Sonoff Touch T1 EU 3 Channel, physical button not working?
LockieFerguson
Post by LockieFerguson »
I am having some issues with my Sonoff Touch T1 EU 3 Channel and was wondering if someone would find the issue.
My setup:
Hardware:
1x Sonoff Touch T1 EU 3 Channel
1x Sonoff Touch T1 EU 1 Channel
All a running Tasmota 8.4.0 with MQTT
I have not setup a light connected to channel 1 of the 3 Channel Touch and directly to the 1 Channel.
When I toggle the switch in the domoticz everything works perfectly, also when I toggle it via the webbrowser.
Only when touching the physical button on the 3 channel, it turns on the relay but does not turn on the light.
I have a similar setup with Channel 2 and 3 of the 3 Channel Touch and there is works perfetly fine.
Does anyone has any idea what the issue could be?
I also tried re-flashing both devices and giving new IdX numbers, without any success.
HarryHase
Domoticz version: stable
Re: Sonoff Touch T1 EU 3 Channel, physical button not working?
Post by HarryHase »
Maybe you have to check, which is the correct template
https://templates.blakadder.com/sonoff_TX-T3EU3C.html
FireWizard
Post by FireWizard »
Hi @LockieFerguson,
Could this be caused by the " Prevent Loop" setting?
Have a look at viewtopic.php?f=11&t=33584&p=255849&hil ... op#p255849
As you probably use MQTT, in this case you have to change the setting to "False".
