dtgbot - Domoticz TeleGram BOT
solarboy
Domoticz version: 2024.6
Re: dtgbot - Domoticz TeleGram BOT
Post by solarboy »
dtgbot is rarely reliable in my experience.
Intel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),SMA Hub (docker),Harmony Hub plugin, Kodi plugin,Homebridge(docker)+Google Home,APC UPS,SMA Modbus,Mitsubishi MQTT, Broadlink,Dombus
jvdz
Domoticz version: 4.107
Post by jvdz »
solarboy wrote: Thursday 09 September 2021 1:13 dtgbot is rarely reliable in my experience.
A bit of a blunt statement don't you think?
I am running it for years and it is rock solid given you take all required precautions.
Jos
hoeby
Domoticz version: V2022.1
Post by hoeby »
I installed it last year.
My wife and me are verder happy with it. Works like a dream.
We like it, because no network setting modification are needed, to give commands to domoticz when we are away from home.
Thin-client --> Docker Domoticz main environment
Pi3A+ --> Google home (GAssistPi)
Pi3B+ --> Docker (P1monitor, Domoticz test environment, Ubiquity controller)
solarboy
Post by solarboy »
I find the service frequently hangs but yes, perhaps a little harsh.
jvdz
Post by jvdz »
That simply means you didn't implement the monit option as that should take care of any hangs. It is a known fact that the long poll can hang for the http addin used, hence the monit check. It only hangs when you have some internet quality issues.
Jos
solarboy
Post by solarboy »
That's another way of putting it. Monit saves the day.
jvdz
Post by jvdz »
Whatever makes you feel like you are right....
I can't remember the last time Monit was needed to restart DTGBOT for my installation and that must be more than a year ago..... but moving on as its clear what your opinion is.
mojso
Post by mojso »
this error appears in dtb.log.errors
 /usr/bin/lua5.2: error loading module 'ssl.core' from file '/usr/local/lib/lua/5.2/ssl.so':
	libssl.so.1.0.0: cannot open shared object file: No such file or directory
stack traceback:
	[C]: in ?
	[C]: in function 'require'
	/usr/local/share/lua/5.2/ssl.lua:7: in main chunk
	/usr/local/share/lua/5.2/ssl/https.lua:10: in main chunk
	/home/pi/dtgbot/dtgbot.lua:132: in main chunk
	[C]: in ?
i tried this way but i think the link is dead
Marcello1970 wrote: Thursday 28 February 2019 12:34
Edit the sources.list
sudo nano /etc/apt/sources.list
add the next line:
this link
deb http://archive.raspbian.org/raspbian/ jessie main contrib non-free rpi
this link
Save it with CTRL + X , Y
and then:
sudo apt-get update
sudo apt-get install libssl1.0.0
Then the bot works!
Thanks to:
https://diyprojects.io/domoticz-install ... HfCKOhKgdW
pi@raspberrypi2:~ $ apt list libssl*
Listing... Done
libssl-dev/oldstable,now 1.1.1d-0+deb10u7 armhf [installed]
libssl-doc/oldstable 1.1.1d-0+deb10u7 all
libssl-ocaml-dev/oldstable 0.5.5-1 armhf
libssl-ocaml/oldstable 0.5.5-1 armhf
libssl-utils-clojure/oldstable 0.8.3-2 all
libssl1.0-dev/oldstable 1.0.2q-2 armhf
libssl1.0.2/oldstable,now 1.0.2q-2 armhf [installed,automatic]
libssl1.1-dbgsym/oldstable 1.1.1d-0+deb10u6+rpt1 armhf
libssl1.1/oldstable,now 1.1.1d-0+deb10u7 armhf [installed]
pi@raspberrypi2:~ $
hoeby
Post by hoeby »
I had the same problem last month.
Solved it with this
You are trying to get something out of the jessie archive. But that doesn't exist anymore. Therefor the error.
wget http://ftp.nl.debian.org/debian/pool/main/o/openssl/libssl1.0.0_1.0.1t-1+deb8u8_armhf.deb
sudo dpkg -i libssl1.0.0_1.0.1t-1+deb8u8_armhf.deb
sudo reboot
mojso
Post by mojso »
hoeby wrote: Monday 20 December 2021 18:22 I had the same problem last month.
Solved it with this
sudo reboot
Thanks a lot, it works great now
mojso
Post by mojso »
another question, how to turn on a switch that is password protected
jvdz
Post by jvdz »
How are you trying to switch this switch? Via a bash or LUA script using a JSON call to domoticz or the MENU?
mojso
Post by mojso »
jvdz wrote: Monday 20 December 2021 23:19 How are you trying to switch this switch? Via a bash or LUA script using a JSON call to domoticz or the MENU?
Via the Menu in Telegram
jvdz
Post by jvdz »
As this requires a JSON call with the extra password field, can only see this working via a Bash or LUA command files that performs that action and the command yourself in the dtgmenu.cfg.
mojso
Post by mojso »
jvdz wrote: Tuesday 21 December 2021 9:08 As this requires a JSON call with the extra password field, can only see this working via a Bash or LUA command files that performs that action and the command yourself in the dtgmenu.cfg.
can you show me an example. please
jvdz
Post by jvdz »
Just create a script for ON and one for OFF .... something like:
#!/bin/sh
curl 'https://yourdomoticzip:port/json.htm?type=command&param=switchlight&idx=IDX-oftheSwitch&switchcmd=On&passcode=YOUR_SWITCH_PASSWORD_AS_SET_IN_SETTINGS'
and save it to /dtgbot/bash with the name pswitchon.sh.
do the same for pswitchoff.sh.
