If i add a cfa3010.xml file in the domoticz/Config dir and a rule in the manufacter file it's gone after every update..
How to add it in an other way?
Abus cfa3010 door lock ozw issue
- Domoticz version: 2025.1
Re: Abus cfa3010 door lock ozw issue
You should make a pull request on the Domoticz Github repository for these 2 changes. Then it will be part of the updates.
Be aware that OZW is out of maintenance and in Domoticz is replaced by Zwavejs2mqtt with Autodiscovery. In Domoticz it is currently supported in Beta with MQTT Autodiscover functionality. See also https://www.domoticz.com/wiki/ZwaveJS2MQTT
abc1000
Tnx, i'll give it a try..
abc1000
Can't make a request on githubwaltervl wrote: Sunday 19 December 2021 11:01 You should make a pull request on the Domoticz Github repository for these 2 changes. Then it will be part of the updates.
Don't know where to start with https://www.domoticz.com/wiki/ZwaveJS2MQTT
To make a PR, create a github account, and edit a file from the domoticz repository. Github will advise you to fork the project and create a change branch. In your for branch create the changes and the create a PR out of that.abc1000 wrote: Monday 20 December 2021 9:05 Can't make a request on githubonly "compare"
I already requested a wiki procedure how to step over from OpenZwave to Autodiscover. See also the discussion from here: viewtopic.php?p=283925#p283925
As the pairing is done on the Zwave stick there is no need to re-pair all devices.
abc1000
It's not easy but i'v got zwavejs2mqtt running and see my zwave devices in controlpanel
In domoticz i'v add MQTT gateway. How to get device's in domoticz? I don't see it
Did you perform all the install steps as mentioned in the wiki?
Did you have the setting allow new devices switched on (Domoticz menu setup - settings)?
abc1000
Yes and yes
I can see in mosquitto.log a connection between domoticz and mosquitto
I'v add' my z-stick gen5+ usb in zwavejs2mqtt.
What i'm missing?
EDIT: issue solved! pff had not same prefix's..
What i'm missing?
