eurotronics SPZB0001 ZIGBEE
FWES70
Domoticz version: 2021.1
Post by FWES70 »
I am running the lastest Domoticz on an up to date Pi with a Zigate (USB) with up to date firmware and the latest beta plugin for the zigate.
What I want to do is change the setpoint of my Eurotronics Spirit Zigbee (NOT Z-Wave) thermostats (SPZB0001). I have been at it for a few days now and I can't figure it out. (tried a few scripts to no avail)
The setpoint of the thermostat is updated (back) to Domoticz after a few minutes, much quicker if I change the setpoint on the thermostat.
So there is communication from the thermostat through the Zigate to Domoticz, right?
BUT... if I change the setpoint in Domoticz, it does not end up at the thermostat, and the setpoint in Domoticz is changed back after a few minutes
I am convinced it worked on a previous version of Domoticz, (2020.2 if I remember correclty) without any additional script, but with Domoticz 2021.1 / Build Hash: 8547c5b7e / Compile Date: 2021-04-17 17:29:11 / dzVents Version: 3.1.7 / Python Version: 3.7.3 (default, Jan 22 2021, 20:04:44) [GCC 8.3.0] I cannot make it work.
Any help would be very much appreciated!!
Thanks,
F.
pipiche
Re: eurotronics SPZB0001 ZIGBEE
Post by pipiche »
What do you use for zigbee controller ? DeConz, z2m ? Zigate ?
Wiki is available here.
Zigbee for Domoticz FAQ
FWES70
Post by FWES70 »
I use the Zigate USB
pipiche
Post by pipiche »
Could you kindly report :
- Domoticz-Zigate plugin branch and version you are using ?
- can you provide the export.json from the WebUI Tools -> Plugin Device List (RAW)
FWES70
Post by FWES70 »
Bonjour, here the details:
Zigate plugin
Geeft ZiGate informatie
Address : 0.0.0.0
Author : zaraki673 pipiche38
Database : /home/pi/domoticz/domoticz.db
DomoticzBuildTime : 2021-04-17 17:29:11
DomoticzHash : 8547c5b7e
DomoticzVersion : 2021.1
FirmwareUpdate : false
FirmwareVersion : 0320
HardwareID : 18
HomeFolder : /home/pi/domoticz/plugins/Domoticz-Zigate/
Key : Zigate
Language : en
LogLevel : 7
Mode1 : V1
Mode2 : USB
Mode3 : False
Mode4 : 9440
Mode5 :
Mode6 : 2
Password :
PluginBranch : beta
PluginUpdate : false
PluginVersion : 5.2.289
Port : 9999
SerialPort : /dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0
StartupFolder : /home/pi/domoticz/
TimeStamp : 24/11/2021 08:10:39
UserDataFolder : /home/pi/domoticz/
Username :
Versie : 5.1
WebRoot :
available : 5.2.258
available-firmMajor : 04
available-firmMinor : 0320
FWES70
Post by FWES70 »
device list:
0 :
App Version : "9"
Battery : 76
ConsistencyCheck : "ok"
DeviceType : "RFD"
Ep : Array[3] [{"ClusterList":[{"0000":"Basic"},{"0003":"Identify"},{"0004":"Groups"},{"0005":"Scenes"},{"0006":"On/Off"},{"0012":"Multistate Input (Basic)"},{"0019":"Over-the-Air Upgrade"},{"ffff":"Unknown"},{"0001":"Power Configuration"}],"Ep":"01"},{"ClusterList":[{"0012":"Multistate Input (Basic)"},{"0006":"On/Off"}],"Ep":"02"},{"ClusterList":[{"0000":"Basic"},{"0003":"Identify"},{"0006":"On/Off"},{"000c":"Analog Input (basic)"},{"0012":"Multistate Input (Basic)"}],"Ep":"03"}]
HW Version : ""
Health : "Live"
IEEE : "00158d000594175a"
LQI : 159
LastCmds : Array[0] []
LastSeen : "24/11/2021 07:49:11"
