigger', -- see httpResponses above.
if (item.ok) then
domoticz.devices('Stromverbrauch').updateP1(usage1, usage2, return1, return2, cons, prod)
IDX = '1453'
USAGE1= 'A_Plus'--total cumulative energy usage meter tariff 1 in Wh. your A_Plus
USAGE2= '0'--total cumulative energy usage meter tariff 2 in Wh. (in your case send always 0)
RETURN1= 'A_Minus'--total cumulative energy return meter tariff 1 in Wh. your A_Minus
RETURN2= '0'--total cumulative energy return meter tariff 2 in Wh. (in your case send always 0)
CONS= 'Watt'--actual usage power (Watt) your Watt
PROD= 'Watt'--actual return power (Watt) (if your "Watt" value is negative, but send a positive value)
You have the order wrong.
From the openurl command you get a JSON from your meter.
From that JSON you have to read all the attributes that you can send to domoticz with the .updateP1() function.
So for example
local USAGE1 = item.json.A_Plus
local RETURN1 = item.json.A_Minus
etc.
For Watt you need first a check if it is positive or negative and then set CONS and PROD with the correct values
Be aware that variables are case sensitive in DzVents so use USAGE1 or usage1 all the way.
And better add some extra logging so you can see what you get. First try to get all the variables out, send the to the log and then send them to the P1 device.
So for example
etc.
Mirkoser
Ok i will try to put the variables from the http to the log first. Step by step:) Sorry but I’m not so familiar with that kind of programming. In the Wiki I miss some concrete examples who would help me to understand
In the DzVents example forum there are a lot of examples for reading a JSON file and send the values to Domoticz like viewtopic.php?f=72&t=23406&hilit=Item.json
Mirkoser
So almost finished, still need to adjust the unit. The Json value is Wh and i need to devide by 1000 to get the right values displayed in Domoticz P1 counter..
and i need an if for the negative value of watt...
timer = {
'every minute' -- just an example to trigger the request
logging = {
domoticz.openURL({
method = 'GET',
if (item.ok) then
local CONS = item.json.Watt
domoticz.log(item.json.A_Plus , domoticz.LOG_INFO)
domoticz.log(item.json.A_Minus, domoticz.LOG_INFO)
domoticz.log(item.json.Watt, domoticz.LOG_INFO)
domoticz.log('Success updating receiving http values', domoticz.LOG_INFO)
domoticz.devices('Stromverbrauch').updateP1(item.json.A_Plus, '0', item.json.A_Minus, '0', item.json.Watt , '0')
domoticz.log('Success updating Device P1', domoticz.LOG_INFO)
}- waltervl
The divider is done by Domoticz setting for divider (in menu Setup - Settings tab Counter)
So you have to always supply Wh values for P1 (and also other Electricity Counters)!
See also https://www.domoticz.com/wiki/Domoticz_ ... mart_meter
Perhaps also try to supply integer values and not fractional eg 1305727.0 if you run into strange results.
Mirkoser
ok, but why still a dot is shown? i activated the p1 "no decimals" in the settings
What values are you sending according your log?
What is the setting of menu Setup - Settings tab Counter?
Mirkoser
so it should show me 1434 Kwh , 196Kwh , 2991W
If i get a negative value from the powerfox for Watt it will not work and i have no idea how to realize it in the script
There is an issue with decimals yes or no especially on graphs.
So that seemsnto be a bug.
I will come back for the negative value.
DzVents is based on Lua so math.abs() function should work.
It would perhaps also help to use math.floor() to get numbers without decimals. math.floor(1234.0) will give 1234
GetWatt = item.json.Watt
If GetWatt < 0 then
CONS = 0
PROD = math.abs(GetWatt)
CONS = GetWatt
PROD = 0
