Does anybody knows how to add some Zigbee2mqtt Switches/modules to Domoticz switch tab please?
I can see them under Domoticz/Zigbee2mqtt device list as they are already paired but not under settings/devices and this way I can`t bring them to the Switches Tab (add device)
Thanks for any advice
Zigbee2mqtt devices list in domoticz
- heggink
- Domoticz version: 12451
Re: Zigbee2mqtt devices list in domoticz
THis is using the python plugin, correct? I have already switched to the built in autodiscovery which eliminates the need for the plugin.
That said, if tehse devices show up under the plugin's page, they should also show up in domoticz. 2 things I would try: 1) check if your settings allow devices to be added and 2) swicth on debug to see what happens.
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
Msystem
Thanks for the reply,
I have tried debug - true but no luck.
Yes it is phyton plugin - allow devices is on as it work for few devices.
devices which I cant add are zigbee 3.0 controller switched (dimmers)
Maybe time to check auto discovery maybe that will help.
something from log file:
2021-11-23 09:53:30.283 Zigbee2MQTT: (Zigbee2MQTT) Received available devices list from bridge
2021-11-23 09:53:30.283 Zigbee2MQTT: (Zigbee2MQTT) Device 0x84fd27fffe635f86 (0x84fd27fffe635f86) doesn't have "model" attribute, skipped
2021-11-23 09:53:30.283 Zigbee2MQTT: (Zigbee2MQTT) This is not the plugin issue, this is issue with your zigbee network