LogicalType : "End Device"
Manufacturer : "1037"
Model : "lumi.remote.b286acn02"
PowerSource : "Battery"
ProfileID : ""
ReceiveOnIdle : ""
Stack Version : ""
Stamp : Object {"LastSeen":"24/11/2021 07:49:11","MsgType":"8102","Time":"2021-11-24 07:49:11","time":1637736551.3810246}
Status : "inDB"
Type : ""
WidgetList : Array[1] [{"WidgetName":"Zigbee - schak beneden","WidgetType":"DButton_3","_WidgetID":"129"}]
ZDeviceID : ""
ZDeviceName : "schak beneden"
_NwkId : "3618"
1 :
App Version : "36"
Battery : ""
DeviceType : "FFD"
Ep : Array[2] [{"ClusterList":[{"0000":"Basic"},{"0001":"Power Configuration"},{"0002":"Unknown"},{"0003":"Identify"},{"0004":"Groups"},{"0005":"Scenes"},{"0006":"On/Off"},{"000a":"Time"},{"000c":"Analog Input (basic)"},{"0010":"Binary Output (Basic)"},{"0019":"Over-the-Air Upgrade"},{"0b04":"Electrical Measurement"},{"0702":"Unknown"}],"Ep":"01"},{"ClusterList":[{"0004":"Groups"},{"0005":"Scenes"},{"0006":"On/Off"},{"0010":"Binary Output (Basic)"}],"Ep":"02"}]
HW Version : "18"
Health : "Live"
IEEE : "00158d0005c0dfbd"
LQI : 207
LastCmds : Array[10] [{"CmdCode":"07","TimeStamps":"01/01/1970 01:08:25"},{"CmdCode":"02","TimeStamps":"01/01/1970 01:08:26"},{"CmdCode":"07","TimeStamps":"01/01/1970 01:08:27"},{"CmdCode":"07","TimeStamps":"01/01/1970 01:08:28"},{"CmdCode":"02","TimeStamps":"01/01/1970 01:09:00"},{"CmdCode":"07","TimeStamps":"01/01/1970 01:09:01"},{"CmdCode":"07","TimeStamps":"01/01/1970 01:09:02"},{"CmdCode":"02","TimeStamps":"01/01/1970 01:09:03"},{"CmdCode":"07","TimeStamps":"01/01/1970 01:09:04"},{"CmdCode":"07","TimeStamps":"01/01/1970 01:09:05"}]
LastSeen : "24/11/2021 08:16:04"
LogicalType : "Router"
Model : "lumi.relay.c2acn01"
PowerSource : "Main"
ProfileID : "0104"
Stack Version : "2"
Stamp : Object {"LastSeen":"24/11/2021 08:16:04","MsgType":"8102","Time":"2021-11-24 08:16:04","time":1637738164.0204453}
Status : "inDB"
Type : "Switch"
WidgetList : Array[4] [{"WidgetName":"Zigbee - relais2 beneden","WidgetType":"Switch","_WidgetID":"130"},{"WidgetName":"Zigbee - lumi.relay.c2acn01_Power-00158d0005c0dfbd-01","WidgetType":"Power","_WidgetID":"131"},{"WidgetName":"Zigbee - lumi.relay.c2acn01_Meter-00158d0005c0dfbd-01","WidgetType":"Meter","_WidgetID":"132"},{"WidgetName":"Zigbee - relais beneden","WidgetType":"Switch","_WidgetID":"133"}]
ZDeviceID : "0101"
ZDeviceName : "relais beneden"
_NwkId : "3694"
2 :
App Version : "16"
Battery : 153
DeviceType : "RFD"
Ep : Array[2] [{"ClusterList":[{"0000":"Basic"},{"0001":"Power Configuration"},{"0003":"Identify"},{"0402":"Temperature Measurement"},{"0b05":"Diagnostics"},{"0019":"Over-the-Air Upgrade"}],"Ep":"01"},{"ClusterList":[{"0000":"Basic"},{"0003":"Identify"},{"0405":"Relative Humidity Measurement"}],"Ep":"02"}]
HW Version : "16"
Health : "Live"
IEEE : "842e14fffef82b34"
LQI : 168
LastSeen : "24/11/2021 08:11:34"
Manufacturer : "120b"
Model : "HT-EF-3.0"
ProfileID : "0104"
ReceiveOnIdle : ""
Stack Version : "2"
Stamp : Object {"LastSeen":"24/11/2021 08:11:34","MsgType":"8011","Time":"2021-11-24 08:11:34","time":1637737894.3404226}
Status : "inDB"
