'Dromotica' app for controlling Domoticz from Android
maluko
Re: Android app
Post by maluko »
hi sebas
Are you think about translate this app to others languages?
If you need help with PT tanslate, send me PM.
tommysharp
Re: Android app
Post by tommysharp »
blackstrider wrote:This might sound a bit of gimmick, what about voices control to show off to our friend and family plus apple fan boys.
I currently use AutoVoice and Tasker to achieve this.... I also use this great android app but the main benefit is it works without having open any ups.... The Nexus 5 phone is always listening even with the screen off, so long as it's charging.... So I can shout "OK Google, open the front gate"..... Works really well, although I do wish I didn't have to mention Google every time!
sebas
Re: Android app
Post by sebas »
Don't see why you would need access to the source code repository for feature requests... I keep track of the ones that reach me via the forum and via email. I appreciate all the input I get but it's too much to develop in a short period so I need to focus on the features that are usable by many.
cyrano1966
Re: Android app
Post by cyrano1966 »
Sebas,
First my thanks on the great work done in Dromotica. Just a quick question and probably a silly one but unable to find it anywhere in documentation or forum. How do you configure West longitudes for geofencing? The negative sign from the keyboard is not taken.
Thanks in advance
Marcelo
12345caravan
Re: Android app
Post by 12345caravan »
Great app!
Only problem for me is the opentherm-gateway thermostat.....
The setpoint is verrrry bad readable, light grey text on white???
I can not set a temp, if I can not choose one.
Plus the temps are all in half degree (e.g. 19.5/20.5/21.5), that's exacly what my Honeywell
don't accept. Maybe steps in full degrees in between?
Rbmg
Re: Android app
Post by Rbmg »
Hi Sebastiaan,
I love the App a lot! I am, however, also experiencing the 'blank' page issue when returning from an inactive state that was reported by thorbj a couple of weeks ago. It occurs on all my devices with Android 4.4.2, 4.4.4 and 5.0. It would be nice if you could fix it or tell me how to fix it if it is a configuration thing.
Cheers,
Rbmg
ThinkPad
Re: Android app
Post by ThinkPad »
I am also encountering the white screen issue. I think this can be solved by implementing a forced refresh on opening of the app
Ron
Domoticz version: 2.2284
Re: Android app
Post by Ron »
I allso have the white screen problem.
Nothing appears until i swipe the screen from left to right.
Brutus
Re: Android app
Post by Brutus »
@Ron and Thinkpad,
Sabastiaan is working on a solution he mentioned at 27th of November. It wil be fixed when he releases the next update.
Greetings Brutus.
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
Rbmg
Re: Android app
Post by Rbmg »
I'm sorry I overlooked the comment on the white screen issue.
I noticed that the app is not updating any more on my tablet. The latest version is 1.5.15. The play store notes that the app is not compatible with my device. Could it be that it requires GPS since the geofencing feature was introduced? My tablet (Colorfly 708 Q2) that is my primary domotica & entertainment control center is WIFI only and lacks GPS. Is it possible to make that requirement optional?
Cheers,
Rbmg
Blueone
Re: Android app
Post by Blueone »
Can you also look to the data usage, is uses almost 50MB in the background a month.
Brutus
Re: Android app
Post by Brutus »
Blueone wrote:Can you also look to the data usage, is uses almost 50MB in the background a month.
I had this problem to some time ago. I uninstalled the app and installed it again. After that the problem is solved. I have used 1MB in 7 days now.
Hope this will help for you.
Greetings Brutus.
28x Fibaro Modules
SMA Solar System
barbaar
Re: Android app
Post by barbaar »
Just installed Domoticz and Dromotica.. Works well.. However, I have two issues with Dromotica:
1. Each time I reopen Dromotica (app is running on background), the dashboard stays empty. I have to reselect the dashboard on the left to get data:
2. I connected the OpenTherm Gateway to my Domoticz. However, I can barely read the Setpoint temperatures:
See on the lower right bottom of the screenshot. The menu is also barely readable. This is probably because the fontcolor is white.
Used device:
Nexus 5, android 5.0.
Domoticz running on a raspberry pi, lastest unstable version.
Brutus
Re: Android app
Post by Brutus »
Hi Barbaar,
For the first problem I only can say this will be fixed in the next release. As you can see some reply's back.
Greetings Brutus.
28x Fibaro Modules
SMA Solar System
remb0
Re: Android app
Post by remb0 »
Sebas. On our telephones we can't set temperature of the icy thermostaat. First we cant read because of the colours and second when we choose 21 it doesn' t change.
Can you fix this?
Marius
Re: Android app
Post by Marius »
Any chance for fixing thermostat bug?
It would be realy nice to be able to set the temperature.
Blueone
Re: Android app
Post by Blueone »
It is already clear that he wan't to keep is closed source, why do you keep asking? There are also serveral ways to report bugs and place feature requests.
Scoobydoo
Re: Android app
Post by Scoobydoo »
Android wear support would be an awesome addition. Being able to turn on switches etc from your wear watch would be great.
micksel
Re: Android app
Post by micksel »
feature request:
i don't think this function exist in your app right now.
a way to separate walking from driving. maybe if a specific bluetooth connection is connected like the car and you arrave inside the proximity. than your in your car and maybe the garage would open etc
jannl
Domoticz version: 2026.1.x
Re: Android app
Post by jannl »
I think thatvis something that can be done with the geofencing option in dromotica or an app like tasker.
