Dashticz - latest beta - Howto change font-size x-axis and legend graph Topic is solved
Maikel76
Domoticz version: 2022.1
Post by Maikel76 »
Goodday,
Really loving the new graph possibilities. Finetuned a lot of stuff
Now I would like to change font-size of the x-axis and also the font of the legend underneath. I have a rather small and full ipad so efficient use of space is priority
this is my CONFiG.js
blocks['my_graph'] = {
       title: 'Avg temp',
        devices: [13, 95, 97, 99, 98],
        graph: 'line',
        graphTypes: ['l','l','te','te','te'],
        lineTension: 0.4,
        width: 8,
        height: '125px',
            legend: {
                te_13:"now",
                te_95:"avg",
                te_97:"set",
                l_99:"din",
                l_98:"AC on"
        lineFill: [false,false,false, true, true],
        datasetColors: ['grey','red','orange','green','rgba(44,130,201,0.5)'],
        debug: false
this is my custom.css
.dt_block[data-id='my_graph'] {                     /* graph temp*/
     padding-top: 0px !important;
     padding-bottom: 0px !important;
.graphheader,
.graphbuttons {
  display: none;
The "font-size: 9px;" with or without !important doest effect x-axis and legend
Also, is there an option to change the large rectangular blocks for small square ones?
this is how the legend looks now;
Scripting is my passion, dzVents, LUA, Bash
Dashticz v3.10.7 Beta --Raspbian Buster
Creo2005
Re: Dashticz - latest beta - Howto change font-size x-axis and legend graph
Post by Creo2005 »
What theme?
Maikel76
Post by Maikel76 »
Creo2005 wrote: Thursday 13 January 2022 11:16What theme?
in CONFIG.js it says;
config['theme'] = 'default';
Lokonli
Post by Lokonli »
Maikel76 wrote: Thursday 13 January 2022 10:39 Goodday,
       title: 'Avg temp',
        graph: 'line',
        lineTension: 0.4,
        width: 8,
        height: '125px',
            legend: {
                te_13:"now",
                te_95:"avg",
                te_97:"set",
                l_99:"din",
                l_98:"AC on"
        debug: false
.graphheader,
.graphbuttons {
  display: none;
The graph elements are no normal HTML elements, but drawn on a canvas by the Chartjs module. That means they can be styled via custom.css.
But, since the goal of Dashticz is to maximize customization options, also for the graphs there is a possibility. However, it's a bit more complex, so only suitable for advanced usage.
While doing some tests, I noticed it was not possible anymore to customize the Y-axes. In the mean time I've fixed that in the latest beta.
Assuming you are running latest beta, you can customize the the font size of x and Y axes and the width of the graph legend via the 'options' block parameter as follows:
    options: {
        scales: {
            xAxes: [{
                   ticks: {
                    fontSize: 7
            yAxes: [{
                ticks: {
                 fontSize: 7,
                scaleLabel: {
                    fontSize: 7
        legend:{
            labels:{
                fontSize:10,
                boxWidth:10
If you are testing, I would advice to first literally copy the code above into your graph block definition. After that you can start adjusting the parameters.
Enjoy.
Maikel76
Post by Maikel76 »
Lokonli wrote: Thursday 13 January 2022 21:25
       title: 'Avg temp',
        graph: 'line',
        lineTension: 0.4,
        width: 8,
        height: '125px',
            legend: {
                te_13:"now",
                te_95:"avg",
                te_97:"set",
                l_99:"din",
                l_98:"AC on"
        debug: false
.graphheader,
.graphbuttons {
  display: none;
    options: {
        scales: {
            xAxes: [{
                   ticks: {
                    fontSize: 7
            yAxes: [{
                ticks: {
                 fontSize: 7,
                scaleLabel: {
                    fontSize: 7
        legend:{
            labels:{
                fontSize:10,
                boxWidth:10
Enjoy.
Hi Lokonli,
Thanks for the extra information, really apreciate that you make these kind of options available through CONFIG.js since that is probably more futureproof than through css (although it's great that option is also available)
It's working like a charm and exactly as I wished, many thanks!
Could ask if it's also possible to add the following graph-type in the graphs module or is it better to make a new topic?
The domoticz device is a Mikrotik Router (https://github.com/mrin/domoticz-routeros-plugin) with value for axis-label Mbit/s. Upstream and downstream are seperate devices
This is the JSON data for device idx 100 (upstream in Mbit/s, downstream is idx 101 also in Mbit/s)
http://ip:port/json.htm?type=devices&rid=100
	"ActTime" : 1642160390,
	"AstrTwilightEnd" : "19:23",
	"AstrTwilightStart" : "05:30",
	"CivTwilightEnd" : "18:31",
	"CivTwilightStart" : "06:22",
	"DayLength" : "11:23",
	"NautTwilightEnd" : "18:57",
	"NautTwilightStart" : "05:56",
	"ServerTime" : "2022-01-14 18:39:50",
	"SunAtSouth" : "12:27",
	"Sunrise" : "06:45",
	"Sunset" : "18:08",
	"app_version" : "2021.1",
	"result" :
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"BatteryLevel" : 255,
			"CustomImage" : 106,
			"Data" : "0.07 Mbit/s",
			"Description" : "",
			"Favorite" : 0,
			"HardwareDisabled" : false,
			"HardwareID" : 9,
			"HardwareName" : "MikroTik",
			"HardwareType" : "Mikrotik RouterOS",
			"HardwareTypeVal" : 94,
			"HaveTimeout" : false,
			"ID" : "00090001",
			"Image" : "mikrotik-routeros-winbox",
			"LastUpdate" : "2022-01-14 18:39:23",
			"Name" : "MikroTik - Bandwidth UP",
			"Notifications" : "false",
			"PlanID" : "0",
			"PlanIDs" :
				0
			"Protected" : false,
			"SensorType" : 1,
			"SensorUnit" : "Mbit/s",
			"ShowNotifications" : true,
			"SignalLevel" : "-",
			"SubType" : "Custom Sensor",
			"Timers" : "false",
			"Type" : "General",
			"TypeImg" : "mikrotik-routeros-winbox",
			"Unit" : 1,
			"Used" : 1,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "100"
	"status" : "OK",
	"title" : "Devices"
Thanks again for all your effort
Lokonli
Post by Lokonli »
Maikel76 wrote: Friday 14 January 2022 12:46 Could ask if it's also possible to add the following graph-type in the graphs module or is it better to make a new topic?
Yes, please create a new topic, and I'll answer it there.
Maikel76
Post by Maikel76 »
Lokonli wrote: Friday 14 January 2022 16:00
Ok thanks, will do that now
