SD to SSD
thomasbaetge
- Domoticz version: 2023.1
Re: SD to SSD
even the cheapest SSD will serve you longer and better than any SD card.
And you have a backup image anyway.
- heggink
- Domoticz version: 12451
Re: SD to SSD
This is not entirely true. Both ssd and sd have different degrees of wear and wear leveling. There are ssd's that suffer badly from wear and there are high endurance sd cards that are as reliable as higher end ssd's.thomasbaetge wrote:even the cheapest SSD will serve you longer and better than any SD card.
Sent from my SM-G980F using Tapatalk
P1 meter & solar panel
Thorgal789
- Target OS: -
Re: SD to SSD
Lol, every time I see user with SSD or SD, but no one use eMMC ?
I want to make a try on my side, but I have no return about this solution.
- McMelloW
- Domoticz version: V2024.1
Re: SD to SSD
What is the advantage of an eMMC vs a SSD on a RPiThorgal789 wrote: Wednesday 15 December 2021 17:16 And noone have tried eMMC card used with a SSD adaptator (no power needed) or a RasPiKey ?
Greetings McMelloW
- JackD
Re: SD to SSD
I agree, had some problems with SD cards in the past, not much, but they generally don't like a lot of writing actions.
So last time I went for a Western Digital Purple SD card, and is running for a while now without any problems.
Perhaps just luck or a coincidence, but my experience tells me that a SD card is not just a SD Card, there are differences(beside the price-tag
heggink wrote: Thursday 16 December 2021 17:48This is not entirely true. Both ssd and sd have different degrees of wear and wear leveling. There are ssd's that suffer badly from wear and there are high endurance sd cards that are as reliable as higher end ssd's.thomasbaetge wrote:even the cheapest SSD will serve you longer and better than any SD card.
Re: SD to SSD
I use this one: https://www.amazon.de/SanDisk-Industria ... 770&sr=8-1
It is in one of my Raspberry's for more then 3 years 24x7x365, never went down and without any error.
Thorgal789
- Target OS: -
Re: SD to SSD
It use the SD port instead of the USB
Less power use.
Less interferences on zigbee gateway (big problem on pi4 + SSD with zigbee gateway).
Smaller, the systeme is more compact. Strange to use a Raspberry 0 for domoticz with a SSD.
- HansOtten
- Domoticz version: 2021-1
Re: SD to SSD
Use the official Raspberry power supply for the Pi 4 of course. No need for exotic expensive ones.EddyG wrote: Thursday 16 December 2021 12:20See what power is needed for an SSD, just to get an idea: https://www.anandtech.com/show/8747/sam ... -review/10HansOtten wrote: Thursday 16 December 2021 11:19
Not true, most RPi's and small SSD's run fine without external power supply and are very fast and reliable.
And other USB devices? I have two more, the zigbee stick and a RFlink.
Do not over engineer!
You will have to set "max_usb_current=1" in the config.txt to be able to power an USB SSD drive properly.
For an Raspberry Pi 4B you will have to buy a 3 Amps charger because the Raspberry Pi 4B can consume 6 Watts.
Raspberry Pi 4, SSD, RFlink, P1 Smart Meter. Many Zigbee devices CR2562 USB stick. Bresser via Weather Underground
Switched to Home Assistant!
Re: SD to SSD
In case you did not know the official Raspberry Pi USB-C charger is 3A, and they all come from China.
- McMelloW
Re: SD to SSD
For my understanding. The SD port needs a micro SD-Card shape connector or an eMMC in a micro SD-card shape. Is there another way?Thorgal789 wrote: Thursday 16 December 2021 20:01It use the SD port instead of the USB
Less power use.
Greetings McMelloW
Re: SD to SSD
Search the Internet for "industrial grade MicroSD cards".
some reading: https://www.quora.com/Is-an-eMMC-better-than-an-SD-card
- HansOtten
Re: SD to SSD
And it works fine with a Raspnberry Pi 4 with SSD and some USB devices.EddyG wrote: Friday 17 December 2021 9:32 In case you did not know the official Raspberry Pi USB-C charger is 3A, and they all come from China.
Besides the Domoticz system I have an OpenVaultMedia NAS with a 2TB WD SSD and the Raspberry Pi powersupply, no problems at all (I check the logs, no underpower logs). So stop making unvalidated statements.
So what is not coming from China nowadays? Enough said.
Re: SD to SSD
Thorgal789
- Target OS: -
Re: SD to SSD
There is some eMMC natively with SD connexion like this one https://www.gotronic.fr/art-module-rasp ... -33116.htmMcMelloW wrote: Friday 17 December 2021 11:44 For my understanding. The SD port needs a micro SD-Card shape connector or an eMMC in a micro SD-card shape. Is there another way?
- McMelloW
Re: SD to SSD
OK thanks, I will have a look at it.Thorgal789 wrote: Friday 17 December 2021 17:36There is some eMMC natively with SD connexion like this one https://www.gotronic.fr/art-module-rasp ... -33116.htmMcMelloW wrote: Friday 17 December 2021 11:44 For my understanding. The SD port needs a micro SD-Card shape connector or an eMMC in a micro SD-card shape. Is there another way?
Greetings McMelloW
sciurius
- Domoticz version: 2021.1
Re: SD to SSD
I blew up several USB3 ports on RPi and other computers with a cheap adapter cable.HansOtten wrote: Wednesday 15 December 2021 13:14 Expensive. I use a USB 3 cableadapter (7,50 euro Pihut) and a SSD 240 GB 20 euro and a Raspbery Pi 4 and printed my own case.
(Blew up = the USB3 port stopped ultraspeed and only functioned in highspeed (USB2) mode)
YMMV.