WidgetList : Array[3] [{"WidgetName":"Zigbee - Voltage-842e14fffef82b34-01","WidgetType":"Voltage","_WidgetID":"134"},{"WidgetName":"Zigbee - TempGang","WidgetType":"Temp","_WidgetID":"135"},{"WidgetName":"Zigbee - HumGang","WidgetType":"Humi","_WidgetID":"136"}]
ZDeviceID : "0302"
ZDeviceName : "temphum gang"
_NwkId : "41f1"
3 :
App Version : "36"
Battery : ""
DeviceType : "FFD"
HW Version : "18"
Health : "Live"
IEEE : "00158d000586765f"
LQI : 153
LastCmds : Array[10] [{"CmdCode":"07","TimeStamps":"01/01/1970 01:08:34"},{"CmdCode":"02","TimeStamps":"01/01/1970 01:08:35"},{"CmdCode":"07","TimeStamps":"01/01/1970 01:08:36"},{"CmdCode":"07","TimeStamps":"01/01/1970 01:08:37"},{"CmdCode":"02","TimeStamps":"01/01/1970 01:08:53"},{"CmdCode":"07","TimeStamps":"01/01/1970 01:08:54"},{"CmdCode":"07","TimeStamps":"01/01/1970 01:08:55"},{"CmdCode":"02","TimeStamps":"01/01/1970 01:08:56"},{"CmdCode":"07","TimeStamps":"01/01/1970 01:08:57"},{"CmdCode":"07","TimeStamps":"01/01/1970 01:08:58"}]
LastSeen : "24/11/2021 08:16:00"
ProfileID : "0104"
Stack Version : "2"
Stamp : Object {"LastSeen":"24/11/2021 08:16:00","MsgType":"8011","Time":"2021-11-24 08:16:00","time":1637738160.9868042}
Status : "inDB"
Type : "Switch"
WidgetList : Array[4] [{"WidgetName":"Zigbee - relais 1e","WidgetType":"Switch","_WidgetID":"137"},{"WidgetName":"Zigbee - lumi.relay.c2acn01_Power-00158d000586765f-01","WidgetType":"Power","_WidgetID":"138"},{"WidgetName":"Zigbee - lumi.relay.c2acn01_Meter-00158d000586765f-01","WidgetType":"Meter","_WidgetID":"139"},{"WidgetName":"Zigbee - lumi.relay.c2acn01_Switch-00158d000586765f-02","WidgetType":"Switch","_WidgetID":"140"}]
ZDeviceID : "0101"
ZDeviceName : "relais 1e"
_NwkId : "d31b"
4 :
App Version : "9"
Battery : 69
DeviceType : "RFD"
HW Version : ""
Health : "Live"
IEEE : "00158d000586a302"
LQI : 123
LastSeen : "24/11/2021 08:15:45"
ProfileID : ""
ReceiveOnIdle : ""
Stack Version : ""
Stamp : Object {"LastSeen":"24/11/2021 08:15:45","MsgType":"8102","Time":"2021-11-24 08:15:45","time":1637738145.4956017}
Status : "inDB"
Type : ""
WidgetList : Array[1] [{"WidgetName":"Zigbee - schak 1e","WidgetType":"DButton_3","_WidgetID":"141"}]
ZDeviceID : ""
ZDeviceName : "schak 1e"
_NwkId : "4cb3"
5 :
App Version : "9"
Battery : 59
DeviceType : "RFD"
Ep : Array[3] [{"ClusterList":[{"0000":"Basic"},{"0003":"Identify"},{"0004":"Groups"},{"0005":"Scenes"},{"0006":"On/Off"},{"0012":"Multistate Input (Basic)"},{"0019":"Over-the-Air Upgrade"},{"ffff":"Unknown"},{"0001":"Power Configuration"}],"Ep":"01"},{"ClusterList":[{"0003":"Identify"},{"0004":"Groups"},{"0005":"Scenes"},{"0012":"Multistate Input (Basic)"}],"Ep":"02"},{"ClusterList":[{"0000":"Basic"},{"0003":"Identify"},{"0006":"On/Off"},{"000c":"Analog Input (basic)"},{"0012":"Multistate Input (Basic)"}],"Ep":"03"}]
HW Version : ""
Health : "Live"
IEEE : "00158d00048452bb"
LQI : 99
LastSeen : "24/11/2021 07:59:27"
Model : "lumi.remote.b186acn02"
ProfileID : ""
ReceiveOnIdle : ""
Stack Version : ""
Stamp : Object {"LastSeen":"24/11/2021 07:59:27","MsgType":"8102","Time":"2021-11-24 07:59:27","time":1637737167.9570804}
Status : "inDB"
Type : ""
WidgetList : Array[1] [{"WidgetName":"Zigbee - schak zolder","WidgetType":"DButton_3","_WidgetID":"142"}]
ZDeviceID : ""
ZDeviceName : "schak zolder"
