I have Domoticz running on a RPi and managed to add ZigBee support with Ziqbee2mqtt. And I have a few ZigBee devices connected. Among those an Ikea Tradfri E1603 outlet. Everything works fine. But now I would like to add one or two extra Ikea Tradfri E1603 outlet devices and I can't remember how I got the first one discovered by Domoticz. I have enabled "accept new devices" on the setup page and plugged in the outlet. No response. I have tried "pairing mode" on the zogbee2mqtt page on Domoticz. No response. And I also tried the the "Allow new ZigBee devices" on the same page. No response.
The white LED om the outlet is on indicating it waits for pairing. But how do I get there?
It is frustrating since it have one up and running and I can't remember how I got it connected.
How add one new Ikea Tradfri Outlet e1603?
- heggink
- Domoticz version: 12451
Re: How add one new Ikea Tradfri Outlet e1603?
Are you using the new autodiscovery function or the python plugin?
Sent from my SM-G980F using Tapatalk
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
ubee
- Domoticz version: 2021.1
Oops, it was quite a a while since I made the configuration, so I had to check this up.
On the hardware tab i find this device:
Zigbee2MQTT Plugin
so I guess I'm using the plugin. And I'm running 2021.1 release of Domoticz.
Zigbee2MQTT Plugin
- heggink
Ok. The following page describes how to put the plug in pair mode:
https://www.zigbee2mqtt.io/devices/E160 ... E1708.html
Once you have done that, in the zigbee2mqtt interface (not the plugin interface), you can then enable inclusion using the button. You can also use the plugin page to include/pair. Both should work.
DASHTICZ 🙃
DASHTICZ 🙃
ubee
Thanks a lot! I know it wasn't that complicated. I hope I'll remember this next time....
- heggink
The forum will remember
DASHTICZ 🙃
DASHTICZ 🙃