Set the x attribute (chmod +x pswitch*.sh)
Modify dtgmenu.cfg and add this command to an menu item .... eg:
static_dtgmenu_submenus = {
	["pSwitch"] = {whitelist="",showdevstatus="n",Menuwidth=3,
		buttons={
		["pswitchon"]	 	= {whitelist=""},
		["pswitchoff"]	 	= {whitelist=""},
Restart DTGBOT and you should be in business... (all untested ;) )
... but to be honest: aren't you defeating the purpose of making it a password protected switch when you automate it in this way?
mojso
Post by mojso »
you are right, the switch is password protected only to prevent accidental pressing, it may be possible to ask whether to execute that command, only for certain switches
hoeby
Post by hoeby »
satanasinc wrote: Tuesday 13 March 2018 16:53 Hi!
First of all excuse my bad english. I do my best.
Ive got a RPi working with the telegram bot and domoticz control but my instalation is very old running ver rapsbian wheezy. So i do a fresh install in a new SD with raspbian stretch and the domoticz telegram bot control dont works.
I cant find where is the problem because dont recive answer from domoticz but the notification works perfect.
The /var/tmp/dtb.log apears to be correct...
2018-03-13 14:52:01 - DomoticzIP: 127.0.0.1
2018-03-13 14:52:01 - DomoticzPort: 8080
2018-03-13 14:52:01 - BotHomePath: /home/pi/dtgbot/
2018-03-13 14:52:01 - TempFileDir: /var/tmp/
2018-03-13 14:52:01 - BotLuaScriptPath: /home/pi/dtgbot/lua/
2018-03-13 14:52:01 - BotBashScriptPath: /home/pi/dtgbot/bash/
2018-03-13 14:52:01 - TelegramBotToken: 524####64:AAFZUOtHs_tvJ_F6c06GYpkt6$$$$$$$$$$$$
2018-03-13 14:52:01 - TelegramBotOffset: TelegramBotOffset
2018-03-13 14:52:01 - -----------------------------------------
2018-03-13 14:52:01 - Starting Telegram api Bot message handler
In /var/tmp/dtb.log.error i got this...
Illegal instruction
My /etc/profile.d/DomoticzData.sh#I can't get the next line to work during start-up so have gone to 127 instead
#export DomoticzIP=$(hostname -I|sed 's/[ ]*$//')
export DomoticzIP="127.0.0.1"
export DomoticzPort="8080"
export TempFileDir="/var/tmp/"
export BotHomePath="/home/pi/dtgbot/"
export BotBashScriptPath=$BotHomePath"bash/"
export BotLuaScriptPath=$BotHomePath"lua/"
export BotLuaLog=$TempFileDir"dtb.log"
export TelegramChatId='34####63#
export TelegramBotToken="524####64:AAFZUOtHs_tvJ_F6c06GYpkt6$$$$$$$$$$$$"
export TelegramBotOffset="TelegramBotOffset"
export EmailTo="alt$$$$$[email protected]"
I have started the installation a couple of times wthout luck following the domoticz wiki.
Any idea? What can i do to make it work?
Thanx in advance for your help.
jvdz wrote: Tuesday 13 March 2018 18:36 The issue seems to lie in these lines so guess the best bet will be an issue with the require files:
-- Load necessary Lua libraries
http = require "socket.http";
socket = require "socket";
https = require "ssl.https";
JSON = require "JSON";
function file_exists(name)
   local f=io.open(name,"r")
   if f~=nil then io.close(f) return true else return false end
-- Load the configuration file this file contains the list of commands
-- used to define the external files with the command function to load.
local config=""
if (file_exists(BotHomePath.."dtgbot-user.cfg")) then
  config = assert(loadfile(BotHomePath.."dtgbot-user.cfg"))();
  print_to_log ("Using DTGBOT config file:"..BotHomePath.."dtgbot-user.cfg")
  config = assert(loadfile(BotHomePath.."dtgbot.cfg"))();
  print_to_log ("Using DTGBOT config file:"..BotHomePath.."dtgbot.cfg")
Could the issue be similar to issues reported like this one?: http://www.domoticz.com/forum/viewtopic ... on#p171940
Jos
The link on the similar issue isn't working anymore, any idea where the link was transfered to?
Trying to install it on a pi zero. Get the same error as reported on page 15
why a pi zero, have this lying around and trying to test something
2021-12-22 18:49:21 - -----------------------------------------
2021-12-22 18:49:21 - Starting Telegram api Bot message handler
Illegal instruction
mojso
Post by mojso »
How to see the value of a sensor from the utility section. via a telegram command
devices - gives me the complete list
for example
info 22 - to show me the quantity in the water tank
jvdz
Post by jvdz »
You can make your own bash (sh) script or LUA script to provide the correct answer or use the Menu structure to display the values of devices.
Just look at the examples provided. :)