_NwkId : "6551"
6 :
App Version : "65"
Battery : ""
DeviceType : "FFD"
Ep : Array[1] [{"ClusterList":[{"0000":"Basic"},{"0004":"Groups"},{"0005":"Scenes"},{"0006":"On/Off"},{"000a":"Time"},{"0019":"Over-the-Air Upgrade"}],"Ep":"01"}]
HW Version : "1"
Health : "Live"
IEEE : "60a423fffe621821"
LQI : 102
LastCmds : Array[4] [{"CmdCode":"02","TimeStamps":"01/01/1970 01:04:20"},{"CmdCode":"07","TimeStamps":"01/01/1970 01:04:21"},{"CmdCode":"02","TimeStamps":"01/01/1970 01:04:22"},{"CmdCode":"07","TimeStamps":"01/01/1970 01:04:23"}]
LastSeen : "24/11/2021 08:15:09"
Manufacturer : 1002
Model : "TS011F"
ProfileID : "0104"
ReceiveOnIdle : "On"
Stack Version : "0"
Stamp : Object {"LastSeen":"24/11/2021 08:15:09","MsgType":"8011","Time":"2021-11-24 08:15:09","time":1637738109.2255762}
Status : "inDB"
Type : "Switch"
WidgetList : Array[1] [{"WidgetName":"Zigbee - relais zolder","WidgetType":"Switch","_WidgetID":"143"}]
ZDeviceID : "0009"
ZDeviceName : "relais zolder"
_NwkId : "4e2e"
7 :
App Version : "16"
Battery : 161
DeviceType : "RFD"
HW Version : "16"
Health : "Live"
IEEE : "842e14fffef82ab6"
LQI : 63
LastSeen : "24/11/2021 08:13:04"
Model : "HT-EF-3.0"
ProfileID : "0104"
ReceiveOnIdle : "Off"
Stack Version : "2"
Stamp : Object {"LastSeen":"24/11/2021 08:13:04","MsgType":"8011","Time":"2021-11-24 08:13:04","time":1637737984.9062543}
Status : "inDB"
WidgetList : Array[3] [{"WidgetName":"Zigbee - HT-EF-3.0_Voltage-842e14fffef82ab6-01","WidgetType":"Voltage","_WidgetID":"144"},{"WidgetName":"Zigbee - TempBK","WidgetType":"Temp","_WidgetID":"145"},{"WidgetName":"Zigbee - HumBK","WidgetType":"Humi","_WidgetID":"146"}]
ZDeviceID : "0302"
ZDeviceName : "temphum BK"
_NwkId : "7acf"
8 :
App Version : "22"
Battery : 71
DeviceType : "RFD"
Ep : Array[2] [{"ClusterList":[{"0000":"Basic"},{"0001":"Power Configuration"},{"0003":"Identify"},{"0009":"Alarms"},{"0402":"Temperature Measurement"},{"0019":"Over-the-Air Upgrade"}],"Ep":"01"},{"ClusterList":[{"0000":"Basic"},{"0001":"Power Configuration"},{"0003":"Identify"},{"0405":"Relative Humidity Measurement"}],"Ep":"02"}]
HW Version : "16"
Health : "Live"
IEEE : "000d6f0015164c62"
LQI : 117
LastSeen : "24/11/2021 08:15:20"
Model : "HT-EM"
ProfileID : "0104"
Stack Version : "2"
Stamp : Object {"LastSeen":"24/11/2021 08:15:20","MsgType":"8011","Time":"2021-11-24 08:15:20","time":1637738120.0391905}
Status : "inDB"
WidgetList : Array[5] [{"WidgetName":"Zigbee - HT-EM_Voltage-000d6f0015164c62-01","WidgetType":"Voltage","_WidgetID":"147"},{"WidgetName":"Zigbee - HT-EM_Alarm-000d6f0015164c62-01","WidgetType":"Alarm","_WidgetID":"148"},{"WidgetName":"Zigbee - TempSK","WidgetType":"Temp","_WidgetID":"149"},{"WidgetName":"Zigbee - HT-EM_Voltage-000d6f0015164c62-02","WidgetType":"Voltage","_WidgetID":"150"},{"WidgetName":"Zigbee - HumSK","WidgetType":"Humi","_WidgetID":"151"}]
ZDeviceID : "0302"
ZDeviceName : "temphum SK"
_NwkId : "4299"
9 :
App Version : "22"
Battery : 40
DeviceType : "RFD"
Ep : Array[1] [{"ClusterList":[{"0000":"Basic"},{"0001":"Power Configuration"},{"0003":"Identify"},{"0004":"Groups"},{"0201":"Thermostat"},{"0019":"Over-the-Air Upgrade"},{"000a":"Time"},{"0402":"Temperature Measurement"}],"Ep":"01"}]
