I posted the following message in general forum, but no one replies:
Does anyone knows of a simple/cheap rf module that I can insert in the middle of an existing mechanical commuted circuit and control (and sense) that circuit as it was and ordinary commuted switch?The biggest question I make myself is, having a said house, with no electronics in it's installations... If someone wanted to start sensing and controlling lights, how could be done?
For example: you have a room whose main light is turned using two or three mechanical common commuted switches. What kind of device would be attached to the existing system, to sense it's state and be able to switch without loosing the mechanical behavior and without having to change any existing switch?
In a commuted system every switch connects to each other in series so it can be possible and easy to insert another switch in the middle. I wonder if there's some device that simulates a commuted switch.
I suppose that's the easy situation. But how about single systems, where there's only a simple mech switch?
