Last year I had some Action flamingo switches setup in domoticz to be able to voice control some “season specific lighting” using controlicz and google home (google home mini speaker). That worked well. Now the switches were used for different applications during the year and I removed them in domoticz and have just re-learned them to add them again.
One of them is called Rudolf, yeah an illuminated… reindeer.
So I added it to controllicz user in domoticz, and it is showing up in google home.
When I tell google “Hey google Rudolf aan” google tells me it will turn on Rudolf.
However nothing happens??? The log tells me “ 2021-12-05 11:26:23.674 Error: User: controlicz, switch not found (idx=141)!”
Which is correct because Rudolfs’ idx is 685. So 141 must be coming from… history?
What is happening and any ideas of how to repair this issue?
Help is very much appreciated!
Controllicz wrong idx sent Topic is solved
Kranendijk
- Domoticz version: 4.10717
JeroenL
- Domoticz version: 2023.2
Re: Controllicz wrong idx sent
What I would try is to remove the device from the user you are using for Controlicz.
Sync devices on Google
Re-add the device with the right IEX to the Controlicz user
Sync devices again. (“ Hey Google sync devices” )
Maybe this works!
Maybe this works!
Kranendijk
It did the trick, thanks!
