I recently upgraded the Zigate firmware to 0321 and took the plunge to the new OPDM version so had to re-pair all my devices which has (mostly) gone smoothly.
I upgraded to the latest Zigate plugin at same time 6.0.001
My Linkind Door and Window sensors would re-register when I re-did the pairing on the device however the open/close status would not update.
So I deleted the device from Domoticz and did a re-pair and the log is included below. The device is created in Domoticz but it fails to update with open/close status.
Not sure if this is a Zigate firmware issue or if it is when I updated the Plugin (it was working fine on ~5.17)
2022-01-10 20:46:48.394 Status: Zigate: (Zigate) Request Accepting new Hardware for ever
2022-01-10 20:46:48.609 Status: Zigate: (Zigate) Accepting new Hardware: Enable (On)
2022-01-10 20:46:57.275 Status: Zigate: (Zigate) [None] NEW OBJECT: ee93 None
2022-01-10 20:46:58.200 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Active Endpoint Response Ep: 01 LQI: 93
2022-01-10 20:46:58.201 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Request Simple Descriptor for Ep: 01
2022-01-10 20:46:58.723 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Simple Descriptor Response EP: 0x01 LQI: 96
2022-01-10 20:46:58.723 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 ProfileID 0104
2022-01-10 20:46:58.723 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 ZDeviceID 0402
2022-01-10 20:46:58.724 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Application Version 0000
2022-01-10 20:46:58.724 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Cluster IN Count: 06
2022-01-10 20:46:58.724 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Cluster In 1: 0000 (Basic)
2022-01-10 20:46:58.725 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Cluster In 2: 0001 (Power Configuration)
2022-01-10 20:46:58.725 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Cluster In 3: 0003 (Identify)
2022-01-10 20:46:58.725 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Cluster In 4: 0020 (Poll Control)
2022-01-10 20:46:58.726 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Cluster In 5: 0500 (IAS Zone)
2022-01-10 20:46:58.726 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Cluster In 6: 0b05 (Diagnostics)
2022-01-10 20:46:58.726 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Cluster OUT Count: 01
2022-01-10 20:46:58.727 Status: Zigate: (Zigate) [-] NEW OBJECT: ee93 Cluster Out 1: 0019 (Over-the-Air Upgrade)
2022-01-10 20:46:59.116 Status: Zigate: (Zigate) [None] NEW OBJECT: ee93 Request Node Descriptor
2022-01-10 20:47:04.072 Status: Zigate: (Zigate) [1] NEW OBJECT: ee93 Model Name: ZB-DoorSensor-D0003
2022-01-10 20:47:09.067 Status: Zigate: (Zigate) [2] NEW OBJECT: ee93 Model Name: ZB-DoorSensor-D0003
2022-01-10 20:47:09.067 Error: Zigate: (Zigate) 'onHeartbeat' failed 'KeyError'.
2022-01-10 20:47:09.067 Error: Zigate: (Zigate) ----> Line 1390 in '/home/john/domoticz/plugins/Domoticz-Zigate/plugin.py'
2022-01-10 20:47:09.067 Error: Zigate: (Zigate) ----> Line 877 in '/home/john/domoticz/plugins/Domoticz-Zigate/plugin.py'
2022-01-10 20:47:09.067 Error: Zigate: (Zigate) ----> Line 784 in '/home/john/domoticz/plugins/Domoticz-Zigate/Modules/heartbeat.py'
2022-01-10 20:47:09.067 Error: Zigate: (Zigate) ----> Line 103 in '/home/john/domoticz/plugins/Domoticz-Zigate/Modules/pairingProcess.py'
2022-01-10 20:47:09.067 Error: Zigate: (Zigate) ----> Line 354 in '/home/john/domoticz/plugins/Domoticz-Zigate/Modules/pairingProcess.py'
2022-01-10 20:47:09.067 Error: Zigate: (Zigate) ----> Line 396 in '/home/john/domoticz/plugins/Domoticz-Zigate/Modules/pairingProcess.py'
2022-01-10 20:47:09.067 Error: Zigate: (Zigate) ----> Line 416 in '/home/john/domoticz/plugins/Domoticz-Zigate/Modules/pairingProcess.py'
2022-01-10 20:47:09.067 Error: Zigate: (Zigate) ----> Line 515 in '/home/john/domoticz/plugins/Domoticz-Zigate/Modules/pairingProcess.py'
Linkind door window sensor Zigate plugin issue
Re: Linkind door window sensor Zigate plugin issue
can you try to retreive beta-6.00.2
Wiki is available here.
Zigbee for Domoticz FAQ
Thanks for the response. Upgraded to .2
Different error this time:
2022-01-10 21:12:56.104 Status: Zigate: (Zigate) onDeviceRemoved - removing End Device
2022-01-10 21:12:56.108 Status: Zigate: (Zigate) Device Zigate - ZB-DoorSensor-D0003_Voltage-84fd27fffe697391-01 with IEEE: 84fd27fffe697391 fully removed from the system.
2022-01-10 21:12:56.116 Status: Zigate: (Zigate) onDeviceRemoved - removing Device Zigate - ZB-DoorSensor-D0003_Voltage-84fd27fffe697391-01 -> 84fd27fffe697391 in Zigate
2022-01-10 21:13:04.039 Status: Zigate: (Zigate) Request Accepting new Hardware for ever
2022-01-10 21:13:04.240 Status: Zigate: (Zigate) Accepting new Hardware: Enable (On)
2022-01-10 21:13:10.652 Status: New sensors allowed for 5 minutes...
2022-01-10 21:13:37.711 Status: Zigate: (Zigate) [None] NEW OBJECT: 5512 None
2022-01-10 21:13:49.061 Status: Zigate: (Zigate) [2] NEW OBJECT: 5512 0045
2022-01-10 21:14:04.082 Status: Zigate: (Zigate) [5] NEW OBJECT: 5512 0045
2022-01-10 21:14:09.068 Error: Zigate: (Zigate) [6] NEW OBJECT: 5512 Not able to get all needed attributes on time
2022-01-10 21:14:09.068 Error: Zigate: (Zigate) processNotinDB - not able to find response from 5512 stop process at 0045
2022-01-10 21:14:09.068 Error: Zigate: (Zigate) processNotinDB - Collected Infos are : {'Version': '3', 'ZDeviceName': '', 'Status': 'UNKNOW', 'SQN': '', 'Ep': {}, 'Heartbeat': '1', 'RIA': '6', 'LQI': {}, 'Battery': {}, 'Model': '', 'ForceAckCommands': [], 'MacCapa': '80', 'IEEE': '84fd27fffe697391', 'Type': {}, 'ProfileID': {}, 'ZDeviceID': {}, 'App Version': '', 'Attributes List': {}, 'DeviceType': 'RFD', 'HW Version': '', 'Last Cmds': [], 'LogicalType': 'End Device', 'Manufacturer': '', 'Manufacturer Name': '', 'NbEp': '', 'PowerSource': '', 'ReadAttributes': {}, 'ReceiveOnIdle': '', 'Stack Version': '', 'Stamp': {'time': 1641849220.8259242, 'Time': '2022-01-10 21:13:40', 'MsgType': '8011', 'LastSeen': 1641849220}, 'ZCL Version': '', 'Health': 'Live', 'Capability': ['Reduced-Function Device', 'Standard security', 'NwkAddr should be allocated'], 'PairingInProgress': True, 'ConsistencyCheck': 'Bad Pairing'}
I would restart the plugin and try the pairing once more
Working perfectly now - thanks!