HW Version : ""
Health : "Live"
IEEE : "00158d00053d2711"
LQI : 153
LastCmds : Array[3] [{"CmdCode":"02","TimeStamps":"01/01/1970 01:01:54"},{"CmdCode":"02","TimeStamps":"01/01/1970 01:01:55"},{"CmdCode":"02","TimeStamps":"01/01/1970 01:01:56"}]
LastSeen : "24/11/2021 08:04:21"
Model : "SPZB0001"
ProfileID : ""
ReceiveOnIdle : ""
Stack Version : "5"
Stamp : Object {"LastSeen":"24/11/2021 08:04:21","MsgType":"8102","Time":"2021-11-24 08:04:21","time":1637737461.000926}
Status : "inDB"
Type : "Temp/ThermoSetpoint/Door/Valve"
WidgetList : Array[4] [{"WidgetName":"Zigbee - Temp_Ivan","WidgetType":"Temp","_WidgetID":"156"},{"WidgetName":"Zigbee - ThermSet Ivan","WidgetType":"ThermoSetpoint","_WidgetID":"157"},{"WidgetName":"Zigbee - SPZB0001_Door-00158d00053d2711-01","WidgetType":"Door","_WidgetID":"158"},{"WidgetName":"Zigbee - SPZB0001_Valve-00158d00053d2711-01","WidgetType":"Valve","_WidgetID":"159"}]
ZDeviceID : ""
ZDeviceName : "thermostaatknop Ivan"
_NwkId : "43f3"
10 :
App Version : "22"
Battery : 25
DeviceType : "RFD"
HW Version : ""
Health : "Live"
IEEE : "00158d00053d2718"
LQI : 78
LastSeen : "24/11/2021 08:15:32"
Model : "SPZB0001"
ProfileID : ""
ReceiveOnIdle : ""
Stack Version : "5"
Stamp : Object {"LastSeen":"24/11/2021 08:15:32","MsgType":"8102","Time":"2021-11-24 08:15:32","time":1637738132.556256}
Status : "inDB"
WidgetList : Array[4] [{"WidgetName":"Zigbee - Temp_Jiri","WidgetType":"Temp","_WidgetID":"160"},{"WidgetName":"Zigbee - ThermSet Jiri","WidgetType":"ThermoSetpoint","_WidgetID":"161"},{"WidgetName":"Zigbee - SPZB0001_Door-00158d00053d2718-01","WidgetType":"Door","_WidgetID":"162"},{"WidgetName":"Zigbee - SPZB0001_Valve-00158d00053d2718-01","WidgetType":"Valve","_WidgetID":"163"}]
ZDeviceID : ""
ZDeviceName : "thermostaatknop Jiri"
_NwkId : "b645"
11 :
App Version : "22"
Battery : 30
ConsistencyCheck : ""
DeviceType : "RFD"
HW Version : ""
Health : "Live"
IEEE : "00158d00053d26e5"
LQI : 168
LastCmds : Array[10] [{"CmdCode":"02","TimeStamps":"01/01/1970 01:06:05"},{"CmdCode":"02","TimeStamps":"01/01/1970 01:06:06"},{"CmdCode":"02","TimeStamps":"01/01/1970 01:06:07"},{"CmdCode":"02","TimeStamps":"01/01/1970 01:06:08"},{"CmdCode":"02","TimeStamps":"01/01/1970 01:06:09"},{"CmdCode":"02","TimeStamps":"01/01/1970 01:06:10"},{"CmdCode":"02","TimeStamps":"01/01/1970 01:06:11"},{"CmdCode":"02","TimeStamps":"None"},{"CmdCode":"02","TimeStamps":"None"},{"CmdCode":"02","TimeStamps":"01/01/1970 01:06:20"}]
LastSeen : "24/11/2021 08:16:07"
Model : "SPZB0001"
ProfileID : ""
ReceiveOnIdle : ""
Stack Version : "5"
Stamp : Object {"LastSeen":"24/11/2021 08:16:07","MsgType":"8102","Time":"2021-11-24 08:16:07","time":1637738167.5483465}
Status : "inDB"
Type : "Temp/ThermoSetpoint/Door"
WidgetList : Array[6] [{"WidgetName":"Zigbee - Temp_SK","WidgetType":"Temp","_WidgetID":"164"},{"WidgetName":"Zigbee - ThermSet SK","WidgetType":"ThermoSetpoint","_WidgetID":"165"},{"WidgetName":"Zigbee - SPZB0001_Door-00158d00053d26e5-01","WidgetType":"Door","_WidgetID":"166"},{"WidgetName":"Zigbee - SPZB0001_Temp-00158d00053d26e5-01","WidgetType":"Temp","_WidgetID":"171"},{"WidgetName":"Zigbee - SPZB0001_ThermoSetpoint-00158d00053d26e5-01","WidgetType":"ThermoSetpoint","_WidgetID":"172"},{"WidgetName":"Zigbee - SPZB0001_Door-00158d00053d26e5-01","WidgetType":"Door","_WidgetID":"173"}]
