I have several Fibaro Roller Shutters FGR223 in use. Domoticz is 2021.1 on Raspi 3 with Raspbian Buster.
Goal: I don't want the to be locked out on my terrace in the evening by an automatic shutter close.
Approach:
When I set the roller shutter manually via wall switch I disable time based events for a certain time period e.g. for 4 hours.
My main question:
Is it possible to distinguish between manual setting via wall switch/GUI and time events?
Use of door contacts is not wanted!
distinguish between manual setting and time based events
- Domoticz version: 2023.2
Raspberry Pi 3B+
Raspbian GNU/Linux 12 (bookworm) / 6.1.61-v7+
Version: 2023.2
Build Hash: 19efd039c
Compile Date: 2023-07-21 17:23:44
dzVents Version: 3.1.8
Python Version: 3.11.2 (main, Mar 13 2023, 12:18:29) [GCC 12.2.0]
Version: 2023.2
Re: distinguish between manual setting and time based events
So if you forget to set the switch you still will be locked out?
I use a door contact in a dzVents script, so a wallswitch could be used the same way in dzVents.
Check the switch before the shutdown of the shutter close.
Really my first try was with a door contact together with the Fibaro FGBS222 Smart Implant+ and a small power supply. But I couldn't get it working (guess there's a heating issue when the parts are placed in the wall behind the Roller shutter module and the switch).
The switch is a single, momentary switch, one push moves up the shutter. Another push stops the shutter.
A second switch is for moving down the shutter. So I have no stable state.
Raspberry Pi 3B+
Version: 2023.2
Version: 2023.2
If you set the timer on the device itself (i.e. via the 'timer' button) that is unconditional: there is no option to add checking for an additional switch or anything. But, if you have a (dummy) switch that switches on the timer, then have a script that switches the roller-shutters depending on the state of the switch, in this script you can add a condition like a 'disable' switch or something.
Assuming you have:
- 1 (dummy) switch "shutters" with a timer when you want to open and close the shutters automatically,
- 1 (dummy) switch "override timer" (switches between Auto and Open),
- 2 roller shutters "shutter 1" and "shutter 2" (no timers on these).
You could use a script like this:
Assuming you have:
local SHUTTERS_NAME = "shutters"
local FORCE_OPEN_NAME = "override timer"
local SHUTTERS_NAMES = { "shutter 1", "shutter 2" }
devices = {
SHUTTERS_NAME,
FORCE_OPEN_NAME
shutters = domoticz.devices(SHUTTERS_NAME)
force_open = domoticz.devices(FORCE_OPEN_NAME)
if nil == shutters then
domoticz.log('Device ' .. SHUTTERS_NAME .. ' not found.', domoticz.LOG_ERROR)
elseif nil == force_open then
domoticz.log('Device ' .. FORCE_OPEN_NAME .. ' not found.', domoticz.LOG_ERROR)
domoticz.devices(SHUTTERS_NAMES).forEach(
function(shutter)
if shutters.bState or force_open.bState then
if shutter.level < 100 then
shutter.setLevel(100) -- open
if shutter.level > 0 then
shutter.setLevel(0) -- close
Thank you for giving me advice.
Meanwhile I have implemented a solution with a virtual switch. When switch is set then my time triggered shutter script does not execute.
I think about a countdown on this virtual switch in this way:
When the switch is pressed a timer value is set to 240 minutes. A countdown script counts the timer value down to 0. During that time the shutter script will not be executed.
Raspberry Pi 3B+
Version: 2023.2
Version: 2023.2
Please share the script how you solved that.
Here is my approach:
Code for the Timeout counter and the virtual switch.
The code is triggered either by time interval to countdown the timeout value or device action(virtual switch, created via "Create Virtual Sensors")
For demo purpose I have set timer interval to 1 minute and the timeout value to 3 minutes.
