SD to SSD
wouterlet
SD to SSD
Hello guys,
I couldn't find a topic/manual for this. But a want to convert my domoticz installation from SD to SSD. But I would like to prevent an new installation, is this possible? Or do I have to completely start over?
- HansOtten
- Domoticz version: 2021-1
Re: SD to SSD
Easy. No reinstallation required.
Look at the general SD to SSD recipes for Raspberry Pi, it is just a matter of copying the SD image to the SSD.
https://github.com/billw2/rpi-clone for example
Make sure you have a USB 3.0 adapter that is supported, the ASmdia chipset works fine.
And have a look at the the EEPROM update and boot order in raspi-config.
Keep the SD safe until the SSD is working. You can always restart the process then.
Raspberry Pi 4, SSD, RFlink, P1 Smart Meter. Many Zigbee devices CR2562 USB stick. Bresser via Weather Underground
Switched to Home Assistant!
sammyke007
- Domoticz version: 2022.1
Re: SD to SSD
This is the best thing you can do with your Pi in my opinion. Just keep your SD somewhere safe. If something fails, you can always revert to it without a problem. I use BENFEI and UGREEN SATA to USB adapters and both work fine for +1 year.
Just check your Pi version and see if it needs additional programming before booting from SSD or not.
wouterlet
Re: SD to SSD
Ok,sounds good. My Pi is an 3B+. I'll have a look how to change the boot options.
Do you have any thoughts about this combination:
https://geekworm.com/products/x820-v3-0 ... 4783619160
Looks nice that I can build it all in a small housing. Or are there known issues with this board?
Re: SD to SSD
I use a similar housing from Geekworm for 2 ssd drives, I use those 2 ssd drive in raid 1, so if 1 ssd drive fails the system still runs.
I also use the power unit from Geekworm.
- HansOtten
Re: SD to SSD
Expensive. I use a USB 3 cableadapter (7,50 euro Pihut) and a SSD 240 GB 20 euro and a Raspbery Pi 4 and printed my own case.wouterlet wrote: Wednesday 15 December 2021 10:37 Ok,sounds good. My Pi is an 3B+. I'll have a look how to change the boot options.
Re: SD to SSD
Cheap SSD my WDC_WDS250G2B0A costed around € 40,-- per pceHansOtten wrote: Wednesday 15 December 2021 13:14 SSD 240 GB 20 euro and a Raspbery Pi 4 and printed my own case.
Can your case be found on Thingiverse?
thomasbaetge
- Domoticz version: 2023.1
Re: SD to SSD
I did that last year, copied the image from SD to a small 120GB SSD from Amazon.
It took me about 30 minutes and the system is running 24/7 ever since. I think 120GB is plenty of storage for this purpose, I am running domoticz with 500+ devices, mosquitto, Phoscon and node-red on a headless buster installation and still have 95% free storage.
- HansOtten
Re: SD to SSD
A small SSD like 120GB is more than enough, you are only replacing a 16 GB SD. And they are about 20 euro now.
Yea, there are many cases on thingiverse, look for HDD + Raspberry. https://www.thingiverse.com/thing:2407893 is the one I use.
Thorgal789
- Target OS: -
Re: SD to SSD
And noone have tried eMMC card used with a SSD adaptator (no power needed) or a RasPiKey ?
Last edited by Thorgal789 on Wednesday 15 December 2021 17:39, edited 1 time in total.
thomasbaetge
Re: SD to SSD
nope, small SSDs are dirt cheap, very reliable and don't need external power supply.
Total no-brainer with a lot of benefits
Thorgal789
- Target OS: -
Re: SD to SSD
Yep but still need one, by the USB port, so more consumption, and less for other USB devices.don't need external power supply
thomasbaetge
Re: SD to SSD
not necessarily.
I have a z-wave stick, a conbee Zigbee stick and said SSD in the PI (3b+).
Plus it has a cooling fan.
it does not report undervoltage with the standard power supply and works perfectly fine.
maybe just because nobody told the PI that it may be too much
- HansOtten
Re: SD to SSD
Not true, most RPi's and small SSD's run fine without external power supply and are very fast and reliable.Thorgal789 wrote: Wednesday 15 December 2021 17:40Yep but still need one, by the USB port, so more consumption, and less for other USB devices.don't need external power supply
And other USB devices? I have two more, the zigbee stick and a RFlink.
Do not over engineer!
- HansOtten
Re: SD to SSD
Good advice!RobertM wrote: Wednesday 15 December 2021 21:25 RPi SD Card Copier![]()
https://linuxhint.com/how-to-clone-a-ra ... i-sd-card/
thomasbaetge
Re: SD to SSD
just remember, if you clone a 16GB SD card to a 120GB SSD you will still have a 16GB image, not 120
Re: SD to SSD
See what power is needed for an SSD, just to get an idea: https://www.anandtech.com/show/8747/sam ... -review/10HansOtten wrote: Thursday 16 December 2021 11:19
You will have to set "max_usb_current=1" in the config.txt to be able to power an USB SSD drive properly.
For an Raspberry Pi 4B you will have to buy a 3 Amps charger because the Raspberry Pi 4B can consume 6 Watts.
thomasbaetge
Re: SD to SSD
I would not make it more complicated than it actually is.
I've just picked the first no-name SSD from Amazon, put my image on it and fired it up.
No undervoltage reported, no crashes or any issues for more than a year in 24/7 operation.
If I would search the internet long enough I will for sure find a website that tells me that it is a shitty idea, but I tend to not solve problems, that I don't have in the first place.
- user4563
- Domoticz version: 2026.3
Re: SD to SSD
It would be wise to get a SSD that is proven to be reliable through unless you don't mind starting over (Samsung, Plextor, WD, Kingston, etc)
ODroid H4+ / Ubuntu server 24.04 LTS
Aeotec Z-Stick Gen5+
ZWave-JS-UI / Mosquitto MQTT
Domoticz for Android
Domoticz Scenes add-on in Kodi
