Solax inverter Plugin
pmalvino
Re: Solax inverter Plugin
Post by pmalvino »
ayasystems, I dont see anywhere on this topic anything about this problem.
I have raspberry with ethernet cable to the router and a wifi usb adapter with the wpa config to connect the v2 wifi network.
In the domoticz log i can see the send data and the received data from the solax.
its retrieves last data saying 401 Authorization required.
ayasystems
Post by ayasystems »
Did you put 5.8.8.8 ip ??
Please send a screenshot of plugin configuration
Check it with google translate https://domotuto.com/integracion-del-in ... -domoticz/ ( spanish site)
Check it also https://blog.chrisoft.io/2021/02/14/fir ... t-wifi-v2/ <--- hacked firm to allow use local network
THBR
Post by THBR »
I recently got a Solax inverter (X1 Boost v2) and I intend to install this plugin.
My RPi (3b) is already connected to my network via eth0. So I have to connect the RPi wlan0 Wifi to the inverter as described.
Does this mean that after installation I can no longer access the inverter in the standard way via the Solaxcloud (internet and their Android app)?