And this is the relevant code snippet for the shutter. It prevents moving the 3 shutters 'RS Kueche' , 'RS WZ li' , 'RS WZ re' when virtual switch is 'On'
Here is a sample log
2022-01-05 15:43:19.870 Status: User: Admin (IP: 192.168.11.21) initiated a switch command (377/RS Stop/On)
2022-01-05 15:43:20.034 Status: dzVents: Info: Handling events for: "RS Stop", value: "On"
2022-01-05 15:43:20.034 Status: dzVents: Info: lockRS: ------ Start internal script: lockRS: Device: "RS Stop (Virtual)", Index: 377
2022-01-05 15:43:20.035 Status: dzVents: Info: lockRS: RS Timeout - set to 3 minutes
2022-01-05 15:43:20.057 Status: dzVents: Info: lockRS: ------ Finished lockRS
2022-01-05 15:44:00.429 Status: dzVents: Info: lockRS: ------ Start internal script: lockRS:, trigger: "every 1 minutes"
2022-01-05 15:44:00.430 Status: dzVents: Info: lockRS: RS Timeout - remaining 2 minutes
2022-01-05 15:44:00.448 Status: dzVents: Info: lockRS: ------ Finished lockRS
2022-01-05 15:45:00.457 Status: dzVents: Info: lockRS: ------ Start internal script: lockRS:, trigger: "every 1 minutes"
2022-01-05 15:45:00.458 Status: dzVents: Info: lockRS: RS Timeout - remaining 1 minutes
2022-01-05 15:45:00.477 Status: dzVents: Info: lockRS: ------ Finished lockRS
2022-01-05 15:45:00.477 Status: dzVents: Info: setRSTimeBasedv6: ------ Start internal script: setRSTimeBasedv6:, trigger: "at 15:45"
2022-01-05 15:45:00.495 Status: dzVents: Info: setRSTimeBasedv6: RS Kueche - action locked for 1 minutes - (switch "RS Stop" set, to enable normal behaviour: set switch "RS Stop" off)
2022-01-05 15:45:00.514 Status: dzVents: Info: setRSTimeBasedv6: ------ Finished setRSTimeBasedv6
2022-01-05 15:46:00.471 Status: dzVents: Info: lockRS: ------ Start internal script: lockRS:, trigger: "every 1 minutes"
2022-01-05 15:46:00.493 Status: dzVents: Info: lockRS: RS Timeout - reset by timer plan
2022-01-05 15:46:00.549 Status: dzVents: Info: lockRS: ------ Finished lockRS
local INTERVAL = 5
local INTERVAL = 1
local TIMEOUT = 240
local TIMEOUT = 3
local PROG = 'lockRS'
local logToFile = true
local tmpLogFile = '/var/log/domoticz/RS.log'
devices = {
'RS Stop'
timer = {
'every ' .. INTERVAL .. ' minutes'
data = {
mailTo = { initial = 'root@localhost' }
logging = {
level = domoticz.LOG_INFO,
marker = PROG
execute = function(dz, item, info)
local idxRSStop = dz.globalData.idxRSStop
--dz.log('RS Stop')
logheader = os.date('%Y-%m-%d %H:%M:%S ',os.time()) .. '-' .. PROG .. '-'
if item.isTimer then
if dz.globalData.RSStopTime > 0 then
if (dz.globalData.RSStopTime - INTERVAL) <= 0 and dz.devices(idxRSStop).state == 'On' then -- reset timeout value
dz.globalData.RSStopTime = 0
dz.devices(idxRSStop).setState('Off').silent()
logtext = 'RS Timeout - reset by timer plan'
else -- count down timeout value
dz.globalData.RSStopTime = dz.globalData.RSStopTime - INTERVAL
logtext = 'RS Timeout - remaining ' .. tostring(dz.globalData.RSStopTime) .. ' minutes'
else -- nothing to do
return 0
elseif item.isDevice then -- virtual switch hit
--item.dump()
if item.state == 'On' then -- switch set on -> set timeout value
dz.globalData.RSStopTime = TIMEOUT
logtext = 'RS Timeout - set to ' .. tostring(dz.globalData.RSStopTime) .. ' minutes'
else -- switch set off - reset timeout value
logtext = 'RS Timeout - reset by manual action'
logtext = info.scriptName .. ': Triggered by unknown event'
dz.log(logtext)
dz.email('message from your lockRS script', logtext, dz.data.mailTo)
if logToFile then os.execute('echo ' .. logheader .. logtext .. ' >>' .. tmpLogFile) end
if ( name == 'RS Kueche' or name == 'RS WZ li' or name == 'RS WZ re') and dz.devices(idxRSStop).state == 'On' then
logtext = ' ' .. name .. ' - action locked for ' .. timeout .. ' minutes - (switch "RS Stop" set, to enable normal behaviour: set switch "RS Stop" off)'
dz.log(logtext)
dz.devices(id).setLevel(lev).withinMin(2)
--dz.devices(id).setLevel(lev).silent()
logtext = ' ' .. name .. ' level set from ' .. curLevel .. '% to ' .. lev .. '%'
dz.log(logtext)
--curLevel = dz.devices(id).level
--logtext = ' ' .. name .. ' new level ' .. curLevel .. '%'
--dz.log(logtext)
--if logToFile then os.execute('echo ' .. logheader .. logtext .. ' >>' .. tmpLogFile) end
Raspberry Pi 3B+
Version: 2023.2
Version: 2023.2