ZDeviceID : ""
ZDeviceName : "thermostaatknop SK"
_NwkId : "7740"
FWES70
Post by FWES70 »
Thank you for your support
FWES70
Post by FWES70 »
here is the RAW part for the SPZB0001:
12 :
Version : "3"
Status : "inDB"
SQN : "e5"
Heartbeat : "29163"
RIA : "0"
LQI : 168
Battery : 30
Model : "SPZB0001"
ForceAckCommands : Array[0] []
MacCapa : "80"
ProfileID : Object {}
ZDeviceID : Object {}
App Version : "22"
Attributes List : Object {}
DeviceType : "RFD"
HW Version : ""
Last Cmds :
0 : Array[5] [365,"02","7740","0100","0101000000000000010002"]
1 : Array[5] [366,"02","7740","0100","0101000000000000010004"]
2 : Array[5] [367,"02","7740","0100","0101000000000000010005"]
3 : Array[5] [368,"02","7740","0100","0101000000000000010006"]
4 : Array[5] [369,"02","7740","0100","0101000000000000010007"]
5 : Array[5] [370,"02","7740","0100","010100000000000001000a"]
6 : Array[5] [371,"02","7740","0100","0101000000000000014000"]
7 : Array[5] ["None","02","7740","0120","010100010000000001002000211C201C200FFF00"]
8 : Array[5] ["None","02","7740","0120","01010201000000000200290000012C012C0FFF000100290012012C0E100FFF0001"]
9 : Array[5] [380,"02","7740","0110","01010201000110370140032906d6"]
Manufacturer Name : "Eurotronic"
NbEp : ""
ReadAttributes :
Ep : Object {"01":{"0000":{"TimeStamp":"22/11/2021 11:14:10","iSQN":{"4000":371,"0000":363,"0001":364,"0002":365,"0004":366,"0005":367,"0006":368,"0007":369,"000a":370},"Attributes":{"4000":"00","0000":"00","0001":"00","0002":"00","0004":"00","0005":"00","0006":"00","0007":"00","000a":"00"},"ZigateRequest":{}},"0001":{"TimeStamp":"24/11/2021 07:43:56","iSQN":{"0021":344,"0033":345},"Attributes":{"003e":"00","0021":"00","0033":"00"},"ZigateRequest":{}},"0019":{"TimeStamp":"22/11/2021 11:14:01","iSQN":{"0001":346,"0002":347,"0003":348,"0004":349,"0005":350,"0006":351,"0007":352,"0008":353,"0009":354,"000a":355},"Attributes":{},"ZigateRequest":{}},"0201":{"TimeStamp":"24/11/2021 08:21:00","iSQN":{"4002":328,"4003":329,"0000":356,"0008":357,"0010":358,"0012":359,"0014":360,"001b":361,"001c":362},"Attributes":{"4002":"00","4003":"00","4008":"00","0000":"00","0008":"00","0012":"00","0014":"00","0010":"00","001b":"00","001c":"00"},"ZigateRequest":{}},"0402":{"TimeStamp":"22/11/2021 11:14:01","iSQN":{"0000":343},"Attributes":{},"ZigateRequest":{}}},"0b":{"0000":{"TimeStamp":"20/11/2021 10:42:03","iSQN":{"0005":57},"Attributes":{},"ZigateRequest":{}}},"02":{"0000":{"TimeStamp":"20/11/2021 10:42:03","iSQN":{"0005":58},"Attributes":{},"ZigateRequest":{}}},"03":{"0000":{"TimeStamp":"20/11/2021 10:42:03","iSQN":{"0005":59},"Attributes":{},"ZigateRequest":{}}},"06":{"0000":{"TimeStamp":"20/11/2021 10:42:03","iSQN":{"0005":60},"Attributes":{},"ZigateRequest":{}}},"09":{"0000":{"TimeStamp":"20/11/2021 10:42:03","iSQN":{"0005":61},"Attributes":{},"ZigateRequest":{}}}}
ReceiveOnIdle : ""
Stack Version : "5"
Stamp : Object {"time":1637738460.7746372,"Time":"2021-11-24 08:21:00","MsgType":"8102","LastSeen":"24/11/2021 08:21:00"}
ZCL Version : "2"
Health : "Live"
