Python 3.7 does not work
sailmich
Rpi zero with Raspian buster light. Beta 4.10977
I did a fresh installation with all apt-get updates. I put gbridge plugin in the correct folder. After restart I would select gbridge in hardware drop down menue but it isn't there. In domoticz log I got Failed dynamic library load, install the latest libpython3.x library
I double checked that latest libpython3 is installed and matched to python version. Is it a problem with buster/domoticz or Python3.7/domoticz?
Appreciate every hint
Re: Python 3.7 does not work
Go back to Stretch, because you might encounter more problems with Buster on the way.
B.t.w. my test system runs fine. Did not test any plugin yet, but no error at startup of Domoticz.
Did you install the dev system?
Status: PluginSystem: Started, Python version '3.7.3'.Code: Select all
sudo apt-get install python3-dev-
sailmich
I will go back to stretch. And yes I had python3-dev installed.EddyG wrote: Saturday 13 July 2019 21:01 Go back to Stretch, because you might encounter more problems with Buster on the way.
B.t.w. my test system runs fine. Did not test any plugin yet, but no error at startup of Domoticz.Did you install the dev system?Code: Select all
Thanks for your answer and comments!
- Solderbro
- Domoticz version: 2020.1
running buster light here and the python3-dev is a must to get the library to the system. Everything else works at a glance with buster-stable.
Solderbro
Solderbro
Raspi 3B+RTC, SSD 128GB, Aeotec Gen5, Eurotronic SpiritZ, Fibaro FRGBW, Zipato PIR, Everspring AN180, Neo Coolcam Plug, Fibaro FGMS, Neo Coolcam Doorsensor, Popp Z-Weather
Thorgal789
- Target OS: -
Hello, by curiosity, if you have buster and python 3.7 I presume ? Can you make a try with a python plugin and the lib requests ?
Just insert a
At the top of a plugin. It seem domoticz is crashing in this situation.
Just insert a
import requests- Solderbro
it looks like this but domoticz stay on schedule here
2019-08-03 07:51:21.936 Error: EventSystem: Failed to execute python event script "Test"
2019-08-03 07:51:21.936 Error: EventSystem: Traceback (most recent call last):
2019-08-03 07:51:21.936 Error: EventSystem: File "<string>", line 1, in <module>
2019-08-03 07:51:21.937 Error: EventSystem: ModuleNotFoundError: No module named 'requests'
I would suggest to downgrade python packages instead of using an older debian stable. Until domoticz parts are upgraded to work better with python 3.7
Solderbro
Solderbro
- Dnpwwo
On a fresh buster (minimal) build running Python 3.7.3 the requests library import worked in Python and Domoticz.
Built from source as per instructions on the wiki.
Default version of Python for the OS (which I always recommend), requests was already installed according to pip3
Thorgal789
- Target OS: -
@Solderbro, Can you try
To install the missing lib. And yes it's that he have do, he is still on buster but python 3.5 now, but for me it's not a good solution, python 3.7 ill be soon a new standard.
@Dnpwwo, so on your side, if you make a complete build it works ? You haven't make a try with a normal install ?
pip3 install requests@Dnpwwo, so on your side, if you make a complete build it works ? You haven't make a try with a normal install ?
- Solderbro
Yes the phyton-pip package was missing, it pulled 32MB of further packages that are installed now.
The result is
2019-08-03 15:16:22.055 Error: EventSystem: Failed to execute python event script "Test2"
2019-08-03 15:16:22.056 Error: EventSystem: File "<string>", line 1
2019-08-03 15:16:22.056 Error: EventSystem: pip3 install requests
2019-08-03 15:16:22.056 Error: EventSystem: ^
2019-08-03 15:16:22.056 Error: EventSystem: SyntaxError: invalid syntax
Solderbro
The result is
Solderbro
Thorgal789
- Target OS: -
"pip3 install requests" is to install the lib, just type in on the console/terminal, on the python file it's still "import requests".
- Solderbro
Some packages did miss, so i installed both sides
domoticz@domosys:~/domoticz/www/styles $ pip --version
pip 18.1 from /usr/lib/python2.7/dist-packages/pip (python 2.7)
domoticz@domosys:~/domoticz/www/styles $ pip3 --version
pip 18.1 from /usr/lib/python3/dist-packages/pip (python 3.7)
pip3 requests in now installed too, i see that there is lot of stuff to install by hand if for example the SD Card wears out.
domoticz@domosys:~/domoticz/www/styles $ pip3 install requests
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: requests in /usr/lib/python3/dist-packages (2.21.0)
But back to the first test script
2019-08-04 17:52:09.342 Error: EventSystem: Failed to execute python event script "Test"
2019-08-04 17:52:09.342 Error: EventSystem: Traceback (most recent call last):
2019-08-04 17:52:09.342 Error: EventSystem: File "<string>", line 1, in <module>
2019-08-04 17:52:09.342 Error: EventSystem: ModuleNotFoundError: No module named 'requests'
Incompatible in some way:-/
Thorgal789
- Target OS: -
From my memory, there was same bug before the last stable (need to add something like sys.path.insert(0,'/usr/local/lib/pythonX.X/dist-packages/') to code), but with all version after this one, the import is now working alone.
It's not the same problem but BTW thx a lot for yours tests ^^.
- Dnpwwo
@Solderbro,
Python packages with pip3 need to be installed using 'sudo' (i.e 'sudo pip3 install requests')
Thorgal789
- Target OS: -
Arf, I haven't see, my fault.
This night I will make a try on windows, and I have an old raspberry 2, just need to find another sd card to test.
Edit 1:
Works perfectly by defaut on windows and pyton 3.7.4
Edit 1:
Is that still valid , or can we install he Python packages on the local user running domoticz ?Dnpwwo wrote: Sunday 04 August 2019 23:33 @Solderbro,
- Domoticz version: 2025.1
It depends what user is running Domoticz service. From the default installation it seems to be user root (but I am not sure)
