I bought Smartmi Smart Fan Heater model zhimi.heater.nb1( https://www.xiaomiproducts.nl/en/xiaomi ... eater.html ) and I want to integrate it into domoticz.
Has anyone managed this?
Xiaomi Smartmi Fan Heater
pfloryann
- Domoticz version: 2026.3
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
pfloryann
Re: Xiaomi Smartmi Fan Heater
After many hours...i find the commands for this Heater.
I used python-miio and a sh file for test.
So if anyone can use these commands to create a plugin for Domoticz for this device would be awesome.
Get info
# Get target Temp
sudo -H -u pi miiocli device --ip 192.168.x.xx --token 951xxxxxxxxxxxxx raw_command get_properties '[{"piid":5,"siid":2}]'
# Get the status (On or off where On = True and Off = False)
sudo -H -u pi miiocli device --ip 192.168.x.xx --token 951xxxxxxxxxxxxx raw_command get_properties '[{"piid":2,"siid":2}]'
# Get the heating status - Warm (1000w) or Hot (2000W) where value 1 = Hot and 2=Warm
sudo -H -u pi miiocli device --ip 192.168.x.xx --token 9abxxxxxxxxxxxxx raw_command get_properties '[{"piid":3,"siid":2}]'
#Get the oscilation status
sudo -H -u pi miiocli device --ip 192.168.x.xx --token 951xxxxxxxxxxxxx raw_command get_properties '[{"piid":4,"siid":2}]'
#Get the indicator light for leds
sudo -H -u pi miiocli device --ip 192.168.x.xx --token 951xxxxxxxxxxxxx raw_command get_properties '[{"piid":1,"siid":6}]'
#Get the child lock status
sudo -H -u pi miiocli device --ip 192.168.x.xx --token 951xxxxxxxxxxxxx raw_command get_properties '[{"piid":1,"siid":7}]'
#Get Recenter automatically status
sudo -H -u pi miiocli device --ip 192.168.x.xx --token 951xxxxxxxxxxxxx raw_command get_properties '[{"piid":3,"siid":8}]'
#Get the Constant Temp status
sudo -H -u pi miiocli device --ip 192.168.x.xx --token 951xxxxxxxxxxxxx raw_command get_properties '[{"piid":5,"siid":8}]'
#Get the notification sound status
sudo -H -u pi miiocli device --ip 192.168.x.xx --token 951xxxxxxxxxxxxx raw_command get_properties '[{"piid":1,"siid":3}]'
#Get Delayed shutdown. Value can be between 1 and 12 Hours. 0 = disable
sudo -H -u pi miiocli device --ip 192.168.x.xx --token 951xxxxxxxxxxxxx raw_command get_properties '[{"piid":1,"siid":4}]'
Send Commands
#Turn on/off (where value for On = True and Off = False)
sudo -H -u pi miiocli device --ip 192.168.x.xx --token 951xxxxxxxxxxxxx raw_command set_properties '[{"value":True,"siid":2,"piid":2}]'
# Set the target Temperature (22 in this case)
sudo -H -u pi miiocli device --ip 192.168.x.xx --token 951xxxxxxxxxxxxx raw_command set_properties '[{"value":22,"siid":2,"piid":5}]'
# Set the heating mode - Warm (1000w) or Hot (2000W) where value 1 = Hot and 2=Warm
sudo -H -u pi miiocli device --ip 192.168.x.xx --token 951xxxxxxxxxxxxx raw_command set_properties '[{"value":2,"siid":2,"piid":3}]'
#Set the Oscilation value 0 = disable, 1 = enable
sudo -H -u pi miiocli device --ip 192.168.x.xx --token 951xxxxxxxxxxxxx raw_command set_properties '[{"value":1,"siid":2,"piid":4}]'
#Set brithness for indicator leds. Value 0 = max, 1= medium, 2= disable
sudo -H -u pi miiocli device --ip 192.168.x.xx --token 951xxxxxxxxxxxxx raw_command set_properties '[{"value":1,"siid":6,"piid":1}]'
#Set child lock. Value True=enable, False=disable
sudo -H -u pi miiocli device --ip 192.168.x.xx --token 951xxxxxxxxxxxxx raw_command set_properties '[{"value":False,"siid":7,"piid":1}]'
#Set Recenter automatically . value True or False
sudo -H -u pi miiocli device --ip 192.168.x.xx --token 951xxxxxxxxxxxxx raw_command set_properties '[{"value":False,"siid":8,"piid":3}]'
#Set Constant temp. Value True or False
sudo -H -u pi miiocli device --ip 192.168.x.xx --token 951xxxxxxxxxxxxx raw_command set_properties '[{"value":True,"siid":8,"piid":5}]'
#Set notification sound. Value True or False
sudo -H -u pi miiocli device --ip 192.168.x.xx --token 951xxxxxxxxxxxxx raw_command set_properties '[{"value":True,"siid":3,"piid":1}]'
#Set Delayed shutdown. Value can be between 1 and 12 Hours. 0 = disable
sudo -H -u pi miiocli device --ip 192.168.x.xx --token 951xxxxxxxxxxxxx raw_command set_properties '[{"value":0,"siid":4,"piid":1}]'
192.168.x.xx = Ip heater, 951xxxxxxxxxxxxx = token heater
Get info
# Get target Temp
Send Commands