Capability : Array[3] ["Reduced-Function Device","Standard security","NwkAddr should be allocated"]
RollingLQI : Array[11] [168,168,168,168,168,168,168,168,168,168,168]
ConfigSource : "DeviceConf"
Ep : Object {"01":{"0000":{"4000":"22190930","0005":"SPZB0001","0000":"2","0001":"22","0002":"5","0004":"Eurotronic","0006":"20191014","0007":"3","000a":"31393931"},"0001":{"0021":60,"0033":0,"003e":"00000000"},"0003":{},"0004":{},"0201":{"4002":0,"4003":19,"4008":"1","0014":"1600","0012":1900,"0000":16.5,"0008":100,"0010":0,"001b":"02","001c":4},"0019":{},"000a":{},"Type":"Temp/ThermoSetpoint/Door","ClusterType":{"164":"Temp","165":"ThermoSetpoint","166":"Door","171":"Temp","172":"ThermoSetpoint","173":"Door"},"0402":{"0000":1650}}}
WriteAttributes :
Ep :
01 :
0000 : Object {"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}
0001 : Object {"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}
0003 : Object {"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}
0004 : Object {"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}
0201 : Object {"TimeStamp":"22/11/2021 15:54:56","iSQN":{"4003":380,"0010":98},"Attributes":{"4003":"03","0010":"10"},"ZigateRequest":{"4003":{"Status":"fullfilled","DataType":"29","EPin":"01","EPout":"01","manuf_id":"1037","manuf_spec":"01","data":"06d6","ackIsDisabled":true},"0010":{"Status":"fullfilled","DataType":"28","EPin":"01","EPout":"01","manuf_id":"0000","manuf_spec":"00","data":"00","ackIsDisabled":true}}}
0019 : Object {"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}
000a : Object {"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}
0402 : Object {"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}
PairingInProgress : false
Bind : Object {"01":{"0201":{"Target":"0000","Stamp":"20/11/2021 10:42:30","Phase":"binded","Status":"00","i_sqn":64},"0001":{"Target":"0000","Stamp":"20/11/2021 10:42:34","Phase":"binded","Status":"00","i_sqn":65}}}
ConfigureReporting : Object {"Ep":{"01":{"0001":{"TimeStamp":"22/11/2021 11:14:01","iSQN":{},"Attributes":{},"ZigateRequest":{}},"0201":{"TimeStamp":"22/11/2021 11:14:01","iSQN":{},"Attributes":{},"ZigateRequest":{}}}}}
Thermostat : Object {"Calibration":0}
BindingTable : Object {"Devices":[{"00158d00053d26e5":{"sourceEp":"01","Cluster":"0201","targetIEEE":"00158d0000ce0484","targetNickName":"Zigate","targetEp":"01"}},{"00158d00053d26e5":{"sourceEp":"01","Cluster":"0001","targetIEEE":"00158d0000ce0484","targetNickName":"Zigate","targetEp":"01"}}],"SQN":1,"TimeStamp":"20/11/2021 10:43:23","BindingTableTableSize":2,"Status":"Success"}
Max Buffer Size : "7f"
Max Rx : "0064"
Max Tx : "0064"
BatteryUpdateTime : "24/11/2021 07:43:56"
SWBUILD_1 : "20191014"
SWBUILD_3 : "22190930"
Param : Object {}
CheckParam : false
NwkID : "7740"
pipiche
Post by pipiche »
Thanks for that, but please could you kindly simply attach as a file the export.json from WebUI > Tools > Plugin RAW Device (json)
You need to rename the .json extension to .txt in order to attach here, but this will ease the way to navigate into the structutre (please provide the full file and not simply an extract)
Could you cllarify how mainy routers you have ? How far is the SPZB0001 from the ZiGate ?
