.checkFirst() not working on Fibaro Roller Shutter
Ragdag
Post by Ragdag »
Have a small dzVents script that will close blind if luminance is below X
Had it like this.
	if (tonumber(domoticz.devices(Illuminance).state) > 10) then
            domoticz.devices(RolluikLinks).open().checkFirst()
            domoticz.devices(RolluikRechts).open().checkFirst()
But after each device update that triggers the script I hear the clicking of the Fibaro Roller Shutter modules and not doing anything. So it would try to open them even when they are already open.
Changing the script to this works as expected:
            if (domoticz.devices(RolluikLinks).state == 'Closed') then
            if (domoticz.devices(RolluikRechts).state == 'Closed') then
Domoticz version: 2025.1
Re: .checkFirst() not working on Fibaro Roller Shutter
Seems that you have probably found a bug.
Perhaps try with .On().checkFirst() or .Off().checkFirst()
Blinds are a little bit confusing in what is Open/Close related to On/Off There are also inverted Blinds devices.
Else you perhaps found a bug. Unfortunately the main maintainer of DzVents passed away half a year ago :( so fixing it will be troublesome.
Ragdag
Post by Ragdag »
waltervl wrote: Tuesday 16 November 2021 17:41 Else you perhaps found a bug. Unfortunately the main maintainer of DzVents passed away half a year ago :( so fixing it will be troublesome.
I did not know that, how sad and horrible.
Tried this small snippet
local RolluikLinks = 116
local RolluikRechts = 106
		timer = {
			'every minute',				-- causes the script to be called every minute
	logging = {
		level = domoticz.LOG_DEBUG,
		marker = 'template',
	execute = function(domoticz, timer)
		domoticz.log('Timer event was triggered by ' .. timer.trigger, domoticz.LOG_INFO)
		    domoticz.devices(RolluikLinks).On().checkFirst()
            domoticz.devices(RolluikRechts).On().checkFirst()
Gives me this error:
2021-11-17 09:53:00.144 Error: dzVents: Error: (3.1.8) template: ...domoticz/scripts/dzVents/generated_scripts/Script #1.lua:15: attempt to call a nil value (field 'On')
gizmocuz
Post by gizmocuz »
@Walter, As you know Domoticz is a open source project and various developers are contributing to it.
I think someone will continue with dzVents or pushes some fixes.
So please do not tell people development stopped...
gizmocuz wrote: Sunday 23 January 2022 10:24 So please do not tell people development stopped...
? I did not tell that? So until someone picks this up, dzVents fixes will be troublesome (not saying stopped).
gizmocuz
Post by gizmocuz »
Doesn't this goes for everything ? If there is a problem in part X of the/any software and nobody fixes it, it stays a issue ?
And when someone makes a PR it is solved?
That is how it always works
solarboy
Domoticz version: 2024.6
Post by solarboy »
I also use this device and I recently had to change a module for exactly the same device using the replace function. The new device doesn't respond to commands in dzVents and throws an error, wether using "open()" , "close()" or "setLevel(50)".
 2025-05-24 14:46:31.417 Error: dzVents: There is no device with that name or id: 3776
2025-05-24 14:46:31.419 Error: dzVents: An error occurred when calling event handler B1 Small Shutter Control DZ
2025-05-24 14:46:31.419 Error: dzVents: ...zVents/generated_scripts/B1 Small Shutter Control DZ.lua:30: attempt to index a nil value (local 'shutter')
However I can control it via it's switch device and also via blockly so for now I have created a dummy level device which I set in dzvents which then sets the shutter position in blockly.
A strange bug !
solarboy
Post by solarboy »
On further examination, "Set Level" also doesn't work in Blockly either, only "Open" and "Close".
solarboy wrote: Saturday 24 May 2025 15:48 I also use this device and I recently had to change a module for exactly the same device using the replace function. The new device doesn't respond to commands in dzVents and throws an error, wether using "open()" , "close()" or "setLevel(50)".
A strange bug !
What is the device type in Domoticz? And what is the integration you use (Openzwave or Zwave-JS-UI?)
And are there more devices with exactly the same name as Dzvents does not like that.
madpatrick
Domoticz version: 2025.2
Post by madpatrick »
Not sure what kind of device you are using, but within my script i'm using the following command in DzVents
	local Screen_Slaapkamer = dz.devices(613)
        Screen_Slaapkamer.switchOn().checkFirst()
or
           	Screen_Slaapkamer.dimTo(50)
Users browsing this forum: Doler and 1 guest