pipiche
Post by pipiche »
Pour your info, just did a test here with a pretty similar setup as you
- ZiGate V1 (latest firmware)
- Domoticz (2021.1 Build 13872) + Plugin (5.2.293)
It works perfectly.
I have counted 3 routers and 9 Battery based devices.
If the communication beween Domoticz -> ZiGate -> Eurotronics doesn't work well, I would question the level of interferences and how far is the Eurotronics from a Router or from the ZiGate.
On which Wifi 2.4 Channel is your Access point ? You might check the Zigbee channel used, you can find it via the WebUI > Tools > Zigate infos(json). Quiet often Zigate works on channel Zigbee 11, in that case it is important to have the Wifi 2.4 on Wifi 11, so any overlap is prevented.
FWES70
Post by FWES70 »
OK, strange that it works on your side
I cannot change the channel on my router (TPLink Deco5 -> not possible to set manually) so I changed the channel of the Zigate to 14.
The 1st thermostat is 1m away from the Zigate on the other side of the wall, the thermostat 2 and 3 are 2m and 3m away from routers 2 and 3.
After changing the channel I tried again, but the thermostat set point is not overtaken by the thermostat.
I read on other forums that there could be an issue with the firmware of the thermostats, but then they would never have worked. still, could you check what firmware you have? mine have 20191014
I cannot attach the file, even after changing the format it seems...
pipiche
Post by pipiche »
If you change the zigbee channel you need to repair all of your devices
FWES70
Post by FWES70 »
Ok, I will try, will let you know
I sent you a PM with the export
pipiche
Post by pipiche »
FWES70 wrote: Friday 19 November 2021 19:34 Hi all,
Thanks,
F.
Do you have any idea what has been changed in between ?
FWES70
Post by FWES70 »
I have no clue what changed. but the more I read about the SPZB0001 the more I think the issue is in the thermostats firmware.
I will try to flash them to see if that works.
pipiche
Post by pipiche »
Here are the firmware information of the SPZB0001 that I'm using
SWBUILD_1 : "20181205"
SWBUILD_3 : "15181120"
Let me know which firmware you are flashing (and where to get), so I can eventually do the same test.
mgugu
Post by mgugu »
You should also check your frequency plan for wifi and zigbee coexistence, see https://www.metageek.com/training/resou ... existence/.
And specifically this picture:
Where you can see that the frequency numbering is different for zigbee and wifi.
I personally made the mistake to set the wifi on channel 1 while the zigbee was at default channel 11.
With a catastrophic result !
Good setting example is zigbee on channel 11 and wifi on channel 8.
Be aware also that auto channel for wifi does not always take into account zigbee signals specifically for cheap AP.
FWES70
Post by FWES70 »
Thank you for that. I adjusted the channels (Zigate and wifi). but that does not solve the problem.
I tried the flash method described here (thanks Solvisit!) https://github.com/EUROTRONIC-Technolog ... -830773393 and it works. (I erased the flash on 1 of my TRV's and then re-flashed it with the FW from a second)
However there is still no good firmware available, Eurotronic published an OTA firmware downgrade but that works only with DeconZ.
I mailed Eurotronics but I think that will give no result...
So I took a chance: I ordered a new TRV and hope it works, then I will extract that FW and flash it to my other TRV's.
Will keep you updated if it works once the TRV arrives.
FWES70
Post by FWES70 »
pipiche wrote: Saturday 27 November 2021 11:37 Here are the firmware information of the SPZB0001 that I'm using
I could provide you the FW from my not-working TRV's, and you could try to flash it,
Or you extract the FW from 1 of yours and send it to me?
is that allowed by the way?
pipiche
Post by pipiche »
Did you try that one ?
https://github.com/Koenkk/zigbee-OTA/ra ... 22C380.ota
From what I saw in your post, it looks like you had that one SWBUILD_1 : "20191014" which seems a bit newer that the one available on the link above
